查看: 12261|回复: 6
ESP32TCP网络摄像头c#上位机esp32 camera
56
167
606
606
2013-10-18
60 小时
发表于 2021-6-17 23:17:49 | 显示全部楼层 |阅读模式
网上基本找不到可以用的ESP32 cam SDK做TCP通讯的例子,ESP8266速度达不到网络摄像头要求的速度。只能转战ESP32,自己移植camera驱动,例子基本思路
1、上位机采用C#编写,包涵普通串口功能,百度AI实时进行人脸识别
public void FaceReg(string[] args)
            // 设置APPID/AK/SK
            var API_KEY = "**************************";                   //你的 Api Key
            var SECRET_KEY = "***************************";        //你的 Secret Key
            var client = new Baidu.Aip.Face.Face(API_KEY, SECRET_KEY);
            client.Timeout = 60000;  // 修改超时时间
                                     //取决于image_type参数,传入BASE64字符串或URL字符串或FACE_TOKEN字符串
                                     //你共享的图片路径(点击路径可直接查看图片)
            //var image = "http://bj.bcebos.com/v1/aip-web/48EBCB80FF7C4DCA9E0139425B76F078?authorization=bce-auth-v1/f86a2044998643b5abc89b59158bad6d/2018-07-27T07:45:30Z/-1//07fd154d3456eea9104b7c467efc0d43aceb7609d1635246d8fdb1272b0cea30";
            //注册第1张人脸
            var value = File.ReadAllBytes("./人脸注册库/钱大大.JPG");
            string image = Convert.ToBase64String(value);
            //var imageType = "BASE64";
            //注册人脸
            var groupId = "Group1";
            var userId = "qian_xiao_ping";
            // 调用人脸注册,可能会抛出网络等异常,请使用try/catch捕获
            //var result = client.UserAdd(image, imageType, groupId, userId);
            //注册第二张人脸
            var value444 = File.ReadAllBytes("./人脸注册库/美女.JPG");
            string image444 = Convert.ToBase64String(value444);
            var userId2 = "fan_hai_hong";
          // var result1 = client.UserAdd(image444, imageType, groupId, userId2);
            //注册第3张人脸
            var value555 = File.ReadAllBytes("./人脸注册库/苏小小.JPG");
            string image555 = Convert.ToBase64String(value555);
            var userId555 = "qian_yi";
            //var result555 = client.UserAdd(image555, imageType, groupId, userId555);
            //注册第4张人脸
            var value123 = File.ReadAllBytes("./人脸注册库/小李子.JPG");
            string image123 = Convert.ToBase64String(value123);
            var userId123 = "xiao_li_zi";
            //var result666 = client.UserAdd(image123, imageType, groupId, userId123);
            // Console.WriteLine(result);
            // 如果有可选参数
            /*var options = new Dictionary<string, object>{
                        {"user_info", "user's info"},
                        {"quality_control", "NORMAL"},
                        {"liveness_control", "LOW"}
                    /*{"max_face_num", 3},
                    {"match_threshold", 70},
                    {"liveness_control", "LOW"},*/
                   // {"user_id", "user1"},
                    {"max_user_num", 1}
            // 带参数调用人脸注册
            //result = client.UserAdd(image, imageType, groupId, userId, options);
            //Console.WriteLine(result);
            //比对
            string image2 = Convert.ToBase64String(TcparrMsgRecCopy);
            /* MemoryStream ms = new MemoryStream(TcparrMsgRecCopy);//文件形式//MemoryStream ms = new MemoryStream(byDataReal);非文件形式
              ms.Position = 0;
             // image999.Save(ms, System.Drawing.Imaging.ImageFormat.Jpeg);
              JPEG_TCP = Image.FromStream(ms);
              JPEG_TCP.Save("./qxp2.jpg", System.Drawing.Imaging.ImageFormat.Jpeg);
              ms.Close();
              var value2 = File.ReadAllBytes("./qxp2.JPG");
              string image2 = Convert.ToBase64String(value2);*/
            /////////////////相似度查找/////////////////////
            var groupIdList = "Group1";
            // 调用人脸搜索,可能会抛出网络等异常,请使用try/catch捕获
            var result5 = client.Search(image2, imageType, groupIdList, options);
            // var result5 = client.MultiSearch(image2, imageType, groupIdList);
            string bbb = result5.ToString();
            int Indexofcc = bbb.IndexOf("error_code");
            int Indexofdd = bbb.IndexOf("error_msg");
            //根据索引截取
            string str20 = bbb.Substring(Indexofcc+13, 1);
            if (str20 == "0")
                try
                    this.Invoke((EventHandler)(delegate
                    //获取相似度
                    string xxx = result5.ToString();
                        int IndexofA = xxx.IndexOf("score");
                        int IndexofB = xxx.IndexOf(",");
                    //根据索引截取
                    string str = xxx.Substring(IndexofA + 8, IndexofB);
                        label12.Text = str;
                    //获取姓名
                    string yyy = result5.ToString();
                        int IndexofA1 = xxx.IndexOf("user_id");
                        int IndexofB1 = xxx.IndexOf("user_info");
                    //根据索引截取
                    string stryyy = xxx.Substring(IndexofA1 + 11, IndexofB1 - IndexofA1 - 24);
                       // label16.Text = stryyy;显示百度云平台返回的姓名
                        if (stryyy == "qian_yi")
                        //显示库中的图片
                        pictureBox2.Image = new Bitmap("./人脸注册库/钱小小.JPG");
                            pictureBox2.Refresh();
                            label16.Text = "钱小小";
                        else if (stryyy == "qian_xiao_ping")
                        //显示库中的图片
                        pictureBox2.Image = new Bitmap("./人脸注册库/钱大大.JPG");
                            label16.Text = "钱大大";
                        else if (stryyy == "fan_hai_hong")
                        //显示库中的图片
                        pictureBox2.Image = new Bitmap("./人脸注册库/美女.JPG");
                            label16.Text = "美女";
                        else if (stryyy == "xiao_li_zi")
                            //显示库中的图片
                            pictureBox2.Image = new Bitmap("./人脸注册库/小李子.JPG");
                            label16.Text = "小李子";
                        else { }
                    //label12.Text = result5.Last.First.Last.First.First.Last.ToString();
                catch
            //var result6 = client.Search(image3, imageType, groupIdList);
2、终端采用ESP32CAM模块,使用乐鑫IDF环境进行编程,移植esp32-camera驱动。采集完图像后马上进行TCP传输
目前例程还有点粗糙,共勉。
static void tcp_client_task(void *pvParameters)
    char host_ip[] = HOST_IP_ADDR;
    int addr_family = 0;
    int ip_protocol = 0;
    while (1) {
#if defined(CONFIG_EXAMPLE_IPV4)
        struct sockaddr_in dest_addr;
        dest_addr.sin_addr.s_addr = inet_addr(host_ip);
        dest_addr.sin_family = AF_INET;
        dest_addr.sin_port = htons(PORT);
        addr_family = AF_INET;
        ip_protocol = IPPROTO_IP;
#elif defined(CONFIG_EXAMPLE_IPV6)
        struct sockaddr_in6 dest_addr = { 0 };
        inet6_aton(host_ip, &dest_addr.sin6_addr);
        dest_addr.sin6_family = AF_INET6;
        dest_addr.sin6_port = htons(PORT);
        dest_addr.sin6_scope_id = esp_netif_get_netif_impl_index(EXAMPLE_INTERFACE);
        addr_family = AF_INET6;
        ip_protocol = IPPROTO_IPV6;
#elif defined(CONFIG_EXAMPLE_SOCKET_IP_INPUT_STDIN)
        ESP_ERROR_CHECK(get_addr_from_stdin(PORT, SOCK_STREAM, &ip_protocol, &addr_family, &dest_addr));
#endif
        int sock =  socket(addr_family, SOCK_STREAM, ip_protocol);
        if (sock < 0) {
            ESP_LOGE(TAG, "Unable to create socket: errno %d", errno);
            break;
        ESP_LOGI(TAG, "Socket created, connecting to %s:%d", host_ip, PORT);
        int err = connect(sock, (struct sockaddr *)&dest_addr, sizeof(struct sockaddr_in6));
        if (err != 0) {
            ESP_LOGE(TAG, "Socket unable to connect: errno %d", errno);
            break;
        ESP_LOGI(TAG, "Successfully connected");
        camera_init_app();
        while (1)
            camera_run();
           //errno=Get_dma_received_count();
           // ESP_LOGE(TAG, "Get_dma_received_count: errno %d", errno);
            errno=camera_get_data_size();
            //ESP_LOGE(TAG, "camera_get_data_size: errno %d", errno);
            fb=camera_get_fb();
            /*camera_fb_t * fb,
            typedef struct {
                                uint8_t * buf;
                                size_t len;
                                size_t width;
                                size_t height;
                                pixformat_t format;
                                struct timeval timestamp;
                            } camera_fb_t;
            if(fb!=0)
            {//50736
                    if(errno>100)
                            //int err = send(sock, payload, strlen(payload), 0);//int err = send(sock, tx_buffer_test, 50*1024, 0);  //
                            if((fb[1]==0xd8)&&(fb[0]==0xff))
                                         for(ii=0;ii<errno;ii++)//查找0XFF,0XD9
                                       if((fb[ii]==0XFF)&&(fb[ii+1]==0XD9))break;
                                      if(ii==errno)
                                                     res=1;//没找到0XFF,0XD8
                                      else  //找到了
                                            res=0;
                                                    /* errno=fb[ii];
                                                    errno=fb[ii+1];
                                                    ESP_LOGE(TAG, "Socket unable to connect: errno %d", errno);*/
                                                    ii=ii+1;
                                           /* if(res==0)
                                                int err = send(sock, fb, errno, 0);
                                                ESP_LOGI(TAG, "Send Ok!");
                                       /*    errno=fb->len;
                                        errno=(fb->buf[0]);
                                         errno=(fb->buf[1]);
                                         errno=(fb->buf[fb->len-1]);
                                         errno=(fb->buf[fb->len-2]);
                                        if(res==0)
                                            jj=ii+1;
                                            for(ii=0;ii<jj;ii++)//查找0XFF,0XD9
                                                fb_real[ii]=fb[ii];
                                                   /* errno=fb_real[jj-1];
                                                    errno=fb_real[jj-2];
                                            int err = send(sock, fb_real, jj, 0);// int err = send(sock, fb_real, errno, 0);
                                            //ESP_LOGI(TAG, "Send Ok!");
                            //esp_camera_fb_return(fb);
                    ESP_LOGI(TAG, "caputer err!");
            if (err < 0)
                ESP_LOGE(TAG, "Error occurred during sending: errno %d", errno);
                break;
             /* int len = recv(sock, rx_buffer, sizeof(rx_buffer) - 1, 0);
            // Error occurred during receiving
            if (len < 0) {
                ESP_LOGE(TAG, "recv failed: errno %d", errno);
                break;
            // Data received
            else {
                rx_buffer[len] = 0; // Null-terminate whatever we received and treat like a string
                ESP_LOGI(TAG, "Received %d bytes from %s:", len, host_ip);
                //ESP_LOGI(TAG, "%s", rx_buffer);
            vTaskDelay(10 / portTICK_PERIOD_MS);//vTaskDelay(2000 / portTICK_PERIOD_MS);
        if (sock != -1) {
            ESP_LOGE(TAG, "Shutting down socket and restarting...");
            shutdown(sock, 0);
            close(sock);
    vTaskDelete(NULL);
void LED_TASK(void);
void app_main(void)
    ESP_ERROR_CHECK(nvs_flash_init());
    ESP_ERROR_CHECK(esp_netif_init());
    ESP_ERROR_CHECK(esp_event_loop_create_default());
    /* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
     * Read "Establishing Wi-Fi or Ethernet Connection" section in
     * examples/protocols/README.md for more information about this function.
    ESP_ERROR_CHECK(example_connect());
    xTaskCreate(LED_TASK, "LED_TASK", 4096, NULL, 5, NULL);
    xTaskCreate(tcp_client_task, "tcp_client", 4096, NULL, 5, NULL);
camera_model_t camera_model;
    esp_err_t temp;
void camera_init_app(void)
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
    errno=Y2_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_d0: errno %d", errno);
  config.pin_d1 = Y3_GPIO_NUM;
      errno=Y3_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_d1: errno %d", errno);
  config.pin_d2 = Y4_GPIO_NUM;
      errno=Y4_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_d2: errno %d", errno);
  config.pin_d3 = Y5_GPIO_NUM;
      errno=Y5_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_d3: errno %d", errno);
  config.pin_d4 = Y6_GPIO_NUM;
      errno=Y6_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_d4: errno %d", errno);
  config.pin_d5 = Y7_GPIO_NUM;
      errno=Y7_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_d5: errno %d", errno);
  config.pin_d6 = Y8_GPIO_NUM;
      errno=Y8_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_d6: errno %d", errno);
  config.pin_d7 = Y9_GPIO_NUM;
      errno=Y9_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_d7: errno %d", errno);
  config.pin_xclk = XCLK_GPIO_NUM;
      errno=XCLK_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_xclk: errno %d", errno);
  config.pin_pclk = PCLK_GPIO_NUM;
      errno=PCLK_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_pclk: errno %d", errno);
  config.pin_vsync = VSYNC_GPIO_NUM;
      errno=VSYNC_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_vsync: errno %d", errno);
  config.pin_href = HREF_GPIO_NUM;
      errno=HREF_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_href: errno %d", errno);
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  errno=SIOD_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_sscb_sda: errno %d", errno);
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  errno=SIOC_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_sscb_scl: errno %d", errno);
  //config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
    errno=RESET_GPIO_NUM;
  ESP_LOGE(TAG, "Socket unable to pin_reset: errno %d", errno);
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  // if PSRAM IC present, init with UXGA resolution and higher JPEG quality
  //                      for larger pre-allocated frame buffer.
     config.frame_size = FRAMESIZE_QQVGA;
   config.jpeg_quality = 4;// config.jpeg_quality = 12;
    //config.fb_count = 1;
    // camera init
ESP_LOGE(TAG, "aaa1");
     temp=camera_probe(&config, &camera_model);
     ESP_LOGE(TAG, "bbb");
    if (temp != ESP_OK)
        ESP_LOGE(TAG, "Camera probe err: errno %d", errno);// ESP_LOGE(TAG, "Camera init failed with err");//Serial.printf("Camera init failed with error 0x%x", err);
        return;
    if(camera_model == 2640)
    //实际改图像改这里就行
    config.frame_size = FRAMESIZE_CIF;//config.frame_size = FRAMESIZE_SVGA;FRAMESIZE_QVGA
         ESP_LOGE(TAG, "Camera not support");
  esp_err_t err = camera_init(&config);
  if (err != ESP_OK) {
    errno=err;
    ESP_LOGE(TAG, "Camera init failed: errno %d", errno);// ESP_LOGE(TAG, "Camera init failed with err");//Serial.printf("Camera init failed with error 0x%x", err);
    return;
  // s->set_framesize(s, FRAMESIZE_QVGA);
    // startCameraServer();
     ESP_LOGE(TAG, "Camera Ready! Use 'http://");//Serial.print("Camera Ready! Use 'http://");
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
  } else {
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  // camera init
    return;
  //sensor_t * s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1); // flip it back
    s->set_brightness(s, 1); // up the brightness just a bit
    s->set_saturation(s, -2); // lower the saturation
  // drop down frame size for higher initial frame rate
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
#endif
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");*/
#define BLINK_GPIO 33
  #define BLINK_GPIO1 26
   #define BLINK_GPIO2 27
   unsigned char temp111=0;
void LED_TASK(void)
    /* Configure the IOMUX register for pad BLINK_GPIO (some pads are
       muxed to GPIO on reset already, but some default to other
       functions and need to be switched to GPIO. Consult the
       Technical Reference for a list of pads and their default
       functions.)
    gpio_pad_select_gpio(BLINK_GPIO);
  //  gpio_pad_select_gpio(BLINK_GPIO1);
   // gpio_pad_select_gpio(BLINK_GPIO2);
    /* Set the GPIO as a push/pull output */
    gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
  //  gpio_set_direction(BLINK_GPIO1, GPIO_MODE_OUTPUT);
   // gpio_set_direction(BLINK_GPIO2, GPIO_MODE_OUTPUT);
    while(1) {
        /* Blink off (output low) */
       /* if(temp111<=5)
        temp111++;
        gpio_set_level(BLINK_GPIO, 0);
      //  gpio_set_level(BLINK_GPIO1, 0);
       // gpio_set_level(BLINK_GPIO2, 0);
       //  digitalWrite(27, 0);
        vTaskDelay(1000 / portTICK_PERIOD_MS);
        /* Blink on (output high) */
        gpio_set_level(BLINK_GPIO, 1);
       // gpio_set_level(BLINK_GPIO1, 1);
        //gpio_set_level(BLINK_GPIO2, 1);
         //digitalWrite(27, 1);
视频详见抖音号:202937710
367
4248
4248
2020-7-24
715 小时
发表于 2021-6-18 16:34:54 | 显示全部楼层
感谢分享
2021-7-16
发表于 2021-8-12 11:34:22 | 显示全部楼层
你好,可以分享一下上位机接收图片数据并变成视频的源码吗?
2021-8-28
发表于 2021-8-28 09:45:52 | 显示全部楼层
56
167
606
606
2013-10-18
60 小时
 楼主| 发表于 2022-6-29 17:34:02 | 显示全部楼层
胡骐麟 发表于 2021-8-28 09:45
您好博主,请问速率怎么样呢
大概6FPS
29
3529
3529
2020-5-24
230 小时
发表于 2023-6-17 07:17:32 | 显示全部楼层
感谢分享
2025-4-17
发表于 2025-5-31 18:09:54 | 显示全部楼层
感谢分享
GMT+8, 2026-10-31 04:26
