查看: 4313|回复: 0
stm32mp157 - 基于5.10.61内核的块设备驱动实现(ramdisk)
29
84
659
659
2014-5-11
87 小时
发表于 2022-4-19 21:15:54 | 显示全部楼层 |阅读模式
在5.10.61(可能在5.0之后)的内核版本中已经弃用了blk_queue_make_request, blk_init_queue等等函数,导致在调试块驱动无IO调度器的例程时出现编译错误。
刚开始有点懵,查了好多资料也没有具体的一个说明,最终还是在内核中找到相关代码借鉴,要改的地方如下:
* Handler function for all zram I/O requests.
增加
static blk_qc_t ramdisk_submit_bio(struct bio *bio)
        struct ramdisk_dev *zram = bio->bi_disk->private_data;
        ramdisk_make_request_fn(zram->queue, bio);
        return BLK_QC_T_NONE;
error:
        bio_io_error(bio);
* 块设备操作函数
static struct block_device_operations ramdisk_fops =
        .owner         = THIS_MODULE,
        .open         = ramdisk_open,
        .release = ramdisk_release,
        .getgeo  = ramdisk_getgeo,
        .submit_bio = ramdisk_submit_bio,    //增加
* @description        : 初始化队列相关操作
* @set                         : blk_mq_tag_set对象
* @return                 : request_queue的地址
static struct request_queue * create_req_queue(struct ramdisk_dev *set)
        struct request_queue *q;
#if 0
        q = blk_alloc_queue(GFP_KERNEL); //(set->numa_node);
        if (!q)
                return ERR_PTR(-ENOMEM);
        blk_queue_make_request(q, ramdisk_make_request_fn);
#else  // 修改代码
        q = blk_alloc_queue(NUMA_NO_NODE); //(set->numa_node);
        if (!q)
        /* zram devices sort of resembles non-rotational disks */
        blk_queue_flag_set(QUEUE_FLAG_NONROT, q);
        blk_queue_flag_clear(QUEUE_FLAG_ADD_RANDOM, q);
         * To ensure that we always get PAGE_SIZE aligned
         * and n*PAGE_SIZED sized I/O requests.
        blk_queue_physical_block_size(q, PAGE_SIZE);
        blk_queue_logical_block_size(q, (1UL<<12));
        blk_queue_io_min(q, PAGE_SIZE);
        blk_queue_io_opt(q, PAGE_SIZE);
        q->limits.discard_granularity = PAGE_SIZE;
        blk_queue_max_discard_sectors(q, UINT_MAX);
        blk_queue_flag_set(QUEUE_FLAG_DISCARD, q);
         * zram_bio_discard() will clear all logical blocks if logical block
         * size is identical with physical block size(PAGE_SIZE). But if it is
         * different, we will skip discarding some parts of logical blocks in
         * the part of the request range which isn't aligned to physical block
         * size.  So we can't ensure that all discarded logical blocks are
         * zeroed.
        //if (ZRAM_LOGICAL_BLOCK_SIZE == PAGE_SIZE)
                blk_queue_max_write_zeroes_sectors(q, UINT_MAX);
        blk_queue_flag_set(QUEUE_FLAG_STABLE_WRITES, q);
#endif
    q->queuedata = set;
        return q;
bwu
GMT+8, 2026-11-3 11:51
