查看: 6847|回复: 1
【求助】linux启动过程中不停重启
2022-12-2
发表于 2022-12-2 14:12:24 | 显示全部楼层 |阅读模式
系统不停重启,请教下
串口查看打印输出。
用sd卡启动系统,每次打印 Starting kernel log daemon... 后重启
  1. Starting Xserver
  2. Starting system message bus: dbus.
  3. Starting Connection Manager
  4. Starting Dropbear SSH server: dropbear.
  5. Starting rpcbind daemon...[   10.923968] fec 2188000.ethernet eth1: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=20b4000.ethernet:02, irq=-1)
  6. done.
  7. [   11.003854] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
  8. starting statd: done
  9. Starting advanced power management daemon: apmd.
  10. apmd[588]: apmd 3.2.1 interfacing with apm driver 1.13 and APM BIOS 1.2
  11. Starting atd: OK
  12. exportfs: can't open /etc/exports for reading
  13. NFS daemon support not enabled in kernel
  14. Starting system log daemon...0
  15. Starting kernel log daemon...
  16. U-Boot 2016.03 (Nov 28 2022 - 23:46:05 -0800)
  17. CPU:   Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
  18. CPU:   Industrial temperature grade (-40C to 105C) at 42C
用emmc启动系统,每次启动完后打印 ICM20608 ID = 0XAE 然后重启
  1. Starting system log daemon...0
  2. Starting kernel log daemon...0
  3. * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon                       [ ok ]
  4. Starting Telephony daemon
  5. Starting Linux NFC daemon
  6. * starting FTP Server: vsftpd... done.
  7. Starting crond: OK
  8. Starting nginx: nginx.
  9. Running local boot scripts (/etc/rc.local).
  10. root@ATK-IMX6U:~# [   17.737946] ICM20608 ID = 0XAE
  11. U-Boot 2016.03-g0ae7e33 (Aug 14 2022 - 19:42:45 +0800)
  12. CPU:   Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
用“NXP官方原版MFG_TOOL烧写工具”烧录emmc启动,则没有问题。
每次重启时都会“嗒”一声,不知道是否硬件问题?
发表于 2022-12-3 22:55:22 | 显示全部楼层
GMT+8, 2026-10-30 23:38
