查看: 9138|回复: 2
ME3630 开机4G模块启动问题
45
182
182
2021-1-4
38 小时
发表于 2021-2-2 14:42:22 | 显示全部楼层 |阅读模式
开机的时候
APP已经启动了
但是4G模块没启动,导致找不到4G模块
如果等4G模块启动完,马上连接 ttyUSB1
就会发生
usb 2-1.2: USB disconnect, device number 4
option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-19)
option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
option 2-1.2:1.0: device disconnected
option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
option 2-1.2:1.1: device disconnected
option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
option 2-1.2:1.2: device disconnected
cdc_ether 2-1.2:1.3 usb0: unregister 'cdc_ether' usb-ci_hdrc.1-1.2, CDC Ethernet Device
usb 2-1.2: new high-speed USB device number 5 using ci_hdrc
idVendor=19d2, idProduct=1476, bInterfaceNumber =0
option 2-1.2:1.0: GSM modem (1-port) converter detected
usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB0
idVendor=19d2, idProduct=1476, bInterfaceNumber =1
option 2-1.2:1.1: GSM modem (1-port) converter detected
usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB2
idVendor=19d2, idProduct=1476, bInterfaceNumber =2
option 2-1.2:1.2: GSM modem (1-port) converter detected
usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB3
cdc_ether 2-1.2:1.3 usb0: register 'cdc_ether' at usb-ci_hdrc.1-1.2, CDC Ethernet Device, 2e:2b:54:9b:5e:c8
上面打印信息,不知道为什么连接了4G模块的ttyUSB1后,模块好像重启了一样,变成了 ttyUSB0 ttyUSB2 ttyUSB3
198
1065
1065
2019-9-19
195 小时
发表于 2021-2-2 15:17:44 | 显示全部楼层
这种是业务逻辑可以调整的吧,简单就可以加个延时,等驱动起来后,再发数据。还得看你的APP是做什么功能。
2021-11-21
发表于 2021-11-28 17:13:54 | 显示全部楼层
老哥,你的开机启动问题解决了吗,我用的udev规则,等udev检测到ttyUSB之后,就马上执行脚本连接。但是我发现使用udev太慢了,情况好得话,3分钟连上网,有时候甚至都连不上......
GMT+8, 2026-10-31 01:37
