查看: 2901|回复: 0
CodeBlocks 模拟器跟着LittleVGL视频教程来整我的缺出现这样的错误怎样解决
2019-9-23
发表于 2022-3-30 17:06:22 | 显示全部楼层 |阅读模式
||=== Build: Debug in lttleVGL (compiler: GNU GCC Compiler) ===|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_apps\demo\demo.c||In function 'void kb_hide_anim_end(lv_anim_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_misc\lv_test_task.c||In function 'void delay_task(lv_task_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_apps\benchmark\benchmark_bg.c|226|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_img\img_flower_icon.c|181|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_1.c|141|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_2.c|141|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_3.c|181|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_4.c|181|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\5_antialiasing\apple_icon_alpha.c|140|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\5_antialiasing\apple_icon_chroma.c|141|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\flower_icon_alpha.c|61|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\lv_tutorial_images.c||In function 'lv_fs_res_t pcfs_open(lv_fs_drv_t*, void*, const char*, lv_fs_mode_t)':|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_disp.c||In function 'uint32_t lv_disp_get_inactive_time(const lv_disp_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\red_rose_16.c|108|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\red_flower.c|322|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_indev.c||In function 'void lv_indev_read_task(lv_task_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_indev.c|79|error: invalid conversion from 'void*' to 'lv_indev_t* {aka _lv_indev_t*}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_indev.c||In function 'void indev_proc_release(lv_indev_proc_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_indev.c|883|error: invalid conversion from 'void*' to 'lv_group_t* {aka _lv_group_t*}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_indev.c|899|error: invalid conversion from 'void*' to 'lv_group_t* {aka _lv_group_t*}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_indev.c||In function 'lv_obj_t* indev_search_obj(const lv_indev_proc_t*, lv_obj_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_misc\lv_ll.h|152|error: invalid conversion from 'void*' to 'lv_obj_t* {aka _lv_obj_t*}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_indev.c|1012|note: in expansion of macro 'LV_LL_READ'|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\red_flower.c|323|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\red_flower.c|324|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\red_flower.c|326|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\red_rose_16.c|109|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\red_rose_16.c|110|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\red_rose_16.c|112|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_disp.c|151|error: 'UINT32_MAX' was not declared in this scope|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\lv_tutorial_images.c|235|error: invalid conversion from 'void*' to 'FILE** {aka _iobuf**}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\lv_tutorial_images.c||In function 'lv_fs_res_t pcfs_close(lv_fs_drv_t*, void*)':|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\lv_tutorial_images.c|254|error: invalid conversion from 'void*' to 'FILE** {aka _iobuf**}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\lv_tutorial_images.c||In function 'lv_fs_res_t pcfs_read(lv_fs_drv_t*, void*, void*, uint32_t, uint32_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\lv_tutorial_images.c|273|error: invalid conversion from 'void*' to 'FILE** {aka _iobuf**}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\lv_tutorial_images.c||In function 'lv_fs_res_t pcfs_seek(lv_fs_drv_t*, void*, uint32_t)':|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\lv_tutorial_images.c|290|error: invalid conversion from 'void*' to 'FILE** {aka _iobuf**}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\lv_tutorial_images.c||In function 'lv_fs_res_t pcfs_tell(lv_fs_drv_t*, void*, uint32_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\lv_tutorial_images.c|306|error: invalid conversion from 'void*' to 'FILE** {aka _iobuf**}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\flower_icon_alpha.c|62|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\flower_icon_alpha.c|63|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\6_images\flower_icon_alpha.c|65|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\5_antialiasing\apple_icon_chroma.c|142|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\5_antialiasing\apple_icon_chroma.c|143|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_style.c||In function 'void lv_style_anim_init(lv_anim_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_style.c|289|error: invalid conversion from 'void*' to 'lv_style_anim_dsc_t*' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_style.c||In function 'void lv_style_anim_set_styles(lv_anim_t*, lv_style_t*, const lv_style_t*, const lv_style_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_style.c|303|error: invalid conversion from 'void*' to 'lv_style_anim_dsc_t*' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_style.c||In function 'void style_animation_common_end_cb(lv_anim_t*)':|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_core\lv_style.c|339|error: invalid conversion from 'void*' to 'lv_style_anim_dsc_t*' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\5_antialiasing\apple_icon_chroma.c|144|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\5_antialiasing\apple_icon_alpha.c|141|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\5_antialiasing\apple_icon_alpha.c|142|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tutorial\5_antialiasing\apple_icon_alpha.c|144|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_4.c|182|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_4.c|183|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_4.c|185|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_3.c|182|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_3.c|183|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_3.c|185|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lv_examples\lv_tests\lv_test_objx\lv_test_imgbtn\imgbtn_img_2.c|142|error: expected primary-expression before '.' token|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_draw\lv_draw_basic.c||In function 'void lv_draw_px(lv_coord_t, lv_coord_t, const lv_area_t*, lv_color_t, lv_opa_t)':|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_draw\lv_draw_basic.c|99|error: invalid conversion from 'void*' to 'lv_color_t* {aka lv_color32_t*}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_draw\lv_draw_basic.c||In function 'void lv_draw_fill(const lv_area_t*, const lv_area_t*, lv_color_t, lv_opa_t)':|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_draw\lv_draw_basic.c|150|error: invalid conversion from 'void*' to 'lv_color_t* {aka lv_color32_t*}' [-fpermissive]|
K:\LittleVGL-PC\lv_pc_simulator\lvgl\src\lv_draw\lv_draw_basic.c|162|error: invalid conversion from 'void*' to 'lv_color_t* {aka lv_color32_t*}' [-fpermissive]|
||More errors follow but not being shown.|
||Edit the max errors limit in compiler options...|
||=== Build failed: 50 error(s), 0 warning(s) (0 minute(s), 5 second(s)) ===|
GMT+8, 2026-11-4 18:37
