查看: 3224|回复: 1
编译SDK失败,有提示,不知道怎么修改?
2020-8-3
发表于 2023-1-24 11:09:20 | 显示全部楼层 |阅读模式
编译SDK失败,提示:
2023-01-24T10:44:07 gzip: /home/zhu/RV1126/SDK/buildroot/dl/bzip2-1.0.6.tar.gz: not in gzip format
2023-01-24T10:44:07 /home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar: This does not look like a tar archive
2023-01-24T10:44:07 /home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar: Exiting with failure status due to previous errors
2023-01-24T10:44:07 make[1]: *** [package/pkg-generic.mk:163: /home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/build/bzip2-1.0.6/.stamp_extracted] Error 2
2023-01-24T10:44:07 make: *** [/home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/Makefile:16: _all] Error 2
2023-01-24T10:49:18 umask 0022 && make -C /home/zhu/RV1126/SDK/buildroot O=/home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126
2023-01-24T10:49:20 /usr/bin/make -j1 O=/home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126 HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" silentoldconfig
2023-01-24T10:49:20 GEN     /home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/Makefile
2023-01-24T10:49:21 >>> bzip2 1.0.6 Extracting
2023-01-24T10:49:21 gzip -d -c /home/zhu/RV1126/SDK/buildroot/dl/bzip2-1.0.6.tar.gz | /home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar --strip-components=1 -C /home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/build/bzip2-1.0.6   -xf -
2023-01-24T10:49:21
2023-01-24T10:49:21 gzip: /home/zhu/RV1126/SDK/buildroot/dl/bzip2-1.0.6.tar.gz: not in gzip format
2023-01-24T10:49:21 /home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar: This does not look like a tar archive
2023-01-24T10:49:21 /home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar: Exiting with failure status due to previous errors
2023-01-24T10:49:21 make[1]: *** [package/pkg-generic.mk:163: /home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/build/bzip2-1.0.6/.stamp_extracted] Error 2
2023-01-24T10:49:21 make: *** [/home/zhu/RV1126/SDK/buildroot/output/alientek_rv1126/Makefile:16: _all] Error 2
Command exited with non-zero status 1
you take 0:02.78 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 563:
    /usr/bin/time -f "you take %E to build builroot" $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
把资料里面的dl压缩包解压到sdk里面的buildroot目录下,重新试试,你这里提示是有个压缩包出问题了
96
433
433
2021-3-9
57 小时
发表于 2023-1-24 11:09:21 | 显示全部楼层
GMT+8, 2026-10-30 20:28
