查看: 11219|回复: 1
linux驱动编译时提示缺少asm/types
2020-1-30
发表于 2021-4-30 16:43:41 | 显示全部楼层 |阅读模式
3金钱
原子哥 我想问一下我用vscode编译第一个linux驱动时编译出现以下问题该怎么解决(在目录下确实没有asm这个文件夹) :
book@100ask:~/lichee-pi/projects/1_chrdevbase$ make
make -C /home/book/lichee-pi/linux_kernels/linux-5.10 M=/home/book/lichee-pi/projects/1_chrdevbase modules
make[1]: Entering directory '/home/book/lichee-pi/linux_kernels/linux-5.10'
  CC [M]  /home/book/lichee-pi/projects/1_chrdevbase/chrdevbase.o
In file included from ./include/linux/types.h:6:0,
                 from /home/book/lichee-pi/projects/1_chrdevbase/chrdevbase.c:1:
./include/uapi/linux/types.h:5:10: fatal error: asm/types.h: No such file or directory
#include <asm/types.h>
compilation terminated.
scripts/Makefile.build:279: recipe for target '/home/book/lichee-pi/projects/1_chrdevbase/chrdevbase.o' failed
make[2]: *** [/home/book/lichee-pi/projects/1_chrdevbase/chrdevbase.o] Error 1
Makefile:1821: recipe for target '/home/book/lichee-pi/projects/1_chrdevbase' failed
make[1]: *** [/home/book/lichee-pi/projects/1_chrdevbase] Error 2
make[1]: Leaving directory '/home/book/lichee-pi/linux_kernels/linux-5.10'
Makefile:8: recipe for target 'kernel_modules' failed
make: *** [kernel_modules] Error 2
编译器用错了,你的应该是用的ubuntu自带的编译器了,属于x86架构的编译器,不是ARM架构的编译器,要用教程4.9.4版本的那个。 不要直接执行make,试试: 配置: make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- 后面加配置文件名 编译: make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-
888
2397
2397
2019-9-25
398 小时
发表于 2021-4-30 16:43:42 | 显示全部楼层
不要直接执行make,试试:
配置:
编译:
GMT+8, 2026-10-31 06:02
