查看: 3248|回复: 1
打印 上一主题 下一主题
[ALTERA] SDRAM仿真文件sdr.v是怎么生成的?
58
58
2019-9-7
14 小时
跳转到指定楼层
楼主
发表于 2021-2-15 20:43:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问这个module sdr (Dq, Addr, Ba, Clk, Cke, Cs_n, Ras_n, Cas_n, We_n, Dqm);仿真模块是怎么生成的?
*    File Name:  sdr.v
*      Version:  2.2
*         Date:  October 12th, 2010
*        Model:  BUS Functional
*    Simulator:  Model Technology
* Dependencies:  None
*        Email:  modelsupport@micron.com
*      Company:  Micron Technology, Inc.
*  Description:  Micron SDRAM Verilog model
*   Limitation:  - Doesn't check for refresh timing
*         Note:  - Set simulator resolution to "ps" accuracy
*                - Set Debug = 0 to disable $display messages
*   Disclaimer:  THESE DESIGNS ARE PROVIDED "AS IS" WITH NO WARRANTY
*                WHATSOEVER AND MICRON SPECIFICALLY DISCLAIMS ANY
*                IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR
*                A PARTICULAR PURPOSE, OR AGAINST INFRINGEMENT.
*                Copyright ?2001 Micron Semiconductor Products, Inc.
*                All rights researved
* Rev  Author          Date        Changes
* 2.3  SH              05/12/2016  - Update tAC, tHZ timing
*      Micron Technology Inc.
* 2.2  SH              10/12/2010  - Combine all parts into sdr_parameters.vh
* 2.1  SH              06/06/2002  - Typo in bank multiplex
* 2.0  SH              04/30/2002  - Second release
`timescale 1ns / 1ps
`include "sdr_parameters.h"
    input                         Clk;
    input                         Cke;
    input                         Cs_n;
    input                         Ras_n;
    input                         Cas_n;
    input                         We_n;
    input     [ADDR_BITS - 1 : 0] Addr;
    input       [BA_BITS - 1 : 0] Ba;
    inout       [DQ_BITS - 1 : 0] Dq;
    input       [DM_BITS - 1 : 0] Dqm;
    reg         [DQ_BITS - 1 : 0] Bank0 [0 : mem_sizes];
    reg         [DQ_BITS - 1 : 0] Bank1 [0 : mem_sizes];
    reg         [DQ_BITS - 1 : 0] Bank2 [0 : mem_sizes];
    reg         [DQ_BITS - 1 : 0] Bank3 [0 : mem_sizes];
    reg                   [1 : 0] Bank_addr [0 : 3];                // Bank Address Pipeline
    reg        [COL_BITS - 1 : 0] Col_addr [0 : 3];                 // Column Address Pipeline
    reg                   [3 : 0] Command [0 : 3];                  // Command Operation Pipeline
    reg                   [1 : 0] Dqm_reg0, Dqm_reg1;               // DQM Operation Pipeline
    reg       [ADDR_BITS - 1 : 0] B0_row_addr, B1_row_addr, B2_row_addr, B3_row_addr;
    reg       [ADDR_BITS - 1 : 0] Mode_reg;
    reg         [DQ_BITS - 1 : 0] Dq_reg, Dq_dqm;
    reg        [COL_BITS - 1 : 0] Col_temp, Burst_counter;
    reg                           Act_b0, Act_b1, Act_b2, Act_b3;   // Bank Activate
    reg                           Pc_b0, Pc_b1, Pc_b2, Pc_b3;       // Bank Precharge
    reg                   [1 : 0] Bank_precharge       [0 : 3];     // Precharge Command
    reg                           A10_precharge        [0 : 3];     // Addr[10] = 1 (All banks)
    reg                           Auto_precharge       [0 : 3];     // RW Auto Precharge (Bank)
    reg                           Read_precharge       [0 : 3];     // R  Auto Precharge
    reg                           Write_precharge      [0 : 3];     //  W Auto Precharge
    reg                           RW_interrupt_read    [0 : 3];     // RW Interrupt Read with Auto Precharge
    reg                           RW_interrupt_write   [0 : 3];     // RW Interrupt Write with Auto Precharge
    reg                   [1 : 0] RW_interrupt_bank;                // RW Interrupt Bank
    integer                       RW_interrupt_counter [0 : 3];     // RW Interrupt Counter
    integer                       Count_precharge      [0 : 3];     // RW Auto Precharge Counter
    reg                           Data_in_enable;
    reg                           Data_out_enable;
    reg                   [1 : 0] Bank, Prev_bank;
    reg       [ADDR_BITS - 1 : 0] Row;
    reg        [COL_BITS - 1 : 0] Col, Col_brst;
    // Internal system clock
    reg                           CkeZ, Sys_clk;
    // Commands Decode
    wire      Active_enable    = ~Cs_n & ~Ras_n &  Cas_n &  We_n;
    wire      Aref_enable      = ~Cs_n & ~Ras_n & ~Cas_n &  We_n;
    wire      Burst_term       = ~Cs_n &  Ras_n &  Cas_n & ~We_n;
    wire      Mode_reg_enable  = ~Cs_n & ~Ras_n & ~Cas_n & ~We_n;
    wire      Prech_enable     = ~Cs_n & ~Ras_n &  Cas_n & ~We_n;
    wire      Read_enable      = ~Cs_n &  Ras_n & ~Cas_n &  We_n;
    wire      Write_enable     = ~Cs_n &  Ras_n & ~Cas_n & ~We_n;
    // Burst Length Decode
    wire      Burst_length_1   = ~Mode_reg[2] & ~Mode_reg[1] & ~Mode_reg[0];
    wire      Burst_length_2   = ~Mode_reg[2] & ~Mode_reg[1] &  Mode_reg[0];
    wire      Burst_length_4   = ~Mode_reg[2] &  Mode_reg[1] & ~Mode_reg[0];
    wire      Burst_length_8   = ~Mode_reg[2] &  Mode_reg[1] &  Mode_reg[0];
    wire      Burst_length_f   =  Mode_reg[2] &  Mode_reg[1] &  Mode_reg[0];
    // CAS Latency Decode
    wire [2 : 0] Cas_latency   =  {Mode_reg[6],  Mode_reg[5],   Mode_reg[4]};
    // Write Burst Mode
    wire      Write_burst_mode = Mode_reg[9];
    wire      Debug            = 1'b1;                          // Debug messages : 1 = On
    wire      Dq_chk           = Sys_clk & Data_in_enable;      // Check setup/hold time for DQ
    assign    Dq               = Dq_reg;                        // DQ buffer
    // Commands Operation
    `define   ACT       0
    `define   NOP       1
    `define   READ      2
    `define   WRITE     3
    `define   PRECH     4
    `define   A_REF     5
    `define   BST       6
    `define   LMR       7
    // These timing dynamically adjust based on CAS Latency
    time  tAC, tHZ;
    // Timing Check variable
    time  MRD_chk;
    time  WR_chkm [0 : 3];
    time  RFC_chk, RRD_chk;
    time  RC_chk0, RC_chk1, RC_chk2, RC_chk3;
    time  RAS_chk0, RAS_chk1, RAS_chk2, RAS_chk3;
    time  RCD_chk0, RCD_chk1, RCD_chk2, RCD_chk3;
    time  RP_chk0, RP_chk1, RP_chk2, RP_chk3;
    initial begin
        Dq_reg = {DQ_BITS{1'bz}};
        Data_in_enable = 0; Data_out_enable = 0;
        Act_b0 = 1; Act_b1 = 1; Act_b2 = 1; Act_b3 = 1;
        Pc_b0 = 0; Pc_b1 = 0; Pc_b2 = 0; Pc_b3 = 0;
        WR_chkm[0] = 0; WR_chkm[1] = 0; WR_chkm[2] = 0; WR_chkm[3] = 0;
        RW_interrupt_read[0] = 0; RW_interrupt_read[1] = 0; RW_interrupt_read[2] = 0; RW_interrupt_read[3] = 0;
        RW_interrupt_write[0] = 0; RW_interrupt_write[1] = 0; RW_interrupt_write[2] = 0; RW_interrupt_write[3] = 0;
        MRD_chk = 0; RFC_chk = 0; RRD_chk = 0;
        RAS_chk0 = 0; RAS_chk1 = 0; RAS_chk2 = 0; RAS_chk3 = 0;
        RCD_chk0 = 0; RCD_chk1 = 0; RCD_chk2 = 0; RCD_chk3 = 0;
        RC_chk0 = 0; RC_chk1 = 0; RC_chk2 = 0; RC_chk3 = 0;
        RP_chk0 = 0; RP_chk1 = 0; RP_chk2 = 0; RP_chk3 = 0;
        $timeformat (-9, 1, " ns", 12);
    end
2217
6430
6430
2018-10-21
1907 小时
2#
发表于 2021-2-20 17:48:56 | 只看该作者
一般是芯片原厂提供的
GMT+8, 2026-10-25 06:40
