查看: 5962|回复: 2
stm32mp移植wm8978音频驱动的问题
2020-8-31
11 小时
发表于 2021-12-30 14:37:26 | 显示全部楼层 |阅读模式
33金钱
不知道什么原因
设备树配置附上
    sound: sound {
        compatible = "audio-graph-card";
        label = "wm8978-audio";
        //routing =
            //"Playback" , "LHP",
            //"Capture" , "LHP";
            //"LMICN" , "Mic Bias",
            //"LMICP" , "Mic Bias";
        dais = <&sai2a_port &sai2b_port>;
        status = "okay";
&i2c4 {
    pinctrl-names = "default", "sleep";
    pinctrl-0 = <&i2c4_pins_a>;
    pinctrl-1 = <&i2c4_pins_sleep_a>;
    status = "okay";
    /delete-property/dmas;
    /delete-property/dma-names;
    codec: wm8978@1a {
        compatible = "wlf,wm8978";
        reg = <0x1a>;
        #sound-dai-cells = <0>;
        status = "okay";
        //wlf,shared-lrclk;
        port {
            #address-cells = <1>;
            #size-cells = <0>;
            wm8978_tx_endpoint: endpoint@0{
                reg = <0>;
                remote-endpoint = <&sai2a_endpoint>;
            wm8978_rx_endpoint: endpoint@1{
                reg = <1>;
                remote-endpoint = <&sai2b_endpoint>;
&sai2 {
    clocks = <&rcc SAI2>, <&rcc PLL3_Q>, <&rcc PLL3_R>;
    clock-names = "pclk", "x8k", "x11k";
    pinctrl-0 = <&sai2a_pins_a>, <&sai2b_pins_b>;
    pinctrl-1 = <&sai2a_sleep_pins_a>, <&sai2b_sleep_pins_b>;
    status = "okay";
    sai2a: audio-controller@4400b004 {
        #clock-cells = <0>;
        dma-names = "tx";
        clocks = <&rcc SAI2_K>;
        clock-names = "sai_ck";
        status = "okay";
            sai2a_port: port {
                sai2a_endpoint: endpoint{
                    remote-endpoint = <&wm8978_tx_endpoint>;
                    format = "i2s";
                    mclk-fs = <256>;
                    dai-tdm-slot-num = <2>;
                    dai-tdm-slot-width = <16>;
    sai2b: audio-controller@4400b024 {
        dma-names = "rx";
        st,sync = <&sai2a 2>;
        clocks = <&rcc SAI2_K>, <&sai2a>;
        status = "okay";
            sai2b_port: port {
                sai2b_endpoint: endpoint{
                    remote-endpoint = <&wm8978_rx_endpoint>;
                    format = "i2s";
                    mclk-fs = <256>;
108
231
231
2020-3-15
28 小时
发表于 2021-12-31 09:43:04 | 显示全部楼层
141
1131
1131
2015-12-20
120 小时
发表于 2022-1-6 08:52:18 | 显示全部楼层
解决了吗?
GMT+8, 2026-11-4 11:55
