查看: 5941|回复: 1
IMX6ULL SPI例程触发core错误 icm20608
49
49
2022-5-20
11 小时
发表于 2022-8-5 11:32:28 | 显示全部楼层 |阅读模式
在学习IMX6ULL SPI教程中(SPI读写icm20608),发现,   1) 如果icm20608_read_regs采用spi_write_then_read()进行数据读写则正常
     static int icm20608_read_regs(struct icm20608_dev *dev, u8 reg,  void *buf, int len)
    int ret = 0;
    struct spi_device *spi = (struct spi_device *)dev->private_data;
    u8 txdata;
    //采用spi接口函数
    txdata = reg | 0x80; //icm20608要求read请求,adress最高位为1
    ret = spi_write_then_read(spi, &txdata, 1, buf, len);
    return 0;
2)如果直接封装spi_transfer,驱动加载时读寄存器(单个)是OK的,但是执行./icm20608App /dev/icm20608则会报如下错误
   函数封装如下:
    static int icm20608_read_regs_xfer(struct icm20608_dev *dev, u8 reg,  void *buf, int len)
    // printk("icm20608_read_regs_xfer Enter\r\n");
    int ret = 0;
    int i = 0;
    struct spi_transfer  xfer[2];
    struct spi_message m;
    if(len > XFER_BUF_LEN-1){
        printk("len(%d) is invalid, max len is:%d\r\n", len, XFER_BUF_LEN);
        return EPERM;
    mutex_lock(&dev->mutex);
    spi_message_init(&m);
    memset(xfer, 0, sizeof(xfer));
    dev->xfer_buf[0] = reg | 0x80; //icm20608要求read请求,adress最高位为1
    xfer[0].tx_buf = &dev->xfer_buf[0];
    xfer[0].len = sizeof(dev->xfer_buf[0]);
    spi_message_add_tail(&xfer[0], &m);
    xfer[1].rx_buf = &dev->xfer_buf[1];
    xfer[1].len = sizeof(dev->xfer_buf[1]) * len;
    spi_message_add_tail(&xfer[1], &m);
    ret = spi_async(spi, &m);
    if (unlikely(ret)) {
                printk("SPI read error: %d\n", ret);
        mutex_unlock(&dev->mutex);
                return ret;
    memcpy(buf, &dev->xfer_buf[1], len);
    // printk("icm20608_read_regs_xfer End\r\n");
    return 0;
最终发现,是把spi_sync()错写成了spi_async()(同时要去掉mutex,即可测试OK)
49
49
2022-5-20
11 小时
 楼主| 发表于 2022-8-5 11:32:29 | 显示全部楼层
GMT+8, 2026-10-31 00:19
