查看: 12652|回复: 0
这样算oop不,刚刚了解这方面知识,看了一上午写了个按键扫描。
44
135
135
2018-8-5
11 小时
发表于 2021-11-4 13:45:33 | 显示全部楼层 |阅读模式
/* 硬件映射 */
#define PIN_KEY1 _pa1
#define PIN_KEY2 _pa2
#define KEY_PRESS 1
#define KEY_RELASE 0
#define LONG_CNT_MIN 50
typedef enum {
    KEY_VALUE_NONE, /* 无按键按下*/
    KEY_VALUE_SHORT,
    KEY_VALUE_LONG,
    KEY_VALUE_MAX,
}KeyValueEn;
typedef enum {
    KEY_STATE_IDEL, /* 未按下 */
    KEY_STATE_FILT, /* 滤波 */
    KEY_STATE_DOWN,
    KEY_STATE_CHECK_RELASE,
    KEY_STATE_MAX,
}KeyStateEn;
typedef enum {
    KEY_NUM1 = 1,
    KEY_NUM2,
    KEY_NUM_MAX,
}KeyNumEn;
typedef struct keyObjLable{
    u8 keyState; /* @KeyStateEn */
    u8 keyValue; /* @KeyValueEn */
    u8 keyNum;   /* @KeyNumEn */
    u8 keepCnt;
    u8 (*IsUp)(u8 keyNumValue);
    void (*KeyScan)(keyObjLable* keyN);
}KeyObj;
KeyObj g_key1Obj, g_key2Obj;
static u8 IsKeyUp(u8 keyNumValue);
static void KeyScan(KeyObj* keyN);
void InitCreatKye1Obj(void)
    g_key1Obj.keyNum = KEY_NUM1;
    g_key1Obj.keyState = KEY_STATE_IDEL;
    g_key1Obj.keyValue = KEY_VALUE_NONE;
    g_key1Obj.keepCnt = 0;
    g_key1Obj.IsUp = IsKeyUp;
    g_key1Obj.KeyScan = KeyScan;
/* 间隔50ms 调用一次 */
    switch (keyN->keyState)
        case KEY_STATE_IDEL :
            if (keyN->IsUp(g_key1Obj.keyNum) == 0)
                keyN->keepCnt = 0;
                keyN->keyState = KEY_STATE_FILT;
        break;
        case KEY_STATE_FILT :
            if (keyN->IsUp(keyN->keyNum) == 0)
                keyN->keyState = KEY_STATE_DOWN;
        break;
        case KEY_STATE_DOWN :
                if (++keyN->keepCnt >= LONG_CNT_MIN)
                    keyN->keyValue = KEY_VALUE_LONG;
                    keyN->keyState = KEY_STATE_CHECK_RELASE;
                keyN->keyValue = KEY_VALUE_SHORT;
                keyN->keyState = KEY_STATE_IDEL;
        break;
        case KEY_STATE_CHECK_RELASE :
            if (keyN->IsUp(keyN->keyNum) == 1)
        break;
        default :
            //err print lastword
            while(1);
        break;
/* keyNum @KeyNumEn */
    switch(keyNumValue)
        case 1 :
            return (PIN_KEY1 == KEY_PRESS);
        break;
        case 2 :
            return (PIN_KEY2 == KEY_PRESS);
        break;
        default :
            while(1); /* 卡住等狗咬死 */
        break;
void main(void)
    InitCreatKye1Obj();
        if (g_timeFlag50Ms == SET)
            g_timeFlag50Ms = RESET;
            g_key1Obj.KeyScan(&g_key1Obj);
GMT+8, 2026-11-5 20:16
