查看: 6867|回复: 1
各位大佬,dma双缓冲数据填补错误是怎么回事
2020-11-3
发表于 2021-9-25 14:55:48 | 显示全部楼层 |阅读模式
dma的配置(是内存到I2S数据寄存器的方式)
hdma_spi3_tx.Instance = DMA1_Stream5;
hdma_spi3_tx.Init.Channel = DMA_CHANNEL_0;
hdma_spi3_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
hdma_spi3_tx.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_spi3_tx.Init.MemInc = DMA_MINC_ENABLE;
hdma_spi3_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
hdma_spi3_tx.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
hdma_spi3_tx.Init.Mode = DMA_CIRCULAR;
hdma_spi3_tx.Init.Priority = DMA_PRIORITY_LOW;
hdma_spi3_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
hdma_spi3_tx.Init.MemBurst = DMA_MBURST_SINGLE;
hdma_spi3_tx.Init.PeriphBurst = DMA_PBURST_SINGLE;
中断处理函数内容:
void DMA1_Stream5_IRQHandler(void)
        rollback();
        UBaseType_t uxSavedInterruptStatus;
        static uint32_t count = 2;
        BaseType_t xHigherPriorityTaskWoken;
        xHigherPriorityTaskWoken = pdFALSE;
        uxSavedInterruptStatus = pdFALSE;
        xSemaphoreTakeFromISR(isrSwitchTaskSem,&xHigherPriorityTaskWoken);
        if(__HAL_DMA_GET_FLAG(&hdma_spi3_tx,DMA_FLAG_TCIF1_5)!=RESET) //DMA传输完成
                        __HAL_DMA_CLEAR_FLAG(&hdma_spi3_tx,DMA_FLAG_TCIF1_5);     //清除DMA传输完成中断标志位
                       if(DMA1_Stream5->CR&(1<<19)) //填数据buf1
                                printf("2\r\n");
                                uxSavedInterruptStatus =          taskENTER_CRITICAL_FROM_ISR();
                                if(count%3 == 0)
                                        //wav_pack1_buf = recvpack2;
                                        for(int i = 0 ; i<(WAV_BUF_SIZE/2) ;i++)
                                                wav_pack1_buf[i] = audio1khz[i];
                                        count++;
                                else if(count%3 == 1)
                                        //wav_pack1_buf = recvpack3;
                                        count++;
                                else if(count%3 == 2)
                                        //wav_pack1_buf = recvpack4;
                                                wav_pack1_buf[i] =audio1khz[i];
                                        count++;
                                taskEXIT_CRITICAL_FROM_ISR(uxSavedInterruptStatus);
                        else //buf2
                                printf("3\r\n");
                                        if(count%3 == 0)
                                                //wav_pack2_buf = recvpack2;
                                                        wav_pack2_buf[i] = audio1khz[i];
                                                count++;
                                                //wav_pack2_buf = recvpack3;
                                                count++;
                                                //wav_pack2_buf = recvpack4;
                                                count++;
                        //taskEXIT_CRITICAL_FROM_ISR(uxSavedInterruptStatus);
        portYIELD_FROM_ISR( xHigherPriorityTaskWoken );
2020-11-3
 楼主| 发表于 2021-9-25 15:00:05 | 显示全部楼层
这是波形图,正确应该是都是正弦波
GMT+8, 2026-10-31 05:45
