查看: 5201|回复: 0
mysql 5.7 安装(收藏防迷路)
143
145
585
585
2020-5-25
42 小时
发表于 2020-12-15 16:47:41 | 显示全部楼层 |阅读模式
1、下载
下载文件为:mysql-5.7.28-1.el7.x86_64.rpm-bundle.tar (解压版)
2、卸载原来安装的mysql
#检查
rpm -qa | grep mariadb
rpm -qa | grep mysql
#卸载 remove后为上面命令查询到的内容,全文件名
yum remove mariadb-xxx
3、解压文件到安装目录
tar -zxvf mysql-5.7.28-linux-glibc2.12-x86_64.tar.gz -C /data/module/
mv mysql-5.7.28-linux-glibc2.12-x86_64 mysql-5.7.28
4、软连接
#在/usr/local/目录下创建到/data/module/mysql-5.7.28的软链接
cd /usr/local
ln -s /data/module/mysql-5.7.28 mysql
5、添加mysql用户
#修改mysql目录权限,并用此用户执行应用
useradd -s /bin/false -M mysql
cd /data/module
chown -R mysql:mysql mysql-5.7.28
6、修改配置文件
#vim /etc/my.cnf
[mysqld]
# binlog 配置
log-bin=/usr/local/mysql/logs/mysql-bin.log
expire-logs-days=14
max-binlog-size=500M
server-id=1
# GENERAL
basedir=/usr/local/mysql
datadir=/usr/local/mysql/data
socket=/usr/local/mysql/mysql.sock
user=mysql
default-storage-engine=InnoDB
character-set-server=utf8
lower_case_table_names = 1
explicit_defaults_for_timestamp=true
[mysqld_safe]
log-error=/usr/local/mysql/mysql-error.log
pid-file=/usr/local/mysql/mysqld.pid
[client]
[mysql]
default-character-set=utf8
7、安装mysql
cd /data/module/mysql-5.7.28
bin/mysqld --initialize --user=mysql --basedir=/usr/local/mysql --datadir=/usr/local/mysql/data
报错! 在/usr/local/mysql/下创建 logs 文件夹就行了,并改为mysql用户。
执行成功后,不要动此窗口,有初始密码需要复制
8、拷贝启动程序
# 再开一个窗口 将mysql的启动程序拷贝到/etc/init.d/目录下
cp /usr/local/mysql/support-files/mysql.server /etc/init.d/mysqld
9、启动mysql
service mysqld start
# 如果报错,可能是mysql-error.log不存在,手动去创建,并修改权限
touch mysql-error.log
chown mysql:mysql mysql-error.log
# 再次启动
10、配置环境变量
# vim /etc/profile 增加
#mysql
export MYSQL_HOME=/usr/local/mysql
export PATH=$PATHMYSQL_HOME/bin
改完 source /etc/profile
11、修改密码
mysql -uroot -p
# 密码为第7步生成的初始密码
mysql> alter user 'root'@'localhost' identified by '000000';
mysql> flush privileges;
12、开启远程连接
GRANT ALL PRIVILEGES ON *.* TO 'root'@'%' IDENTIFIED BY '123456' WITH GRANT OPTION;
13、开机自启配置
chmod +x /etc/init.d/mysqld
chkconfig --add mysqld
chkconfig --list
# 345为on
chkconfig --level 345 mysqld on
14、登录更改
登录 mysql -uroot -p -P3306 -A
use mysql;
update user set host = '%' where user = 'root';
flush privileges;
修改密码
mysql> update user set password=password("*******") where user="*******";  #修改密码报错
ERROR 1054 (42S22): Unknown column 'password' in 'field list'
mysql> update mysql.user set authentication_string=password('*******') where user='*******';  #修改密码成功
Query OK, 1 row affected, 1 warning (0.00 sec)
Rows matched: 1  Changed: 1  Warnings: 1
flush privileges;
GMT+8, 2026-11-5 20:22
