查看: 6452|回复: 4
imx6ull新板子回来nfs挂载文件系统
190
190
2020-7-12
47 小时
发表于 2022-10-20 23:42:23 | 显示全部楼层 |阅读模式
imx6ull新板子回来nfs挂载文件系统,需要把自带的文件系统删除吗?我没删除一直挂载不成功,好像默认启动了板子自带的文件系统
190
190
2020-7-12
47 小时
 楼主| 发表于 2022-10-25 00:34:36 | 显示全部楼层
起个什么名字好 发表于 2022-10-21 10:11
烧写教程的uboot去配置环境变量使用,出厂uboot默认最终是启动emmc里的文件系统
烧成成功了,挂载nfs文件系最后一步又出错了wm8960 1-001a: Failed to issue resetwm8960: probe of 1-001a failed with error -5
fsl-asrc 2034000.asrc: driver registered
imx-wm8960 sound: failed to find codec platform device
imx-wm8960: probe of sound failed with error -22
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
mmc1: MAN_BKOPS_EN bit is not set
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
lib80211: common routines for IEEE802.11 drivers
Key type dns_resolver registered
Registering SWP/SWPB emulation handler
input: gpio-keys as /devices/platform/gpio-keys/input/input2
mmc1: new HS200 MMC card at address 0001
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 2021-07-21 12:17:58 UTC (1626869878)
mmcblk1: mmc1:0001 SPeMMC 7.27 GiB
mmcblk1boot0: mmc1:0001 SPeMMC partition 1 4.00 MiB
mmcblk1boot1: mmc1:0001 SPeMMC partition 2 4.00 MiB
mmcblk1rpmb: mmc1:0001 SPeMMC partition 3 4.00 MiB
mmcblk1: p1 p2
IP-Config: Failed to open eth0
IP-Config: Device `eth0' not found
gpio_dvfs: disabling
VSD_3V3: disabling
can-3v3: disabling
ALSA device list:
  No soundcards found.
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "nfs" or unknown-block(2,0): error -6
Please append a correct "root=" boot option; here are the available partitions:
0100           65536 ram0  (driver?)
0101           65536 ram1  (driver?)
0102           65536 ram2  (driver?)
0103           65536 ram3  (driver?)
0104           65536 ram4  (driver?)
0105           65536 ram5  (driver?)
0106           65536 ram6  (driver?)
0107           65536 ram7  (driver?)
0108           65536 ram8  (driver?)
0109           65536 ram9  (driver?)
010a           65536 ram10  (driver?)
010b           65536 ram11  (driver?)
010c           65536 ram12  (driver?)
010d           65536 ram13  (driver?)
010e           65536 ram14  (driver?)
010f           65536 ram15  (driver?)
b300         7626752 mmcblk1  driver: mmcblk
  b301           32768 mmcblk1p1 4a1b4356-01
  b302         7592960 mmcblk1p2 4a1b4356-02
b330            4096 mmcblk1rpmb  (driver?)
b320            4096 mmcblk1boot1  (driver?)
b310            4096 mmcblk1boot0  (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
random: nonblocking pool is initialized
回复 支持 2 反对 0
91
506
506
2022-7-23
92 小时
发表于 2022-10-21 10:04:15 | 显示全部楼层
回帖奖励 +1 金钱
214
1191
1191
2020-12-1
153 小时
发表于 2022-10-21 10:11:33 | 显示全部楼层
2016-10-5
发表于 2022-10-31 23:27:22 | 显示全部楼层
2273085954 发表于 2022-10-25 00:34
烧成成功了,挂载nfs文件系最后一步又出错了wm8960 1-001a: Failed to issue resetwm8960: probe of 1-00 ...
决绝了吗?
GMT+8, 2026-10-31 01:36
