查看: 2361|回复: 1
build SDK 的 recovery时 出错,不知怎么修改?
2023-3-2
发表于 2023-3-2 11:45:27 | 显示全部楼层 |阅读模式
==========Start building recovery==========
TARGET_RECOVERY_CONFIG=alientek_rv1126_recovery
config is alientek_rv1126_recovery
found kernel image
Top of tree: /home/zqf/sdk1126/sdk1126
#TARGET_BOARD=rv1126
#OUTPUT_DIR=output/alientek_rv1126_recovery
#CONFIG=alientek_rv1126_recovery_defconfig
make: Entering directory '/home/zqf/sdk1126/sdk1126/buildroot'
  GEN     /home/zqf/sdk1126/sdk1126/buildroot/output/alientek_rv1126_recovery/Makefile
/home/zqf/sdk1126/sdk1126/buildroot/build/defconfig_hook.py -m /home/zqf/sdk1126/sdk1126/buildroot/configs/alientek_rv1126_recovery_defconfig /home/zqf/sdk1126/sdk1126/buildroot/output/alientek_rv1126_recovery/.rockchipconfig
BR2_DEFCONFIG='' KCONFIG_AUTOCONFIG=/home/zqf/sdk1126/sdk1126/buildroot/output/alientek_rv1126_recovery/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/zqf/sdk1126/sdk1126/buildroot/output/alientek_rv1126_recovery/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/zqf/sdk1126/sdk1126/buildroot/output/alientek_rv1126_recovery/build/buildroot-config/tristate.config BR2_CONFIG=/home/zqf/sdk1126/sdk1126/buildroot/output/alientek_rv1126_recovery/.config HOST_GCC_VERSION="9" BUILD_DIR=/home/zqf/sdk1126/sdk1126/buildroot/output/alientek_rv1126_recovery/build SKIP_LEGACY= BR2_DEFCONFIG=/home/zqf/sdk1126/sdk1126/buildroot/configs/alientek_rv1126_recovery_defconfig /home/zqf/sdk1126/sdk1126/buildroot/output/alientek_rv1126_recovery/build/buildroot-config/conf --defconfig=/home/zqf/sdk1126/sdk1126/buildroot/output/alientek_rv1126_recovery/.rockchipconfig Config.in
# configuration written to /home/zqf/sdk1126/sdk1126/buildroot/output/alientek_rv1126_recovery/.config
make: Leaving directory '/home/zqf/sdk1126/sdk1126/buildroot'
====Start build alientek_rv1126_recovery====
2023-03-02T11:21:38 >>> host-python3-setuptools 44.0.0 Building
Done in 9s  (error code: 2)
Command exited with non-zero status 2
you take 0:10.43 to build recovery
ERROR: Running build_recovery failed!
ERROR: exit code 2 from line 708:
    /usr/bin/time -f "you take %E to build recovery" $COMMON_DIR/mk-ramdisk.sh recovery.img $RK_CFG_RECOVERY
先一键编译看看,一键编译过了的话,单独编译recovery应该没问题
888
2397
2397
2019-9-25
398 小时
发表于 2023-3-2 11:45:28 | 显示全部楼层
GMT+8, 2026-10-30 21:12
