查看: 6107|回复: 1
imx6ull nand 核心板 kernel 启动时何时创建分区
109
109
2020-2-25
19 小时
发表于 2022-2-19 21:03:44 | 显示全部楼层 |阅读模式
nand 核心板 kernel 启动的时候会出现分区信息以及 板载 nand 型号,但我搜索kernel 工程没有 “MT29F4G08ABADAWP”
gpmi_nand_probe 函数也没有创建分区,请各位大神指教
gpmi_nand_init mtd_device_parse_register mtd_add_device_partitions add_mtd_partitions printk(KERN_NOTICE "Creating %d MTD partitions on \"%s\":\n", nbparts, master->name); for (i = 0; i < nbparts; i++) { allocate_partition ...
109
109
2020-2-25
19 小时
 楼主| 发表于 2022-2-19 21:03:45 | 显示全部楼层
gpmi_nand_init
                        add_mtd_partitions
                                        allocate_partition
                                        printk(KERN_NOTICE "0x%012llx-0x%012llx : \"%s\"\n", (unsigned long long)slave->offset,
                                        (unsigned long long)(slave->offset + slave->mtd.size), slave->mtd.name);                                }
//mtd分区解析
int parse_mtd_partitions(struct mtd_info *master, const char *const *types,
                                   struct mtd_partition **pparts,
                                   struct mtd_part_parser_data *data)
        struct mtd_part_parser *parser;
        int ret = 0;
        if (!types)
                types = default_mtd_part_types;
        for ( ; ret <= 0 && *types; types++) {
                pr_debug("%s: parsing partitions %s\n", master->name, *types);
                parser = get_partition_parser(*types);
                if (!parser && !request_module("%s", *types))
                pr_debug("%s: got parser %s\n", master->name, parser ? parser->name : NULL);
                if (!parser)
                        continue;
                ret = (*parser->parse_fn)(master, pparts, data);
                put_partition_parser(parser);
                if (ret > 0) {
                        printk("types is :%s\n",*types);
                        printk(KERN_NOTICE "%d %s partitions found on MTD device %s\n",
                               ret, parser->name, master->name);
                        break;
        return ret;
GMT+8, 2026-10-31 00:19
