查看: 4763|回复: 11
用的原子哥的程序放在自己遥控器上为什么这里报这种错误,看不懂为啥表达式错误
74
74
2021-4-12
12 小时
发表于 2022-4-25 11:15:34 | 显示全部楼层 |阅读模式
8金钱
static configParam_t configParamDefault=
        .version = VERSION,
//        configParam.language = DISPLAY_LANGUAGE,
        .radio.channel = RADIO_CHANNEL,
        .radio.dataRate = RADIO_DATARATE,
        .radio.addressHigh = ((uint64_t)RADIO_ADDRESS >> 32),
        .radio.addressLow = (RADIO_ADDRESS & 0xFFFFFFFFULL),
        .flight.ctrl = FLIGHT_CTRL_MODE,
        .flight.mode = FLIGHT_MODE,
        .flight.speed = FLIGHT_SPEED,
        .flight.flip = FLIP_SET,
//        configParam.jsParam.pitch.mid = 2000,
//        configParam_t.jsParam.pitch.range_neg = 2000,
//        .jsParam.pitch.range_pos = 2000,
//        .jsParam.roll.mid = 2000,
//        .jsParam.roll.range_neg = 2000,
//        .jsParam.roll.range_pos =2000,
//        .jsParam.yaw.mid = 2000,
//        .jsParam.yaw.range_neg = 2000,
//        .jsParam.yaw.range_pos =2000,
//        .jsParam.thrust.mid = 2000,
//        .jsParam.thrust.range_neg = 2000,
//        .jsParam.thrust.range_pos =2000,
//        .trim.pitch = 0.0,
//   .trim.roll = 0.0,
};用的原子哥的程序放在自己遥控器上为什么这里报这种错误,看不懂为啥表达式错误...\..\HARDWARE\Remoter\CONFIG\src\config_param.c(29): error:  #29: expected an expression
          .version = VERSION,
..\..\HARDWARE\Remoter\CONFIG\src\config_param.c(32): error:  #29: expected an expression
..\..\HARDWARE\Remoter\CONFIG\src\config_param.c(33): error:  #29: expected an expression
..\..\HARDWARE\Remoter\CONFIG\src\config_param.c(34): error:  #29: expected an expression
..\..\HARDWARE\Remoter\CONFIG\src\config_param.c(35): error:  #29: expected an expression
..\..\HARDWARE\Remoter\CONFIG\src\config_param.c(37): error:  #29: expected an expression
..\..\HARDWARE\Remoter\CONFIG\src\config_param.c(38): error:  #29: expected an expression
..\..\HARDWARE\Remoter\CONFIG\src\config_param.c(39): error:  #29: expected an expression
..\..\HARDWARE\Remoter\CONFIG\src\config_param.c(40): error:  #29: expected an expression
..\..\HARDWARE\Remoter\CONFIG\src\config_param.c: 0 warnings, 9 errors
808
2158
2158
2021-7-17
672 小时
发表于 2022-4-25 14:57:56 | 显示全部楼层
你没有添加这些HARDWARE\Remoter\CONFIG\src\config_param.c文件吗?
74
74
2021-4-12
12 小时
 楼主| 发表于 2022-4-25 16:18:39 | 显示全部楼层
添加了
80
914
3343
3343
2013-5-28
468 小时
发表于 2022-4-25 16:21:30 | 显示全部楼层
3515
9339
9339
2020-5-11
5165 小时
发表于 2022-4-25 17:35:13 | 显示全部楼层
莫非不支持C++?建议试一下C语言的结构体初始化方式。
专治疑难杂症
74
74
2021-4-12
12 小时
 楼主| 发表于 2022-4-25 21:58:56 | 显示全部楼层
我直接去掉那一部分了
778
6790
6790
2017-4-12
1261 小时
发表于 2022-4-26 16:57:41 | 显示全部楼层
在魔术棒里面,打开c99模式
74
74
2021-4-12
12 小时
 楼主| 发表于 2022-4-29 09:50:13 | 显示全部楼层
245925587 发表于 2022-4-26 16:57
在魔术棒里面,打开c99模式
怎么打开
74
74
2021-4-12
12 小时
 楼主| 发表于 2022-4-29 09:51:03 | 显示全部楼层
我试试
74
74
2021-4-12
12 小时
 楼主| 发表于 2022-4-29 09:54:21 | 显示全部楼层
聚东风 发表于 2022-4-25 16:21
FLIGHT_CTRL_MODE
这些东西定义了吗?就是对应的.h文件
定义了,这是.h里定义部分
typedef struct{
        u8 version;
//        enum language language;
        radioConfig_t radio;
        flightConfig_t flight;
//        joystickParam_t jsParam;
        trim_t trim;
        u8 cksum;
} configParam_t;
80
914
3343
3343
2013-5-28
468 小时
发表于 2022-4-29 10:52:19 | 显示全部楼层
夏明明 发表于 2022-4-29 09:54
定义了,这是.h里定义部分
typedef struct{
你在FLIGHT_CTRL_MODE上右键,点击go to definition of "FLIGHT_CTRL_MODE",如果跳不过去就是没添加对应的文件,而且你给我看的这是啥呀,我问的是FLIGHT_CTRL_MODE这个应该是个宏,不是你这个结构体
74
74
2021-4-12
12 小时
 楼主| 发表于 2022-5-2 17:14:29 | 显示全部楼层
聚东风 发表于 2022-4-29 10:52
你在FLIGHT_CTRL_MODE上右键,点击go to definition of "FLIGHT_CTRL_MODE",如果跳不过去就是没添加对应的 ...
/* ĬèÏÅäÖÃ2Îêy */
#define  VERSION        13                /*±íê¾°æ±¾ÎaV1.3*/
#define  DISPLAY_LANGUAGE        SIMPLE_CHINESE
#define  RADIO_CHANNEL                 2
#define  RADIO_DATARATE         DATA_RATE_250K
#define  RADIO_ADDRESS                 0x123456789AULL
#define  FLIGHT_CTRL_MODE        ALTHOLD_MODE
#define  FLIGHT_MODE                HEAD_LESS
#define  FLIGHT_SPEED                LOW_SPEED
#define  FLIP_SET                        FLIP_DISABLE
go to define是这个
GMT+8, 2026-11-11 00:35
