查看: 8470|回复: 3
rt_thread_yield好像没起作用是为什么
23
81
81
2020-5-9
14 小时
发表于 2020-12-28 16:32:21 | 显示全部楼层 |阅读模式
int main(void)
    delay_init(168);
    MX_USART1_UART_Init();
    freertos_init();
static void thread1_entry(void *parameter)
    rt_uint32_t count = 0;
        rt_kprintf("thread 1 count = %d\r\n",count++);
        rt_thread_yield();
static void thread2_entry(void *parameter)
        rt_kprintf("thread 2 count = %d\r\n",count++);
        rt_thread_yield();
static void startDefaultTaskFuc(void *parameter)
        tid2 = rt_thread_create("t1", thread1_entry, RT_NULL, 512, 5, 5);
        if(tid2!=RT_NULL)
            rt_thread_startup(tid2);
            rt_kprintf("create thread1 failed!\r\n");
        tid3 = rt_thread_create("t2", thread2_entry, RT_NULL, 512, 5, 5);
        if(tid3 !=RT_NULL)
            rt_thread_startup(tid3);
            rt_kprintf("create thread2 failed!\r\n");
void freertos_init(void)
    rt_thread_init(&startDefaultTask, "start", startDefaultTaskFuc, RT_NULL, rt_startDefaultTask_stack, sizeof(rt_startDefaultTask_stack), 3, 20);
    rt_thread_startup(&startDefaultTask);
以上程序,理论上应该是线程1和线程2交替运行吧,为什么我的rt_thread_yield好像不起作用 ,rt_thread_yield函数中该处if (to_thread != rt_current_thread)判断错误。在打印函数还未执行完就跳到另一个线程了
收←◆thread 1 count = 0
thread 1 count = 1
thread 1 count = 2
thread 1 count = 3
thread 1 count = thread 2 count = 0
thread 2 count = 1
thread 2 c2
thread 1 count = 5
thread 1 count = 6
threadount = 7
thread 2 count = 3
thread 2 count = 4
2 count = 4
thread 1 count = 8
thread 1 count =thread 2 count = 5
thread 2 count = 6
thread 2 c 7
thread 1 count = 10
thread 1 count = 11
thrount = 12thread 2 count = 8
thread 2 count = 9
ead 2 count = 9
\0thread 1 count = 13
23
81
81
2020-5-9
14 小时
 楼主| 发表于 2020-12-28 17:02:26 | 显示全部楼层
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "lcd.h"
#include "key.h"
#include "rtthread.h"
正点原子 探索者F407开发板        RT-Thread实验7
yield切换线程 - 库函数版本
RT-Thread官方微信公众号:RTThread
RT-Thread技术论坛:http://www.rt-thread.org
正点原子官方微信公众号:正点原子
正点原子技术论坛:www.openedv.com
正点原子淘宝店铺:http://eboard.taobao.com
作者: RT-Thread        &        正点原子
/* 重映射串口1到rt_kprintf */
void rt_hw_console_output(const char *str)
        rt_enter_critical();
        while (*str!='\0')
                if (*str=='\n')
                        USART_SendData(USART1, '\r');
                        while (USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
                USART_SendData(USART1, *str++);
        rt_exit_critical();
#define THREAD_STACK_SIZE 512
#define THREAD_PRIORITY   2
#define THREAD_TIMESLICE  20
/* 指向线程控制块的指针 */
static rt_thread_t tid1 = RT_NULL;
static rt_thread_t tid2 = RT_NULL;
/* 线程1入口 */
static void thread1_entry(void* parameter)
    while (1)
                /* 打印线程1的输出 */
                rt_kprintf("thread1: count = %d\n", count ++);
                /* 执行yield后应该切换到thread2执行 */
                rt_thread_yield();
/* 线程2入口 */
static void thread2_entry(void* parameter)
    while (1)
        /* 打印线程2的输出 */
        rt_kprintf("thread2: count = %d\n", count ++);
        /* 执行yield后应该切换到thread1执行 */
        rt_thread_yield();
int main()
    /* 创建线程1 */
    tid1 = rt_thread_create("thread",
                                                        thread1_entry,
                                                        RT_NULL, /* 线程入口是thread1_entry, 入口参数是RT_NULL */
                                                        THREAD_STACK_SIZE,
                                                        THREAD_PRIORITY,
                                                        THREAD_TIMESLICE);
    if (tid1 != RT_NULL)
        rt_thread_startup(tid1);
    /* 创建线程2 */
    tid2 = rt_thread_create("thread",
                                                        thread2_entry,
                                                        RT_NULL, /* 线程入口是thread2_entry, 入口参数是RT_NULL */
                                                        THREAD_STACK_SIZE,
                                                        THREAD_PRIORITY,
                                                        THREAD_TIMESLICE);
    if (tid2 != RT_NULL)
    return 0;
这是正点原子的例程,优先级太高的话线程2还未创建成功线程1就开始运行,并且main函数无法再获取时间片,将优先级从5改为25的结果有点混乱,但是应该是理想的结果吧。那我改的程序问题出在哪呢?收←◆msh >thread1: count = 0
thread1: count = 1
thrthread2: count = 0
thread2: count = 1
thread2: counead2: count = 2
thread1: count = 3
thread1: count t = 4
thread2: count = 3
thread2: count = 4
threa= 5
thread1: count = 5
thread1: count = 6
thread1d1: count = 7
thread2: count = 6
thread2: count = : count = 7
thread1: count = 8
thread1: count = 99
thread2: count = 8
thread2: count = 9
thread2: 0thread1: count = 10
thread1: count = 11
thread1: ccount = 12
thread2: count = 11
thread2: count = 12ount = 12
thread1: count = 13
thread1: count = 14
thread2: count = 13
thread2: count = 14
发表于 2020-12-29 01:30:48 | 显示全部楼层
268
1053
1053
2020-5-11
253 小时
发表于 2020-12-29 08:58:30 | 显示全部楼层
GMT+8, 2026-11-4 02:54
