查看: 5602|回复: 2
安装ncurses6.0时make install停着不动了
2013-12-17
发表于 2022-5-26 23:40:42 | 显示全部楼层 |阅读模式
大家又遇到了这个问题嘛,一直停在这里不动了
mkdir -p /home/wxx/linux/IMX6ULL/tool/ncurses/share/tabset
DESTDIR= \
        prefix=/home/wxx/linux/IMX6ULL/tool/ncurses \
        exec_prefix=/home/wxx/linux/IMX6ULL/tool/ncurses \
        bindir=/home/wxx/linux/IMX6ULL/tool/ncurses/bin \
        top_srcdir=.. \
        srcdir=. \
        datadir=/home/wxx/linux/IMX6ULL/tool/ncurses/share \
        ticdir=/home/wxx/linux/IMX6ULL/tool/ncurses/share/terminfo \
        source=terminfo.tmp \
        cross_compiling=yes \
        /bin/sh ./run_tic.sh
** Building terminfo database, please wait...
Running /usr/local/bin/tic to install /home/wxx/linux/IMX6ULL/tool/ncurses/share/terminfo ...
        You may see messages regarding extended capabilities, e.g., AX.
        These are extended terminal capabilities which are compiled
        using
                tic -x
        If you have ncurses 4.2 applications, you should read the INSTALL
        document, and install the terminfo without the -x option.
解决了,用文档的方式行不通,应该配置成这样的./configure --prefix=/home/zuozhongkai/linux/IMX6ULL/tool/ncurses --host=arm-linux-gnueabihf --with-shared
2013-12-17
 楼主| 发表于 2022-5-26 23:40:43 | 显示全部楼层
2013-12-17
 楼主| 发表于 2022-5-27 23:19:44 | 显示全部楼层
还是不行啊,怎么回事
GMT+8, 2026-10-30 23:42
