查看: 6292|回复: 1
....烧写固件无法加载设备树...
68
403
403
2013-10-9
74 小时
发表于 2022-12-28 10:42:52 | 显示全部楼层 |阅读模式
....烧写系统提示:
U-Boot 2016.03 (Dec 27 2022 - 16:54:58 +0800)
CPU:   Freescale i.MX6ULL rev1.1 69 MHz (running at 396 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 47C
Reset cause: POR
Board: MX6ULL_BORROW_EMMC
I2C:   ready
DRAM:  512 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
Display: TFT43AB (480x272)
Video: 480x272x24
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc1(part 0) is current device
Net:   FEC1
Error: FEC1 address not set.
Normal Boot
syntax error
reading boot.scr
** Unable to read file boot.scr **
reading zImage
5612496 bytes read in 137 ms (39.1 MiB/s)
Booting from mmc ...
reading imx6ull-alientek-emmc.dtb
** Unable to read file imx6ull-alientek-emmc.dtb **
Kernel image @ 0x80800000 [ 0x000000 - 0x55a3d0 ]
Starting kernel ...
找不到imx6ull-alientek-emmc.dtb
查看uboot的EMMC
=> ls mmc 1:1
  5612496   zimage
    39459   imx6ull-14x14-evk.dtb
2 file(s), 0 dir(s)
  5612496   zimage
2 file(s), 0 dir(s)
怎么解决?...
无兄弟不篮球
214
1191
1191
2020-12-1
153 小时
发表于 2022-12-28 16:07:24 | 显示全部楼层
** Unable to read file imx6ull-alientek-emmc.dtb **,你的设备树是imx6ull-14x14-evk.dtb,名字对不上。最直接的方法就是把你设备树名字改为imx6ull-alientek-emmc.dtb
GMT+8, 2026-10-30 23:42
