查看: 10126|回复: 14
12864显示中文,字母,数字,符号
36
89
89
2014-3-23
发表于 2014-5-15 15:42:33 | 显示全部楼层 |阅读模式
12864显示中文,字母,数字,符号,激情献上
12864显示中文,字母,数字,符号.zip
41.9 KB, 下载次数: 1296
当你找到你的目标之后,保持好奇心和坚持,就是你剩下来要做的事情了。
56
1237
2657
2657
2014-2-13
521 小时
发表于 2014-5-15 23:35:07 | 显示全部楼层
感谢LZ分享
36
89
89
2014-3-23
 楼主| 发表于 2014-5-16 12:05:44 | 显示全部楼层
回复【2楼】回复【2楼】黑夜之狼:
共同进步O(∩_∩)O
56
1237
2657
2657
2014-2-13
521 小时
发表于 2014-5-16 13:25:30 | 显示全部楼层
技术交流,Sell 中颖单片机,欢迎私信骚扰
40
40
2014-4-25
发表于 2014-5-19 16:20:33 | 显示全部楼层
楼主帮我看一下,这段程序可以用12864显示不
#include "main.h"
#include "lcd.h"
#include <stdio.h>
#include "HX711.h"
unsigned char buf[20];
unsigned long HX711_Buffer = 0;
unsigned int Weight_Maopi = 0,Weight_Shiwu = 0; //   Weight_Shiwu????
float Weight,Price,FMoney;
char rice_Count = 0;  //×???
unsigned char KEY_NUM = 0;
unsigned char rice_Buffer[3] = {0x00,0x00,0x00};
unsigned long Money = 0;
bit Flag_OK = 0;
void main()
init_lcd(); //??????LCD
WriteString( 2, 0 ,"Welcome to use!") ;
write_com(0x80); //?????è??
WriteStr("Welcome to use! "); //???ú??????????
delayms(2000);  //???±2s
delayms(2000);
delayms(2000);
 ClrSreen();
looprice_Count = 0;
Price_Buffer[0] = 0;
Price_Buffer[1] = 0;
Price_Buffer[2] = 0;
Flag_OK = 0;
WriteString(  1 ,0,"??????0.000KG    ") ;
WriteString(  2,0 ,"????:  . ??")  ;
WriteString( 3  ,0,"×?????   . ??") ;
WriteString( 4,0,  "??????????") ;
WriteStr("+WEI |PRI | MON ");
write_com(0x80+0x40); //?????è??
WriteStr("0.000|  . |   . ");
Get_Maopi(); //?????¤????
if( Flag_OK == 0)
Get_Weight(); //????
    write_com(0x80+3);
write_data(Weight_Shiwu/1000 + 0x30);
write_data('.');
write_data(Weight_Shiwu%1000/100 + 0x30);
write_data(Weight_Shiwu%100/10 + 0x30);
write_data(Weight_Shiwu%10 + 0x30);
write_data('.');
KEY_NUM = KEY_Scan();
if( KEY_NUM != 0x55) //?±·??????????????±?ò???·??°??ü°?????
if(KEY_NUM == 16) //??×?A?ü?????¤????
Get_Maopi(); //???¤
if(KEY_NUM == 15) //??×?B?ü?????ü??????????
goto loop;
if(KEY_NUM == 12) //??×?C?????????í?ó?±·?????????
Price_Count--;
if( rice_Count < 0)
Price_Count = 0;
Price_Buffer[Price_Count] = 0;    //????????????????????
switch(Price_Count)
case 0:
write_com(0x90+3);
write_data(' ');
break;
case 1:
write_com(0x80+3);
write_data(0x20);//
write_data(' ');
break;
case 2:
write_com(0x80+4);
write_data('.');
write_data(' ');
break;
default: break;
if(KEY_NUM == 13) //??×?D?ü??????×???
Money = rice_Buffer[0] * 100 + rice_Buffer[1] * 10 + rice_Buffer[2];
Money = Money * Weight_Shiwu / 1000;
write_com(0x88+3);
write_data(Money/1000 + 0x30);
write_data(Money%1000/100 + 0x30);
write_data(Money%100/10 + 0x30);
write_data('.');
write_data(Money%10 + 0x30);
write_com(0x80+0x40+11);
write_data('.');
Flag_OK = 1;
if(KEY_NUM >= 0 && KEY_NUM <= 9)   //????????????????
Price_Buffer[Price_Count] = KEY_NUM;
switch(Price_Count)
case 0:
write_com(0x90+3);
write_data(Price_Buffer[0] + 0x30);
write_com(0x80+0x40+6);
break;
case 1:
write_com(0x90+3);
write_data(0x20);//
write_data(Price_Buffer[1] + 0x30);
write_com(0x80+0x40+7);
break;
case 2:
write_com(0x90+4);
write_data('.');//
write_data(Price_Buffer[2] + 0x30);
write_com(0x80+0x40+9);
break;
default: break;
Price_Count++;
if( rice_Count >= 3)
Price_Count = 3;
//???ó?ü???¨?è
unsigned char KEY_Scan()
unsigned char temp = 0;
unsigned char com = 0x55 , com1 = 0 , com2 = 0;
P3=0xf0;
if(P3!=0xf0)
com1=P3;
P3=0x0f;
com2=P3;
P3=0xf0;
    while(P3!=0xf0);
temp=com1|com2;
if(temp==0xee)com=1;//??×?1
if(temp==0xed)com=4;//??×?4
if(temp==0xeb)com=7;//??×?7
if(temp==0xe7)com=11;//±????ü*???ü
if(temp==0xd7)com=0;//??×?0
if(temp==0xb7)com=14;//±????ü*???ü
if(temp==0xde)com=2; //??×?2
if(temp==0xdd)com=5; //??×?5
if(temp==0xdb)com=8;//??×?8
if(temp==0xbe)com=3;//??×?3
if(temp==0xbd)com=6; //??×?6
if(temp==0xbb)com=9;//??×?9
if(temp==0x7e)com=16;//??×?A?ü?????¤????
if(temp==0x7d)com=15;//??×?B?ü?????ü??????????
if(temp==0x7b)com=12;//??×?C?????????í?ó?±·?????????
if(temp==0x77)com=13;//??×?D?ü??????×???
return(com);
void Get_Weight()
HX711_Buffer = HX711_Read();
HX711_Buffer = HX711_Buffer/100;
if(HX711_Buffer > Weight_Maopi)
Weight_Shiwu = HX711_Buffer;
Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //??????????AD???ù??????
Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/4.22+0.05);  //??????????????????
//?ò?????????????÷?????ú???????ù???ò???????????????÷?è????????????4.30??????????
//?±·????????????????????ó?±??????????????
//????????°???4.0-5.0???????ò?????÷???????¨??
//+0.05?????????á????°?·???
Buzzer = 1; //??±???±¨
else if(HX711_Buffer < Weight_Maopi - 30)
Buzzer = 0; //??????±¨??
else if(HX711_Buffer > Weight_Maopi + 24970) //?ó??5Kg??×??ó??????±¨??
Buzzer = 0;
void Get_Maopi()
Weight_Maopi = HX711_Buffer/100;
//MS???±????(12M?§????????)
void Delay_ms(unsigned int n)
unsigned int  i,j;
for(i=0;i<n;i++)
for(j=0;j<123;j++);>
40
40
2014-4-25
发表于 2014-5-19 16:25:10 | 显示全部楼层
回复【5楼】我灬是菜鸟:
以下附上LCD.c
void delayms(uint z) //???± z ms
uint i;
uchar j;
for(i=z;i>0;i--)
for(j=110;j>0;j--);
void delays(unsigned char j)
   unsigned char k;
   unsigned int i;
   for(;j>0;j--)
     for(i=1250;i>0;i--)
       for(k=180;k>0;k--);
void write_com(uchar a) //???ü??
E=0;RS=0;RW=0;
E=1;
P0=a;
delayms(10);           //???± 5ms
E=0;
void write_data(uchar b) //??????
    E=0;RS=1;RW=0;
E=1;
P0=b;
E=0;
void init_lcd()      //??????
write_com(0x01);  //????
write_com(0x30);  //?????è??
write_com(0x0c);  //??/???????è??
write_com(0x06);   //????·????è??
write_com(0x14);   //??±ê????
void ClrSreen()
void LCD_set_xy(  unsigned char x,unsigned char y)
    unsigned char address;
switch(x)
case 0: address = 0x80 + y; break;
     case 1: address = 0x80 + y; break;
case 2: address = 0x90 + y; break;
      case 3: address = 0x88 + y; break;
case 4: address = 0x98 + y; break;
default:address = 0x80 + y; break;
    write_com(address);
  void WriteString(  unsigned char x,unsigned char y ,unsigned char *s)   //????×?·???????????
unsigned char ByteNum=0;
 LCD_set_xy(x,y );
   while (*s)
if(*s<0xa0)
    ByteNum++;
write_data(*s++);
   if(*s>=0xa0)
    if(ByteNum%2==0)
write_data(*s++);
write_data(*s++);
write_data(0x20);
write_data(*s++);
write_data(*s++);
 ByteNum=0;
   ByteNum=0;
void WriteStr(unsigned char *s)
while(*s>0)
write_data(*s);
s++;
36
89
89
2014-3-23
 楼主| 发表于 2014-5-19 17:05:22 | 显示全部楼层
你 粘贴上去的程序语句的注释都乱码了!!!你看一下我分享的程序,然后再搜索一下12864的中文资料对着看一下吧~~楼主正在练级,,,在我没有成为大神之前,不敢误人子弟,呵呵呵。我也是搜索大神的程序,然后改成适合自己用的程序而已~~
36
89
89
2014-3-23
 楼主| 发表于 2014-5-19 17:05:45 | 显示全部楼层
回复【5楼】我灬是菜鸟:
发表于 2014-5-19 22:47:34 | 显示全部楼层
谢谢分享...
43
278
621
621
2013-12-27
发表于 2014-5-19 22:52:30 | 显示全部楼层
无图无真相。
水的比较多。
36
89
89
2014-3-23
 楼主| 发表于 2014-5-20 12:24:55 | 显示全部楼层
回复【10楼】青苹果PAD:
我完全没有理由去忽悠你啊,忽悠你,我会有什么好处吗?
36
89
89
2014-3-23
 楼主| 发表于 2014-5-20 12:25:14 | 显示全部楼层
回复【9楼】正点原子:
O(∩_∩)O
43
278
621
621
2013-12-27
发表于 2014-5-21 08:42:42 | 显示全部楼层
没有那意思了,我喜欢LCD的显示,好看,如果有图片就好了。
水的比较多。
36
89
89
2014-3-23
 楼主| 发表于 2014-5-21 12:07:01 | 显示全部楼层
回复【13楼】青苹果PAD:
不好意思,误会你了,下次改进(给图给真相)O(∩_∩)O
43
278
621
621
2013-12-27
发表于 2014-5-21 14:47:09 | 显示全部楼层
水的比较多。
GMT+8, 2026-11-1 10:34
