查看: 8669|回复: 3
[新手求助] 把RT-Thread Nano移植到F103RC之后,不能正常点亮LED问题
2021-3-16
发表于 2021-3-26 14:41:01 | 显示全部楼层 |阅读模式
各位大佬, 如题:
板子上有两个LED灯, 一个蓝色,一个红色, 我想在RT-Thread Nano OS的两个thread里, 循环点亮和熄灭LED灯, 但是运行到蓝色LED灯灭之后,LED灯的状态就不变了, 问题出现在哪里了呢?
【这个Nano里, 没有使用heap】
#include "stm32f10x_gpio.h"
#include "myFunctions.h"
#include "stm32f10x.h"
#include <rtthread.h>
#define THREAD_PRIORITY         1
#define THREAD_STACK_SIZE       100
#define THREAD_TIMESLICE        100
//ALIGN(RT_ALIGN_SIZE)
static char thread1_stack[100];
static struct rt_thread thread1;
/* 线程1入口 */
static void thread1_entry(void *param)
    int count = 0;
        while (1)
                if(count == 0)
                        GPIO_SetBitx(GPIOA,GPIO_Pin_8); //Blue LED OFF
                        rt_thread_mdelay(1000);
                        count = 1;
                        GPIO_ResetBitx(GPIOA,GPIO_Pin_8); //Blue LED ON
                        count = 0;
static char thread2_stack[100];
static struct rt_thread thread2;
/* 线程2入口 */
static void thread2_entry(void *param)
    int count = 0;
        while (1)
                if(count == 0)
                        GPIO_SetBitx(GPIOD,GPIO_Pin_2); //Red  LED OFF
                        rt_thread_mdelay(5000);
                        count = 1;
                        GPIO_ResetBitx(GPIOD,GPIO_Pin_2); //Red  LED ON
                        count = 0;
int main()
        rt_err_t retValue= 0;
        LED_GPIO_Init();
        /* 初始化线程1,名称是thread1,入口是thread1_entry */
        retValue = rt_thread_init(&thread1,"thread1",thread1_entry,RT_NULL,&thread1_stack[0],sizeof(thread1_stack),THREAD_PRIORITY, THREAD_TIMESLICE);
        retValue = rt_thread_startup(&thread1);
        if(retValue == RT_EOK)
                GPIO_SetBitx(GPIOA,GPIO_Pin_8); //Blue LED OFF    //-------------------------》 程序运行到了这里, 蓝色灯也熄灭了。
        /* 初始化线程2,名称是thread2,入口是thread2_entry */
        retValue = rt_thread_init(&thread2, "thread2",thread2_entry,RT_NULL,&thread2_stack[0],sizeof(thread2_stack),THREAD_PRIORITY, THREAD_TIMESLICE);
        retValue = rt_thread_startup(&thread2);
                GPIO_SetBitx(GPIOD,GPIO_Pin_2); //Red  LED OFF   //-------------------------》 程序没有运行到了这里, 红色LED一直亮。
        return 0;
编译没有错误,下载到板子上,也能运行。
compiling board.c...
linking...
Program Size: Code=6780 RO-data=644 RW-data=128 ZI-data=2888
FromELF: creating hex file...
".\Objects\LED_Test.axf" - 0 Error(s), 1 Warning(s).
Build Time Elapsed:  00:00:05
2021-3-16
 楼主| 发表于 2021-3-29 09:11:03 | 显示全部楼层
现在LED灯能正常点亮了, 解决办法是: 把 RTT的 SysTick 从默认的1ms,改成了10ms, 把stack也加大到500bytes。
这样改,是因为我的板子主频太低了, 入门的板子
不过又出现新问题: delay函数有点不对了, 比如想要延时1s, delay函数的输入得是100, 不是1000, 不知道怎么改。。。。
发表于 2021-3-30 02:18:04 | 显示全部楼层
wzcfxu 发表于 2021-3-29 09:11
现在LED灯能正常点亮了, 解决办法是: 把 RTT的 SysTick 从默认的1ms,改成了10ms, 把stack也加大到500by ...
继续努力
154
434
434
2013-3-18
82 小时
发表于 2021-3-31 08:49:02 | 显示全部楼层
之前的问题主要是任务栈小了。中断改成10ms了,延时100不就是1秒吗
GMT+8, 2026-11-4 02:56
