查看: 12967|回复: 9
[XILINX] ZYNQ7010 与DAC采用SPI通信,仿真没有问题,但上板后没有输出时钟
2021-3-5
发表于 2021-7-11 16:23:57 | 显示全部楼层 |阅读模式
10金钱
ZYNQ7010 与DAC采用SPI通信,仿真没有问题,但上板后没有输出时钟,有没有哪位大佬可以解决一下,万分感谢!!!
屏幕截图 2021-07-11 151636.png 屏幕截图 2021-07-11 161559.png 顶层模块`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 2021/07/10 23:43:50
// Design Name:
// Module Name: DAC_test
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
//顶层模块
module DAC_test(
                        Clk,   //模块时钟50M
                        Rst_n, //模块复位
                        DAC_CS_N,  //TLV5618的CS_N接口
                        DAC_DIN,   //TLV5618的DIN接口
                        DAC_SCLK   //TLV5618的SCLK接口
        input Clk;
        input Rst_n;
        output DAC_CS_N;
        output DAC_DIN;
        output DAC_SCLK;
        reg Start;
        reg [15:0]r_DAC_DATA;
        wire DAC_State;
        wire [15:0]DAC_DATA;
        wire Set_Done;
        tlv5618 tlv5618(
                .Clk(Clk),
                .Rst_n(Rst_n),
                .DAC_DATA(DAC_DATA),
                .Start(Start),
                .Set_Done(Set_Done),
                .DAC_CS_N(DAC_CS_N),
                .DAC_DIN(DAC_DIN),
                .DAC_SCLK(DAC_SCLK),
                .DAC_State(DAC_State)
        ila_0 your_instance_name (
        .clk(Clk), // input wire clk
        .probe0(Rst_n), // input wire [0:0]  probe0
        .probe1(DAC_CS_N), // input wire [0:0]  probe1
        .probe2(DAC_DIN), // input wire [0:0]  probe2
        .probe3(DAC_SCLK) // input wire [0:0]  probe3
        always@(posedge Clk or negedge Rst_n)
        if(!Rst_n)
                r_DAC_DATA <= 16'd0;
        else if(DAC_State)
                r_DAC_DATA <= DAC_DATA;
        if(!Rst_n)
                Start <= 1'd0;
        else if(r_DAC_DATA != DAC_DATA)
                Start <= 1'b1;
                Start <= 1'd0;
endmodule
// 驱动部分
module tlv5618(
        Clk,
        Rst_n,
        DAC_DATA,        //并行数据输入端
        Start,                //开始标志位
        Set_Done,        //完成标志位
        DAC_CS_N,        //片选
        DAC_DIN,        //串行数据送给ADC芯片
        DAC_SCLK,        //工作时钟SCLK
        DAC_State        //工作状态
        parameter fCLK = 50;                //时钟参数
        parameter DIV_PARAM = 2;        //分频参数
        input Clk;
        input Rst_n;
        input [15:0] DAC_DATA;
        input Start;
        output reg Set_Done;
        output reg DAC_CS_N;
        output reg DAC_DIN;
        output reg DAC_SCLK;
        output DAC_State;
        assign DAC_State = DAC_CS_N;        //工作状态标志与片选信号相同
        reg [15:0] r_DAC_DATA;
        reg [3:0] DIV_CNT;                //分频计数器
        reg SCLK2X;                                //2倍SCLK的采样时钟
        reg [5:0] SCLK_GEN_CNT;        //SCLK生成暨序列机计数器
        reg en;                                        //转换使能信号
        wire trans_done;                 //转换序列完成标志信号
        if(!Rst_n)
                en <= 1'b0;
        else if(Start)
                en <= 1'b1;
        else if(trans_done)
                en <= 1'b0;        //转换完成后将使能关闭
                en <= en;
        //分频计数器
        if(!Rst_n)
                DIV_CNT <= 4'd0;
        else if(en)begin
                if(DIV_CNT == (DIV_PARAM - 1'b1))        //前面设置了分频系数为2,这里计数器能够容纳2拍时钟脉冲
                        DIV_CNT <= 4'd0;
                        DIV_CNT <= DIV_CNT + 1'b1;
                end
                DIV_CNT <= 4'd0;
        //二分频
        if(!Rst_n)
                SCLK2X <= 1'b0;
        else if(en && (DIV_CNT == (DIV_PARAM - 1'b1)))
                SCLK2X <= 1'b1;
                SCLK2X <= 1'b0;
        //生成序列计数器,对SCLK脉冲进行计数
        if(!Rst_n)
                SCLK_GEN_CNT <= 6'd0;
        else if(SCLK2X && en)begin        //在高脉冲期间,累计拍数
                if(SCLK_GEN_CNT == 6'd33)
                        SCLK_GEN_CNT <= SCLK_GEN_CNT + 1'd1;
                end
                SCLK_GEN_CNT <= SCLK_GEN_CNT;
        if(!Rst_n)
        else if(Start)        //收到开始发送命令时,寄存DAC_DATA值
                r_DAC_DATA <= r_DAC_DATA;
        //依次将数据移出到DAC芯片
        if(!Rst_n)begin
                DAC_DIN <= 1'b1;
                DAC_SCLK <= 1'b0;
                DAC_CS_N <= 1'b1;
                end
        else if(!Set_Done && SCLK2X) begin
                case(SCLK_GEN_CNT)
                        0:
                                begin        //高脉冲期间内,计数为0时了,打开片选使能,给予时钟上升沿,将最高位数据送给ADC芯片
                                        DAC_CS_N <= 1'b0;
                                        DAC_DIN <= r_DAC_DATA[15];
                                        DAC_SCLK <= 1'b1;
                                end
                        1,3,5,7,9,11,13,15,17,19,21,23,25,27,29,31:
                                begin
                                        DAC_SCLK <= 1'b0;        //时钟低电平
                                end
                        2:  begin DAC_DIN <= r_DAC_DATA[14]; DAC_SCLK <= 1'b1; end
                        4:  begin DAC_DIN <= r_DAC_DATA[13]; DAC_SCLK <= 1'b1; end
                        6:  begin DAC_DIN <= r_DAC_DATA[12]; DAC_SCLK <= 1'b1; end
                        8:  begin DAC_DIN <= r_DAC_DATA[11]; DAC_SCLK <= 1'b1; end
                        10: begin DAC_DIN <= r_DAC_DATA[10]; DAC_SCLK <= 1'b1; end
                        12: begin DAC_DIN <= r_DAC_DATA[9];  DAC_SCLK <= 1'b1; end
                        14: begin DAC_DIN <= r_DAC_DATA[8];  DAC_SCLK <= 1'b1; end
                        16: begin DAC_DIN <= r_DAC_DATA[7];  DAC_SCLK <= 1'b1; end
                        18: begin DAC_DIN <= r_DAC_DATA[6];  DAC_SCLK <= 1'b1; end
                        20: begin DAC_DIN <= r_DAC_DATA[5];  DAC_SCLK <= 1'b1; end
                        22: begin DAC_DIN <= r_DAC_DATA[4];  DAC_SCLK <= 1'b1; end
                        24: begin DAC_DIN <= r_DAC_DATA[3];  DAC_SCLK <= 1'b1; end
                        26: begin DAC_DIN <= r_DAC_DATA[2];  DAC_SCLK <= 1'b1; end
                        28: begin DAC_DIN <= r_DAC_DATA[1];  DAC_SCLK <= 1'b1; end
                        30: begin DAC_DIN <= r_DAC_DATA[0];  DAC_SCLK <= 1'b1; end
                        32: DAC_SCLK <= 1'b1;         //时钟拉高
                        33: DAC_CS_N <= 1'b1;        //关闭片选
                        default:;
                endcase
        end
        assign trans_done = (SCLK_GEN_CNT == 33) && SCLK2X;
        if(!Rst_n)
                Set_Done <= 1'b0;
        else if(trans_done)
                Set_Done <= 1'b1;
                Set_Done <= 1'b0;
endmodule
检查下是不是模块输入的时钟,或者复位信号有问题
2217
6430
6430
2018-10-21
1907 小时
发表于 2021-7-11 16:23:58 | 显示全部楼层
2217
6430
6430
2018-10-21
1907 小时
发表于 2021-7-13 08:59:31 | 显示全部楼层
ILA和ISIM里面看到的信号,是同一个模块里面的吗
2021-3-5
 楼主| 发表于 2021-7-13 16:49:44 | 显示全部楼层
2021-3-5
 楼主| 发表于 2021-7-16 10:55:58 | 显示全部楼层
大佬,找到问题了,是时钟的问题,谢谢了
2022-4-15
发表于 2022-4-15 17:28:19 | 显示全部楼层
请问大佬输出引脚如何绑定的?
2217
6430
6430
2018-10-21
1907 小时
发表于 2022-4-16 09:27:36 | 显示全部楼层
20220415 发表于 2022-4-15 17:28
请问大佬输出引脚如何绑定的?
你是说管脚分配?
2022-4-15
发表于 2022-4-16 12:42:43 | 显示全部楼层
QinQZ 发表于 2022-4-16 09:27
你是说管脚分配?
对,我不知道管脚怎么分配,SPI的引脚没找到
2217
6430
6430
2018-10-21
1907 小时
发表于 2022-4-16 13:57:15 | 显示全部楼层
要看原理图,你是用的什么板子?一般有提供管脚分配Excel表格的
2022-4-15
发表于 2022-4-16 22:12:49 | 显示全部楼层
我用的ZYNQ7020,论坛回复太慢了,要不大佬加我Q聊吧:2747547991。
GMT+8, 2026-10-25 08:43
