查看: 6456|回复: 2
[XILINX] iMPACT14.7 Initialize Chain 错误,请问可能是什么原因导致的?
36
36
2022-2-17
发表于 2022-2-17 17:26:24 | 显示全部楼层 |阅读模式
iMPACT
iMPACT
console所有信息:
GUI --- Auto connect to cable...
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.4
INFO:iMPACT - Digilent Plugin: Opening device : "SN:210512180081".
INFO:iMPACT - Digilent Plugin: User Name: JtagHs1
INFO:iMPACT - Digilent Plugin: Product Name: Digilent JTAG-HS1
INFO:iMPACT - Digilent Plugin: Serial Number: 210512180081
INFO:iMPACT - Digilent Plugin: Product ID: 30900152
INFO:iMPACT - Digilent Plugin: Firmware Version: 0108
INFO:iMPACT - Digilent Plugin: JTAG Port Number: 0
INFO:iMPACT - Digilent Plugin: JTAG Clock Frequency: 10000000 Hz
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 2022/2/17 17:25:08
PROGRESS_START - Starting Operation.
Identifying chain contents...done.
ERROR:iMPACT - A problem may exist in the hardware configuration. Check that the cable, scan chain, and power connections are intact, that the specified scan chain configuration matches the actual hardware, and that the power supply is adequate and delivering the correct voltage.
PROGRESS_END - End Operation.
Elapsed time =      0 sec.
下载器是正点原子的Platform Cable USB。
请问可能是什么原因导致的?
线接错了,此问题关闭
36
36
2022-2-17
 楼主| 发表于 2022-2-17 17:26:25 | 显示全部楼层
线接错了,此问题关闭
808
2157
2157
2021-7-17
672 小时
发表于 2022-2-18 09:59:39 | 显示全部楼层
GMT+8, 2026-10-24 22:43
