查看: 6712|回复: 6
求助 lvgl7.1移植完不显示控件 stm32F405RG
2020-1-6
发表于 2021-1-30 16:51:34 | 显示全部楼层 |阅读模式
rt,板子是stm32f405rgt6 屏幕是ili9488
移植完之后什么都不显示,只有一片白
有没有大神知道是什么原因
lv_port_disp.c
#if 1
#include "lv_port_disp.h"
#include "lcd.h"
#include "gui.h"
#define COLOR_BUF_SIZE (LV_HOR_RES_MAX*LV_VER_RES_MAX)
static void disp_flush(lv_disp_drv_t * disp_drv, const lv_area_t * area, lv_color_t * color_p);
void lv_port_disp_init(void)
     * Create a buffer for drawing
    /* Example for 1) */
    static lv_disp_buf_t disp_buf_1;
    static lv_color_t buf1_1[LV_HOR_RES_MAX * 10];                      /*A buffer for 10 rows*/
    lv_disp_buf_init(&disp_buf_1, buf1_1, NULL, LV_HOR_RES_MAX * 10);   /*Initialize the display buffer*/
     * Register the display in LittlevGL
    lv_disp_drv_t disp_drv;                         /*Descriptor of a display driver*/
    lv_disp_drv_init(&disp_drv);                    /*Basic initialization*/
    /*Set up the functions to access to your display*/
    /*Set the resolution of the display*/
    disp_drv.hor_res = lcddev.width;
    disp_drv.ver_res = lcddev.height;
    /*Used to copy the buffer's content to the display*/
    disp_drv.flush_cb = disp_flush;
    /*Set a display buffer*/
    disp_drv.buffer = &disp_buf_1;
#if LV_USE_GPU
    /*Optionally add functions to access the GPU. (Only in buffered mode, LV_VDB_SIZE != 0)*/
    /*Blend two color array using opacity*/
    disp_drv.gpu_blend = gpu_blend;
    /*Fill a memory array with a color*/
    disp_drv.gpu_fill = gpu_fill;
#endif
    /*Finally register the driver*/
    lv_disp_drv_register(&disp_drv);
          LCD_Fill(area->x1,area->y1,area->x2,area->y2,color_p->full);
    lv_disp_flush_ready(disp_drv);//???????,?? lvgl ???? flushing ?????
#else /* Enable this file at the top */
/* This dummy typedef exists purely to silence -Wpedantic. */
typedef int keep_pedantic_happy;
#endif
2020-1-6
 楼主| 发表于 2021-1-30 16:52:28 | 显示全部楼层
main.c
#include "delay.h"
#include "sys.h"
#include "lcd.h"
#include "touch.h"
#include "gui.h"
#include "test.h"
#include "lv_port_indev.h"
void lvgl_first_demo_start(void);
int main(void)
        delay_init(168);     //3õê¼»ˉÑóê±oˉêy
        LCD_Init();           //òo¾§Æá3õê¼»ˉ
        lv_init(); //lvgl ?????
        lv_port_disp_init();
//        lv_port_indev_init();
        LCD_Fill(0,0,lcddev.width,lcddev.height,GREEN);
        lvgl_first_demo_start();
                lv_tick_inc(1);
                lv_task_handler();
    lv_obj_t * btn = lv_btn_create(lv_scr_act(), NULL);     /*Add a button the current screen*/
    lv_obj_set_pos(btn, 1, 1);                            /*Set its position*/
    lv_obj_set_size(btn, 12, 5);                          /*Set its size*/
//    lv_obj_set_event_cb(btn, btn_event_cb);                 /*Assign a callback to the button*/
    lv_obj_t * label = lv_label_create(btn, NULL);          /*Add a label to the button*/
    lv_label_set_text(label, "Button");                     /*Set the labels text*/
        lv_obj_t * label1 = lv_label_create(lv_scr_act(), NULL);
        lv_label_set_text(label1, "Hello world!");
        lv_obj_align(label1, NULL, LV_ALIGN_CENTER, 0, 0);
        lv_obj_align(btn, label1, LV_ALIGN_OUT_TOP_MID, 0, -10);
72
520
520
2020-6-6
232 小时
发表于 2021-4-6 10:37:16 | 显示全部楼层
70
70
2020-5-12
发表于 2021-12-25 16:26:36 | 显示全部楼层
108
108
2019-10-29
40 小时
发表于 2022-3-15 18:05:38 | 显示全部楼层
兄弟,这个问题解决了吗
55
148
148
2020-5-21
62 小时
发表于 2022-3-16 08:46:44 | 显示全部楼层
这是我的能正常显示
    /*The most simple case (but also the slowest) to put all pixels to the screen one-by-one*/
    int32_t x;
    int32_t y;
    for(y = area->y1; y <= area->y2; y++) {
        for(x = area->x1; x <= area->x2; x++) {
                        lcd_point_set(x,y,color_p->full);
            color_p++;
    /* IMPORTANT!!!
     * Inform the graphics library that you are ready with the flushing*/
55
148
148
2020-5-21
62 小时
发表于 2022-3-16 09:06:28 | 显示全部楼层
这个能正常显示
    int32_t x;
    int32_t y;
            color_p++;
    /* IMPORTANT!!!
GMT+8, 2026-11-4 18:39
