查看: 6214|回复: 0
[XILINX] 求教各位大神GTP硬件引脚分配
2019-6-9
发表于 2022-6-6 16:59:17 | 显示全部楼层 |阅读模式
请教一下各位大神大佬,GTP硬件引脚需要我们在XDC文件分配吗?我看原子哥例程里面在顶层模块有光口输入输出定义,但是没有找到引脚分配,是因为硬核不需要分配IP默认引脚吗?那为啥还要在模块里面定义输入输出端口呢?
module gtwizard_0_exdes #
    parameter EXAMPLE_CONFIG_INDEPENDENT_LANES     =   1,//configuration for frame gen and check
    parameter EXAMPLE_LANE_WITH_START_CHAR         =   0,         // specifies lane with unique start frame char
    parameter EXAMPLE_WORDS_IN_BRAM                =   512,       // specifies amount of data in BRAM
    parameter EXAMPLE_SIM_GTRESET_SPEEDUP          =   "FALSE",    // simulation setting for GT SecureIP model
    parameter EXAMPLE_USE_CHIPSCOPE                =   0,         // Set to 1 to use Chipscope to drive resets
    parameter STABLE_CLOCK_PERIOD                  = 10
    input wire  Q0_CLK1_GTREFCLK_PAD_N_IN,
    input wire  Q0_CLK1_GTREFCLK_PAD_P_IN,
    input wire  DRP_CLK_IN,
    input  wire         RXN_IN,
    input  wire         RXP_IN,
    output wire         TXN_OUT,
    output wire         TXP_OUT,
    output wire [1:0]   tx_disable
@正点原子
GMT+8, 2026-10-25 08:40
