查看: 1604|回复: 0
uboot 下修改环境变量中设备树名称重启失效
2021-9-25
发表于 2021-9-25 23:47:03 | 显示全部楼层 |阅读模式
emmc版本,将imx6ull-alientek-emmc.dtb文件拷贝至/run/media/mmcblk1p1目录下,修改uboot下环境变量,saveenv正常查看环境变量已修改,可以boot启动,但是重启后环境变量中的设备树文件恢复为imx6ull-14x14-emmc-7-1024x600-c.dtb。
=> pri
baudrate=115200
board_name=EVK
board_rev=14X14
boot_fdt=try
bootcmd=run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi
bootcmd_mfg=run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
bootdelay=1
bootscript=echo Running bootscript from mmc ...; source
console=ttymxc0
ethact=FEC1
ethaddr=00:04:9f:04:d2:35
ethprime=FEC
fdt_addr=0x83000000
fdt_file=imx6ull-14x14-emmc-7-1024x600-c.dtb
fdt_high=0xffffffff
findfdt=if test $fdt_file = undefined; then if test $board_name = EVK && test $board_rev = 9X9; then setenv fdt_file imx6ull-9x9-evk.dtb; fi; if test $board_name = EVK && test $board_rev = 14X14; then setenv fdt_file imx6ull-14x14-evk.dtb; fi; if test $fdt_file = undefined; then echo WARNING: Could not determine dtb to use; fi; fi;
gatewayip=192.168.1.1
image=zImage
initrd_addr=0x83800000
initrd_high=0xffffffff
ip_dyn=yes
ipaddr=192.168.1.118
loadaddr=0x80800000
loadbootscript=fatload mmc ${mmcdev}{mmcpart} ${loadaddr} ${script};
loadfdt=fatload mmc ${mmcdev}{mmcpart} ${fdt_addr} ${fdt_file}
loadimage=fatload mmc ${mmcdev}{mmcpart} ${loadaddr} ${image}
mfgtool_args=setenv bootargs console=${console},${baudrate} rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.file=/fat g_mass_storage.ro=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber="" clk_ignore_unused
mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot}
mmcautodetect=yes
mmcboot=echo Booting from mmc ...; run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
mmcdev=1
mmcpart=1
mmcroot=/dev/mmcblk1p2 rootwait rw
netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ip=dhcp nfsroot=${serverip}{nfsroot},v3,tcp
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
netmask=255.255.255.0
panel=ATK-LCD-7-1024x600
script=boot.scr
serverip=192.168.1.104
splashimage=0x88000000
splashpos=m,m
Environment size: 2658/8188 bytes
=> setenv fdt_file 'imx6ull-alientek-emmc.dtb'
=> saveenv
Saving Environment to MMC...
Writing to MMC(1)... done
=> pri
baudrate=115200
board_name=EVK
board_rev=14X14
boot_fdt=try
bootdelay=1
console=ttymxc0
ethact=FEC1
ethprime=FEC
fdt_addr=0x83000000
fdt_file=imx6ull-alientek-emmc.dtb
fdt_high=0xffffffff
image=zImage
ip_dyn=yes
loadaddr=0x80800000
mmcautodetect=yes
mmcdev=1
mmcpart=1
script=boot.scr
splashpos=m,m
Environment size: 2648/8188 bytes
=> boot
switch to partitions #0, OK
mmc1(part 0) is current device
reading boot.scr
** Unable to read file boot.scr **
reading zImage
5901752 bytes read in 201 ms (28 MiB/s)
reading imx6ull-alientek-emmc.dtb
39280 bytes read in 26 ms (1.4 MiB/s)
Kernel image @ 0x80800000 [ 0x000000 - 0x5a0db8 ]
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Using Device Tree in place at 83000000, end 8300c96f
Starting kernel ...
GMT+8, 2026-10-31 02:21
