查看: 5234|回复: 1
uboot mmcinfo 打印mmc命令错误
53
53
2020-11-28
26 小时
发表于 2022-11-30 21:08:53 | 显示全部楼层 |阅读模式
第一次学LINUX,根据正点原子MP1的手册一步步来的,到了uboot这里打印emmc信息就出错了我又重新刷了镜像还是这种情况
求大佬解决:
STM32MP> mmc info
Card did not respond to voltage select!
STM32MP> mmc rescan
STM32MP> mmc rst
mmc - MMC sub system
Usage:
mmc info - display info of the current MMC device
mmc read addr blk# cnt
mmc write addr blk# cnt
mmc erase blk# cnt
mmc rescan
mmc part - lists available partition on current mmc device
mmc dev [dev] [part] - show or set current mmc device [partition]
mmc list - lists available devices
mmc hwpartition [args...] - does hardware partitioning
  arguments (sizes in 512-byte blocks):
    [user [enh start cnt] [wrrel {on|off}]] - sets user data area attributes
    [gp1|gp2|gp3|gp4 cnt [enh] [wrrel {on|off}]] - general purpose partition
    [check|set|complete] - mode, complete set partitioning completed
  WARNING: Partitioning is a write-once setting once it is set to complete.
  Power cycling is required to initialize partitions after set to complete.
mmc bootbus dev boot_bus_width reset_boot_bus_width boot_mode
- Set the BOOT_BUS_WIDTH field of the specified device
mmc bootpart-resize <dev> <boot part size MB> <RPMB part size MB>
- Change sizes of boot and RPMB partitions of specified device
mmc partconf dev [boot_ack boot_partition partition_access]
- Show or change the bits of the PARTITION_CONFIG field of the specified device
mmc rst-function dev value
- Change the RST_n_FUNCTION field of the specified device
   WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.
mmc setdsr <value> - set DSR register value
解决了 mmc切换设备就好了
53
53
2020-11-28
26 小时
 楼主| 发表于 2022-11-30 21:08:54 | 显示全部楼层
解决了 mmc切换设备就好了
GMT+8, 2026-11-3 10:52
