查看: 8964|回复: 2
探索者f4,串口4(uart4)能接收,不能发送
2021-7-13
发表于 2021-7-13 11:26:30 | 显示全部楼层 |阅读模式
STM32F407ZET6芯片,在串口通信实验的基础上增加UART4,但是UART4能够收到数据,不能正常发出数据。相关代码如下:
①初始化部分:
UART_HandleTypeDef UART4_Handler; //UART4句柄
//初始化IO 串口4
//bound:波特率
void uart4_init(u32 bound)
        //UART 初始化设置
        UART4_Handler.Instance=UART4;                                            //USART1
        UART4_Handler.Init.BaudRate=bound;                                    //波特率
        UART4_Handler.Init.WordLength=UART_WORDLENGTH_8B;   //字长为8位数据格式
        UART4_Handler.Init.StopBits=UART_STOPBITS_1;            //一个停止位
        UART4_Handler.Init.Parity=UART_PARITY_NONE;                    //无奇偶校验位
        UART4_Handler.Init.HwFlowCtl=UART_HWCONTROL_NONE;   //无硬件流控
        UART4_Handler.Init.Mode=UART_MODE_TX_RX;                    //收发模式
        UART4_Handler.Init.OverSampling = UART_OVERSAMPLING_16;//过采样设置
        HAL_UART_Init(&UART4_Handler);                                            //HAL_UART_Init()会使能UART4
        HAL_UART_Receive_IT(&UART4_Handler, (u8 *)&aRxBuffer4, RXBUFFERSIZE);//该函数会开启接收中断:标志位UART_IT_RXNE,并且设置接收缓冲以及接收缓冲接收最大数据量
void HAL_UART_MspInit(UART_HandleTypeDef *huart)
    //GPIO端口设置
        GPIO_InitTypeDef GPIO_Initure;
        if(huart->Instance==USART1)//如果是串口1,进行串口1 MSP初始化
                //省略串口1的初始化
        if(huart->Instance==UART4)//如果是串口1,进行串口1 MSP初始化
                __HAL_RCC_GPIOA_CLK_ENABLE();                        //使能GPIOA时钟
                __HAL_RCC_UART4_CLK_ENABLE();                        //使能UART4时钟
                GPIO_Initure.Pin=GPIO_PIN_0;                        //PA0
                GPIO_Initure.Mode=GPIO_MODE_AF_PP;                //复用推挽输出
                GPIO_Initure.Pull=GPIO_PULLUP;                        //上拉
                GPIO_Initure.Speed=GPIO_SPEED_FAST;                //高速
                GPIO_Initure.Alternate=GPIO_AF8_UART4;        //复用为UART4
                HAL_GPIO_Init(GPIOA,&GPIO_Initure);                   //初始化PA0
                GPIO_Initure.Pin=GPIO_PIN_1;                        //PA1
                HAL_GPIO_Init(GPIOA,&GPIO_Initure);                   //初始化PA1
#if EN_UART4_RX
                HAL_NVIC_EnableIRQ(UART4_IRQn);                                //使能UART4中断通道
                HAL_NVIC_SetPriority(UART4_IRQn,3,2);                        //抢占优先级3,子优先级2
#endif
②主函数部分
uint8_t CMD4[3]={0xF6,0x01,0xA0};
int main(void)
        LED0 = 1;
    HAL_Init();                            //初始化HAL库
    Stm32_Clock_Init(168,4,2,4);          //设置时钟,168Mhz
        delay_init(168);                       //初始化延时函数
        uart_init(115200);              //初始化USART
        uart4_init(115200);              //初始化UART4
        LED_Init();                                                //初始化LED
    KEY_Init();                     //初始化按键
                HAL_UART_Transmit(&UART4_Handler,(uint8_t*)CMD4,3,0xffff);
                if(startflag ==1)
        startflag =0;
                  LED0 = ~ LED0;
          delay_ms(500);
串口收到PC端发来的数据可以使LED灯亮或灭,但是无法使用HAL_UART_Transmit()发出数据。(串口1是可以正常使用的)。
参考一下这个帖子 https://www.openedv.com/forum.php?mod=viewthread&tid=282924
367
4248
4248
2020-7-24
715 小时
发表于 2021-7-13 11:26:31 | 显示全部楼层
2024-10-23
发表于 2025-3-24 10:01:50 | 显示全部楼层
不要用UART4资源,因为探索者的UART4复用的PA1引脚接了PHY模块,那个TXC一直在发数据,前几天用探索者做原型验证的时候也遇到了这个问题,调试的时候看了下发现串口一直在中断触发崩溃了都,在站内一直没找到问题,也没往那方向去想。改了下Reset信号发现没能关掉TXC,不知道是不是我哪里写的有问题,但是暂时没空试
GMT+8, 2026-10-31 06:21
