查看: 10326|回复: 5
[XILINX] zynq7020 uboot无法跳转到linux
85
303
303
2015-9-2
83 小时
发表于 2021-9-3 08:43:44 | 显示全部楼层 |阅读模式
9金钱
根据文档,使用petalinux打包了一个最小系统,将BOOT.BIN 和 image.ug文件都复制到sd卡的FAT32分区。
启动信息打印如下:
Board: Xilinx Zynq
Silicon: v3.1
I2C:   ready
DRAM:  ECC disabled 1 GiB
MMC:   sdhci_transfer_data: Error detected in status(0x208000)!
mmc@e0100000: 0 (SD), mmc@e0101000: 1 (eMMC)
SF: Detected w25q256 with page size 256 Bytes, erase size 4 KiB, total 32 MiB
In:    serial@e0000000
Out:   serial@e0000000
Err:   serial@e0000000
Net:   ZYNQ GEM: e000b000, phyaddr ffffffff, interface rgmii-id
eth0: ethernet@e000b000
## Error: "open_led" not defined
Device: mmc@e0100000
Manufacturer ID: 2
OEM: 544d
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.4 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
** Unable to read file uEnv.txt **
Copying Linux from SD to RAM...
** Unable to read file uImage **
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
starting USB...
USB0:   USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
ethernet@e000b000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.100.100 (257 ms)
*** Warning: no boot file name; using 'C0A86464.img'
Using ethernet@e000b000 device
TFTP from server 0.0.0.0; our IP address is 192.168.100.100; sending through gateway 192.168.100.254
Filename 'C0A86464.img'.
Load address: 0x0
Loading: *
TFTP error: 'File Not Found D:\ManageEngine\OpManager\tftp_files\C0A86464.img' (1)
Not retrying...
missing environment variable: pxefile_addr_r
BOOTP broadcast 1
DHCP client bound to address 192.168.100.100 (6 ms)
Filename 'boot.scr.uimg'.
Load address: 0x0
Loading: *
TFTP error: 'File Not Found D:\ManageEngine\OpManager\tftp_files\boot.scr.uimg' (1)
Not retrying...
BOOTP broadcast 1
Load address: 0x0
Loading: *
Not retrying...
不知是否因为上文标红处导致无法跳转,如果是,为什么会找不到这个文件呢?
70
275
275
2018-10-22
35 小时
发表于 2021-9-3 13:37:13 | 显示全部楼层
petalinux使用的是什么版本的呢
70
275
275
2018-10-22
35 小时
发表于 2021-9-3 13:37:50 | 显示全部楼层
petalinux使用的是什么版本的呢, 做的哪个例程呢
85
303
303
2015-9-2
83 小时
 楼主| 发表于 2021-9-3 23:17:47 | 显示全部楼层
85
303
303
2015-9-2
83 小时
 楼主| 发表于 2021-9-6 09:01:55 | 显示全部楼层
setenv bootcmd ' mmcinfo && fatload mmc 0 0x10000000 image.ub; bootm 0x10000000;'
重新指定bootcmd后,可以进入linux。
不知为什么,恢复默认环境变量不行。
70
275
275
2018-10-22
35 小时
发表于 2021-9-10 09:26:26 | 显示全部楼层
贴一下完整的打印信息吧
GMT+8, 2026-10-26 10:46
