查看: 8910|回复: 6
使用正点原子邮票孔二次开发,网络口问题
336
336
2019-10-2
88 小时
发表于 2021-3-4 20:50:37 | 显示全部楼层 |阅读模式
需求:  项目只需要一个网络口,故原理图保留了正点原子的PHY地址为0的网络即ENET1,去掉ENET2。
操作步骤(我这边修改的是出厂的源代码):按照《【正点原子】I.MX6U嵌入式Linux驱动开发指南V1.5》
中第1700页69.6.2节的指导,修改设备树文件,修改为如下:
/*hxf pinctrl_enet2: enet2grp {
                        fsl,pins = <
                                MX6UL_PAD_GPIO1_IO07__ENET2_MDC                0x1b0b0
                                MX6UL_PAD_GPIO1_IO06__ENET2_MDIO        0x1b0b0
                                MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN        0x1b0b0
                                MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER        0x1b0b0
                                MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00        0x1b0b0
                                MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01        0x1b0b0
                                MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN        0x1b0b0
                                MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00        0x1b0b0
                                MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01        0x1b0b0
                                MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2        0x4001b009
&fec1 {
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_enet1
                     &pinctrl_fec1_reset>;
        phy-mode = "rmii";
        phy-handle = <ephy0>;
        phy-reset-gpios = <&gpio5 7 GPIO_ACTIVE_LOW>;
        phy-reset-duration = <200>;
        status = "okay";
        mdio {
                #address-cells = <1>;
                #size-cells = <0>;
                ethphy0: ethernet-phy@0 {
                        compatible = "ethernet-phy-ieee802.3-c22";
                        reg = <0>;
/*&hxf fec2 {
        pinctrl-0 = <&pinctrl_enet2
                     &pinctrl_fec2_reset>;
        phy-mode = "rmii";
        phy-handle = <ephy1>;
        phy-reset-gpios = <&gpio5 8 GPIO_ACTIVE_LOW>;
        status = "okay";
        mdio {
                #size-cells = <0>;
                ethphy0: ethernet-phy@1 {
                        reg = <0>;
                ethphy1: ethernet-phy@2 {
                        reg = <1>;
pinctrl_enet1: enet1grp {
                        fsl,pins = <
                                MX6UL_PAD_GPIO1_IO07__ENET1_MDC                0x1b0b0
                                MX6UL_PAD_GPIO1_IO06__ENET1_MDIO        0x1b0b0
                                MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN        0x1b0b0
                                MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER        0x1b0b0
                                MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00        0x1b0b0
                                MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01        0x1b0b0
                                MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN        0x1b0b0
                                MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00        0x1b0b0
                                MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01        0x1b0b0
                                MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1        0x4001b009
。并且修改\u-boot\include\configs路径下mx6ullevk.h文件
网络的宏为#define CONFIG_FEC_ENET_DEV                0。
重新编译后,下载到开发板上。开发板接入公司局域网内,网线插在ENET1口上,
另一端连接在交换机一端口上。WINDOWS主机已经关闭防火墙。
在UBOOT内设置好变量如下:
setenv ipaddr 192.168.6.45
setenv ethaddr 00:04:9f:04:d2:35
setenv gatewayip 192.168.6.1
setenv netmask 255.255.255.0
setenv serverip 192.168.6.125
问题1.描述:启动完成后,设置开发板IP地址为192.168.6.45。在控制终端内ping服务器(地址为192.168.6.125),提示
“ Destination Host Unreachable”。开发板LOG输出文件见“alietek_logo_network.txt”。奇怪的是网络驱动变成了generic 驱动了。用官方出厂固件能ping通。
有人碰到过这个问题吗?折腾了好几天了,没解决。
问题2:正点原子提供的邮票孔原理图SYMBOLE中第67管脚名称为ENET1_RX_DATA0/ENET1_TXD0。感觉命名错误了,正确的应该是
ENET1_TX_DATA0/ENET1_TXD0。
alietek_log_network.txt.zip
23.89 KB, 下载次数: 2
336
336
2019-10-2
88 小时
 楼主| 发表于 2021-3-5 19:46:12 | 显示全部楼层
没人回答,自己顶顶
336
336
2019-10-2
88 小时
 楼主| 发表于 2021-3-19 18:54:11 | 显示全部楼层
我这边的设计是邮票孔板与l c d在一个p c b上,lan8720在另一个板子上,两个pcb用 pfc线缆连接信号、距离大约是20c m。也就是mac与phy的距离有20厘米的距离。
发表于 2021-3-21 01:34:10 | 显示全部楼层
336
336
2019-10-2
88 小时
 楼主| 发表于 2021-3-21 09:42:40 | 显示全部楼层
问了,没见答复
发表于 2021-3-22 02:46:52 | 显示全部楼层
明天继续问
69
6727
13696
13696
2012-11-26
3873 小时
发表于 2021-3-22 08:58:43 | 显示全部楼层
既然官方的固件能ping通,那就用官方的设备树,加上设置为网口1试试
学无止境
GMT+8, 2026-10-31 04:01
