查看: 9088|回复: 2
4.3寸RGB屏幕,GT9147,测试tslib没反应
2021-4-15
发表于 2021-5-9 13:32:46 | 显示全部楼层 |阅读模式
4.3寸的800*480的屏,用的是GT9147的驱动,按照教程第64章的内容,修改设备树和移植GT9147驱动到了内核里                pinctrl_tsc: tscgrp {
                        fsl,pins = <
                                /* 4.3寸RGB屏幕,GT9147 */
                                MX6UL_PAD_SNVS_TAMPER9__GPIO5_IO09 0x10B0 /* TSC_RST */
                                MX6UL_PAD_GPIO1_IO09__GPIO1_IO09 0x10B0 /* TSC_INT */
        gt9147:gt9147@14 {
                compatible = "goodix,gt9147", "goodix,gt9xx";
                pinctrl-names = "default";
                pinctrl-0 = <&pinctrl_tsc>;
                reg = <0x14>;
                interrupt-parent = <&gpio1>;
                interrupts = <9 0>;
                reset-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>;
                interrupt-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
                status = "okay";
启动后串口有显示:
GT9147 ID =0X3
input: gt9147 as /devices/platform/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-0014/input/input2
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
i2c /dev entries driver
按理说应该是成功了
然后无论hexdump /dev/input/event1还是event0,event2在点击屏幕是均无任何反应
咋回事,不明白了,另外,我用出厂的系统操作触摸屏时按照快速上手的方法测试时成功的
好了,原因是我只是reboot,而没有直接断电重启,断电重启后成功了
2021-4-15
 楼主| 发表于 2021-5-9 13:32:47 | 显示全部楼层
2021-4-15
 楼主| 发表于 2021-5-9 16:02:54 | 显示全部楼层
补充:以前的帖子看过,几处该屏蔽的都屏蔽了
GMT+8, 2026-10-31 07:15
