查看: 5823|回复: 0
复旦微MCU单片机FM33LG048休眠模式RTthread使用方法记录
56
167
606
606
2013-10-18
60 小时
发表于 2023-1-13 14:30:28 | 显示全部楼层 |阅读模式
鉴于复旦微官方提供的RTThread存在bug,重新修改进行测试,满足项目实际要求
原官方休眠处理如下:
static void sleep(void)
   rt_tick_t timeout_tick, delta_tick;
   rt_uint32_t ret, freq = 32768;
   static rt_uint32_t os_tick_remain = 0;
   timeout_tick = rt_timer_next_timeout_tick() - rt_tick_get();
   if (timeout_tick >= 2)
       fm33xx_lptimer_start(freq * timeout_tick / RT_TICK_PER_SECOND);
       DeepSleep();
       ret = fm33xx_lptimer_get_current_tick();
       delta_tick = (ret * RT_TICK_PER_SECOND + os_tick_remain) / freq;
       os_tick_remain += (ret * RT_TICK_PER_SECOND);
       os_tick_remain %= freq;
       fm33xx_lptimer_stop();
       rt_tick_set(rt_tick_get() + delta_tick);
       rt_timer_check();
修改后如下:
rt_uint32_t ret1, freq = 32768;
void SleepAppHookHandle(void)
//   rt_tick_t timeout_tick, delta_tick;
//   rt_uint32_t ret, freq = 32768;
   if ((timeout_tick >= 2))
                                __disable_irq();
                                CLEAR_BIT(SysTick->CTRL, (rt_uint32_t)SysTick_CTRL_TICKINT_Msk);
                                BspLpTimerStart(freq * timeout_tick / RT_TICK_PER_SECOND);
                                SleepAppDeepSleep();
                                ret1 = BspLpTimerGetCurrentTick();
                                delta_tick = (ret1 * RT_TICK_PER_SECOND * 10u ) / freq;
                                if((delta_tick%10u) > 1u)
                                        delta_tick = (delta_tick + 10u)/10u;
                                        delta_tick = (delta_tick)/10u;
                                SET_BIT(SysTick->CTRL, (rt_uint32_t)SysTick_CTRL_TICKINT_Msk);
                                BspLpTimerStop();
                                rt_timer_check();
                 __enable_irq();
GMT+8, 2026-11-4 03:46
