查看: 1775|回复: 2
开始学uboot了,编译uboot后出现报错
49
49
2019-8-23
发表于 2022-12-8 10:26:37 | 显示全部楼层 |阅读模式
//////下面是终端的报错内容
hjh@hjh:~/Linux/Uboot/alientek_uboot $ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- mx6ull_14x14_ddr512_emmc_defconfig
# configuration written to .config
hjh@hjh:~/Linux/Uboot/alientek_uboot $ make V=1 ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j12
make -f ./Makefile silentoldconfig
make -f ./scripts/Makefile.build obj=scripts/basic
rm -f .tmp_quiet_recordmcount
make -f ./scripts/Makefile.build obj=scripts/kconfig silentoldconfig
mkdir -p include/config include/generated
scripts/kconfig/conf  --silentoldconfig Kconfig
make -f ./scripts/Makefile.autoconf || \
        { rm -f include/config/auto.conf; false; }
if [ -d arch/arm/mach-mx6/include/mach ]; then  \
        dest=../../mach-mx6/include/mach;                       \
else                                                            \
        dest=arch-mx6;                  \
fi;                                                             \
ln -fsn $dest arch/arm/include/asm/arch
set -e; : '  CHK     include/config.h'; mkdir -p include/;      (echo "/* Automatically generated - do not edit */"; for i in $(echo "IMX_CONFIG=board/freescale/mx6ullevk/imximage-ddr512.cfg,MX6ULL_EVK_EMMC_REWORK" | sed 's/,/ /g'); do echo \#define CONFIG_$i | sed '/=/ {s/=/        /;q; } ; { s/$/        1/; }'; done; echo \#define CONFIG_BOARDDIR board/freescale/mx6ullevk; echo \#include \<config_defaults.h\>; echo \#include \<config_uncmd_spl.h\>; echo \#include \<configs/"mx6ullevk".h\>; echo \#include \<asm/config.h\>; echo \#include \<config_fallbacks.h\>;) < scripts/Makefile.autoconf > include/config.h.tmp; if [ -r include/config.h ] && cmp -s include/config.h include/config.h.tmp; then rm -f include/config.h.tmp; else : '  UPD     include/config.h'; mv -f include/config.h.tmp include/config.h; fi
  arm-linux-gnueabihf-gcc -E -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time  -D__KERNEL__ -D__UBOOT__   -D__ARM__ -marm -mno-thumb-interwork  -mabi=aapcs-linux  -mword-relocations  -fno-pic  -mno-unaligned-access  -ffunction-sections -fdata-sections -fno-common -ffixed-r9  -msoft-float  -pipe -Iinclude  -I./arch/arm/include -include ./include/linux/kconfig.h  -nostdinc -isystem /usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.4/include  -DDO_DEPS_ONLY -dM ./include/common.h > include/autoconf.mk.tmp && { sed -n -f ./tools/scripts/define2mk.sed include/autoconf.mk.tmp | while read line; do if [ -n "" ] || ! grep -q "${line%=*}=" include/config/auto.conf; then echo "$line"; fi done > include/autoconf.mk; rm include/autoconf.mk.tmp; } || { rm include/autoconf.mk.tmp; false; }
  arm-linux-gnueabihf-gcc -x c -DDO_DEPS_ONLY -M -MP -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time  -D__KERNEL__ -D__UBOOT__   -D__ARM__ -marm -mno-thumb-interwork  -mabi=aapcs-linux  -mword-relocations  -fno-pic  -mno-unaligned-access  -ffunction-sections -fdata-sections -fno-common -ffixed-r9  -msoft-float  -pipe -Iinclude  -I./arch/arm/include -include ./include/linux/kconfig.h  -nostdinc -isystem /usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.4/include -MQ include/config/auto.conf ./include/common.h > include/autoconf.mk.dep || { rm include/autoconf.mk.dep; false; }
touch include/config/auto.conf
set -e; : '  CHK     include/config/uboot.release'; mkdir -p include/config/;   echo "2016.03$(/bin/bash ./scripts/setlocalversion .)" < include/config/auto.conf > include/config/uboot.release.tmp; if [ -r include/config/uboot.release ] && cmp -s include/config/uboot.release include/config/uboot.release.tmp; then rm -f include/config/uboot.release.tmp; else : '  UPD     include/config/uboot.release'; mv -f include/config/uboot.release.tmp include/config/uboot.release; fi
set -e; : '  CHK     include/generated/timestamp_autogenerated.h'; mkdir -p include/generated/;         (if test -n "${SOURCE_DATE_EPOCH}"; then SOURCE_DATE="@${SOURCE_DATE_EPOCH}"; DATE=""; for date in gdate date.gnu date; do ${date} -u -d "${SOURCE_DATE}" >/dev/null 2>&1 && DATE="${date}"; done; if test -n "${DATE}"; then LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_DATE "%b %d %C%y"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_TIME "%T"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_TZ "%z"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_DMI_DATE "%m/%d/%Y"'; else return 42; fi; else LC_ALL=C date +'#define U_BOOT_DATE "%b %d %C%y"'; LC_ALL=C date +'#define U_BOOT_TIME "%T"'; LC_ALL=C date +'#define U_BOOT_TZ "%z"'; LC_ALL=C date +'#define U_BOOT_DMI_DATE "%m/%d/%Y"'; fi) < Makefile > include/generated/timestamp_autogenerated.h.tmp; if [ -r include/generated/timestamp_autogenerated.h ] && cmp -s include/generated/timestamp_autogenerated.h include/generated/timestamp_autogenerated.h.tmp; then rm -f include/generated/timestamp_autogenerated.h.tmp; else : '  UPD     include/generated/timestamp_autogenerated.h'; mv -f include/generated/timestamp_autogenerated.h.tmp include/generated/timestamp_autogenerated.h; fi
set -e; : '  CHK     include/generated/version_autogenerated.h'; mkdir -p include/generated/;   (echo \#define PLAIN_VERSION \"2016.03\"; echo \#define U_BOOT_VERSION \"U-Boot \" PLAIN_VERSION; echo \#define CC_VERSION_STRING \"$(arm-linux-gnueabihf-gcc --version | head -n 1)\"; echo \#define LD_VERSION_STRING \"$(arm-linux-gnueabihf-ld.bfd --version | head -n 1)\"; ) < include/config/uboot.release > include/generated/version_autogenerated.h.tmp; if [ -r include/generated/version_autogenerated.h ] && cmp -s include/generated/version_autogenerated.h include/generated/version_autogenerated.h.tmp; then rm -f include/generated/version_autogenerated.h.tmp; else : '  UPD     include/generated/version_autogenerated.h'; mv -f include/generated/version_autogenerated.h.tmp include/generated/version_autogenerated.h; fi
make -f ./scripts/Makefile.build obj=.
mkdir -p lib/
mkdir -p arch/arm/lib/
set -e; : '  CHK     include/generated/generic-asm-offsets.h'; mkdir -p include/generated/;     (set -e; echo "#ifndef __GENERIC_ASM_OFFSETS_H__"; echo "#define __GENERIC_ASM_OFFSETS_H__"; echo "/*"; echo " * DO NOT MODIFY."; echo " *"; echo " * This file was generated by Kbuild"; echo " */"; echo ""; sed -ne         "s:[[:space:]]*\.ascii[[:space:]]*\"\(.*\)\":\1:; /^->/{s:->#\(.*\):/* \1 */:; s:^->\([^ ]*\) [\$#]*\([-0-9]*\) \(.*\):#define \1 \2 /* \3 */:; s:^->\([^ ]*\) [\$#]*\([^ ]*\) \(.*\):#define \1 \2 /* \3 */:; s:->::; p;}"; echo ""; echo "#endif" ) < lib/asm-offsets.s > include/generated/generic-asm-offsets.h.tmp; if [ -r include/generated/generic-asm-offsets.h ] && cmp -s include/generated/generic-asm-offsets.h include/generated/generic-asm-offsets.h.tmp; then rm -f include/generated/generic-asm-offsets.h.tmp; else : '  UPD     include/generated/generic-asm-offsets.h'; mv -f include/generated/generic-asm-offsets.h.tmp include/generated/generic-asm-offsets.h; fi
set -e; : '  CHK     include/generated/asm-offsets.h'; mkdir -p include/generated/;     (set -e; echo "#ifndef __ASM_OFFSETS_H__"; echo "#define __ASM_OFFSETS_H__"; echo "/*"; echo " * DO NOT MODIFY."; echo " *"; echo " * This file was generated by Kbuild"; echo " */"; echo ""; sed -ne         "s:[[:space:]]*\.ascii[[:space:]]*\"\(.*\)\":\1:; /^->/{s:->#\(.*\):/* \1 */:; s:^->\([^ ]*\) [\$#]*\([-0-9]*\) \(.*\):#define \1 \2 /* \3 */:; s:^->\([^ ]*\) [\$#]*\([^ ]*\) \(.*\):#define \1 \2 /* \3 */:; s:->::; p;}"; echo ""; echo "#endif" ) < arch/arm/lib/asm-offsets.s > include/generated/asm-offsets.h.tmp; if [ -r include/generated/asm-offsets.h ] && cmp -s include/generated/asm-offsets.h include/generated/asm-offsets.h.tmp; then rm -f include/generated/asm-offsets.h.tmp; else : '  UPD     include/generated/asm-offsets.h'; mv -f include/generated/asm-offsets.h.tmp include/generated/asm-offsets.h; fi
make -f ./scripts/Makefile.build obj=tools
  cc -Wp,-MD,tools/.mkenvimage.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/mkenvimage.o tools/mkenvimage.c
  cc -Wp,-MD,tools/lib/.crc32.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -pedantic -c -o tools/lib/crc32.o tools/lib/crc32.c
  cc -Wp,-MD,tools/.aisimage.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/aisimage.o tools/aisimage.c
  cc -Wp,-MD,tools/.atmelimage.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/atmelimage.o tools/atmelimage.c
  cc -Wp,-MD,tools/common/.bootm.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/common/bootm.o tools/common/bootm.c
  cc -Wp,-MD,tools/.default_image.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/default_image.o tools/default_image.c
  cc -Wp,-MD,tools/lib/.fdtdec_common.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/lib/fdtdec_common.o tools/lib/fdtdec_common.c
  cc -Wp,-MD,tools/lib/.fdtdec.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/lib/fdtdec.o tools/lib/fdtdec.c
  cc -Wp,-MD,tools/.fit_common.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/fit_common.o tools/fit_common.c
  cc -Wp,-MD,tools/.fit_image.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/fit_image.o tools/fit_image.c
  cc -Wp,-MD,tools/.gpimage.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/gpimage.o tools/gpimage.c
In file included from /usr/include/x86_64-linux-gnu/sys/stat.h:446,
                 from tools/imagetool.h:18,
                 from tools/atmelimage.c:8:
/usr/lib/gcc/x86_64-linux-gnu/9/include-fixed/bits/statx.h:38:25: error: missing binary operator before token "("
   38 | #if __glibc_has_include ("__linux__/stat.h")
                 from ./tools/mkimage.h:18,
                 from ./tools/../common/bootm.c:26,
                 from tools/common/bootm.c:1:
                 from tools/aisimage.c:8:
                 from tools/mkenvimage.c:21:
                 from tools/default_image.c:17:
make[1]: *** [scripts/Makefile.host:111:tools/mkenvimage.o] 错误 1
make[1]: *** 正在等待未完成的任务....
  cc -Wp,-MD,tools/.gpimage-common.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/gpimage-common.o tools/gpimage-common.c
make[1]: *** [scripts/Makefile.host:111:tools/atmelimage.o] 错误 1
make[1]: *** [scripts/Makefile.host:111:tools/common/bootm.o] 错误 1
make[1]: *** [scripts/Makefile.host:111:tools/aisimage.o] 错误 1
                 from tools/fit_common.c:21:
                 from tools/fit_image.c:17:
make[1]: *** [scripts/Makefile.host:111:tools/default_image.o] 错误 1
                 from tools/gpimage.c:22:
make[1]: *** [scripts/Makefile.host:111:tools/fit_common.o] 错误 1
                 from tools/gpimage-common.c:21:
make[1]: *** [scripts/Makefile.host:111:tools/fit_image.o] 错误 1
make[1]: *** [scripts/Makefile.host:111:tools/gpimage.o] 错误 1
make[1]: *** [scripts/Makefile.host:111:tools/gpimage-common.o] 错误 1
make: *** [Makefile:1194:tools] 错误 2
Ubuntu 中安装好了 ncurses 库,之后解压uboot-imx-2016.03-2.1.0-gd3f0479-v1.4.tar.xz,因为格式不是.bz2,自行搜索解压的:解压tar.xz文件:先 xz -d xxx.tar.xz 将 xxx.tar.xz解压成 xxx.tar 然后,再用 tar xvf xxx.tar来解包
在之后执行那三条make就报错,希望能帮我看看什么问题,怎么解决
49
49
2019-8-23
 楼主| 发表于 2022-12-8 10:31:44 | 显示全部楼层
hjh@hjh:~/Linux/Uboot/alientek_uboot $ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- distclean
  CLEAN   tools
  CLEAN   tools/lib tools/common
  CLEAN   u-boot.lds u-boot.cfg
  CLEAN   scripts/basic
  CLEAN   scripts/kconfig
  CLEAN   include/config include/generated
  CLEAN   .config .config.old include/autoconf.mk.dep include/autoconf.mk include/config.h
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/zconf.lex.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/zconf.tab.o
In file included from scripts/kconfig/zconf.tab.c:2534:
scripts/kconfig/confdata.c: In function ‘conf_write’:
scripts/kconfig/confdata.c:771:19: warning: ‘%s’ directive writing likely 7 or more bytes into a region of size between 1 and 4097 [-Wformat-overflow=]
  771 |  sprintf(newname, "%s%s", dirname, basename);
scripts/kconfig/confdata.c:771:19: note: assuming directive output of 7 bytes
In file included from /usr/include/stdio.h:867,
                 from scripts/kconfig/zconf.tab.c:84:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:36:10: note: ‘__builtin___sprintf_chk’ output 1 or more bytes (assuming 4104) into a destination of size 4097
   36 |   return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1,
   37 |       __bos (__s), __fmt, __va_arg_pack ());
scripts/kconfig/confdata.c:774:20: warning: ‘.tmpconfig.’ directive writing 11 bytes into a region of size between 1 and 4097 [-Wformat-overflow=]
  774 |   sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid());
/usr/include/x86_64-linux-gnu/bits/stdio2.h:36:10: note: ‘__builtin___sprintf_chk’ output between 13 and 4119 bytes into a destination of size 4097
  HOSTLD  scripts/kconfig/conf
else                                                            \
        dest=arch-mx6;                  \
fi;                                                             \
  arm-linux-gnueabihf-gcc -E -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -O2 -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time  -D__KERNEL__ -D__UBOOT__   -D__ARM__ -marm -mno-thumb-interwork  -mabi=aapcs-linux  -mword-relocations  -fno-pic  -mno-unaligned-access  -ffunction-sections -fdata-sections -fno-common -ffixed-r9  -msoft-float  -pipe -Iinclude  -I./arch/arm/include -include ./include/linux/kconfig.h  -nostdinc -isystem /usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.4/include  -DDO_DEPS_ONLY -dM ./include/common.h > include/autoconf.mk.tmp && { sed -n -f ./tools/scripts/define2mk.sed include/autoconf.mk.tmp | while read line; do if [ -n "" ] || ! grep -q "${line%=*}=" include/config/auto.conf; then echo "$line"; fi done > include/autoconf.mk; rm include/autoconf.mk.tmp; } || { rm include/autoconf.mk.tmp; false; }
  arm-linux-gnueabihf-gcc -x c -DDO_DEPS_ONLY -M -MP -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -O2 -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time  -D__KERNEL__ -D__UBOOT__   -D__ARM__ -marm -mno-thumb-interwork  -mabi=aapcs-linux  -mword-relocations  -fno-pic  -mno-unaligned-access  -ffunction-sections -fdata-sections -fno-common -ffixed-r9  -msoft-float  -pipe -Iinclude  -I./arch/arm/include -include ./include/linux/kconfig.h  -nostdinc -isystem /usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.4/include -MQ include/config/auto.conf ./include/common.h > include/autoconf.mk.dep || { rm include/autoconf.mk.dep; false; }
  arm-linux-gnueabihf-gcc -E -Wp,-MD,./.u-boot.cfg.d -D__KERNEL__ -D__UBOOT__   -D__ARM__ -marm -mno-thumb-interwork  -mabi=aapcs-linux  -mword-relocations  -fno-pic  -mno-unaligned-access  -ffunction-sections -fdata-sections -fno-common -ffixed-r9  -msoft-float  -pipe  -march=armv7-a   -Iinclude   -I./arch/arm/include -include ./include/linux/kconfig.h  -nostdinc -isystem /usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.4/include -include ./include/u-boot/u-boot.lds.h -DCPUDIR=arch/arm/cpu/armv7  -ansi -DDO_DEPS_ONLY -D__ASSEMBLY__ -x assembler-with-cpp -P -dM -E -o u-boot.cfg include/config.h
mkdir -p lib/
  arm-linux-gnueabihf-gcc -Wp,-MD,lib/.asm-offsets.s.d  -nostdinc -isystem /usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.4/include -Iinclude   -I./arch/arm/include -include ./include/linux/kconfig.h -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -DDO_DEPS_ONLY    -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(asm_offsets)"  -D"KBUILD_MODNAME=KBUILD_STR(asm_offsets)"  -fverbose-asm -S -o lib/asm-offsets.s lib/asm-offsets.c
  arm-linux-gnueabihf-gcc -Wp,-MD,arch/arm/lib/.asm-offsets.s.d  -nostdinc -isystem /usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.4/include -Iinclude   -I./arch/arm/include -include ./include/linux/kconfig.h -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -DDO_DEPS_ONLY    -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(asm_offsets)"  -D"KBUILD_MODNAME=KBUILD_STR(asm_offsets)"  -fverbose-asm -S -o arch/arm/lib/asm-offsets.s arch/arm/lib/asm-offsets.c
  cc -Wp,-MD,tools/.gen_eth_addr.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -pedantic -o tools/gen_eth_addr tools/gen_eth_addr.c
  cc -Wp,-MD,tools/.img2srec.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -pedantic -o tools/img2srec tools/img2srec.c
  cc -Wp,-MD,tools/.os_support.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/os_support.o tools/os_support.c
  echo "#include <../lib/crc32.c>" >tools/lib/crc32.c
  echo "#include <../common/bootm.c>" >tools/common/bootm.c
  arm-linux-gnueabihf-gcc -E -Wp,-MD,./.u-boot.lds.d -D__KERNEL__ -D__UBOOT__   -D__ARM__ -marm -mno-thumb-interwork  -mabi=aapcs-linux  -mword-relocations  -fno-pic  -mno-unaligned-access  -ffunction-sections -fdata-sections -fno-common -ffixed-r9  -msoft-float  -pipe  -march=armv7-a   -Iinclude   -I./arch/arm/include -include ./include/linux/kconfig.h  -nostdinc -isystem /usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.4/include -include ./include/u-boot/u-boot.lds.h -DCPUDIR=arch/arm/cpu/armv7  -ansi -D__ASSEMBLY__ -x assembler-with-cpp -P -o u-boot.lds arch/arm/cpu/u-boot.lds
  echo "#include <../lib/fdtdec_common.c>" >tools/lib/fdtdec_common.c
  echo "#include <../lib/fdtdec.c>" >tools/lib/fdtdec.c
  echo "#include <../common/image-fit.c>" >tools/common/image-fit.c
  cc -Wp,-MD,tools/.image-host.o.d -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer   -include ./include/libfdt_env.h -idirafterinclude -idirafter./arch/arm/include -I./lib/libfdt -I./tools -DCONFIG_SYS_TEXT_BASE=0x87800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE  -c -o tools/image-host.o tools/image-host.c
                 from tools/mkimage.h:18,
                 from tools/image-host.c:12:
make[1]: *** [scripts/Makefile.host:111:tools/image-host.o] 错误 1
49
49
2019-8-23
 楼主| 发表于 2022-12-8 13:58:19 | 显示全部楼层
根据error: missing binary operator before token,执行sudo apt-get install gcc-multilib以安装缺少的 32 位库,解决了第三步的报错,
Image Type:   Freescale IMX Boot Image
Image Ver:    2 (i.MX53/6/7 compatible)
Mode:         DCD
Data Size:    364544 Bytes = 356.00 kB = 0.35 MB
Load Address: 877ff420
Entry Point:  87800000
目前第二步任然报错
GMT+8, 2026-10-31 00:14
