查看: 2369|回复: 1
编译rootfs报错,请教如何解决
113
113
2019-11-27
22 小时
发表于 2023-3-6 15:50:25 | 显示全部楼层 |阅读模式
processing board option: rootfs
processing option: rootfs
==========Start building buildroot==========
TARGET_BUILDROOT_CONFIG=alientek_rv1126
Top of tree: /home/horn/03_RV1126/SDK
#TARGET_BOARD=rv1126
#OUTPUT_DIR=output/alientek_rv1126
#CONFIG=alientek_rv1126_defconfig
make: Entering directory '/home/horn/03_RV1126/SDK/buildroot'
  GEN     /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/Makefile
/home/horn/03_RV1126/SDK/buildroot/build/defconfig_hook.py -m /home/horn/03_RV1126/SDK/buildroot/configs/alientek_rv1126_defconfig /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig
BR2_DEFCONFIG='' KCONFIG_AUTOCONFIG=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build/buildroot-config/tristate.config BR2_CONFIG=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.config HOST_GCC_VERSION="9" BUILD_DIR=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build SKIP_LEGACY= BR2_DEFCONFIG=/home/horn/03_RV1126/SDK/buildroot/configs/alientek_rv1126_defconfig /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build/buildroot-config/conf --defconfig=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig Config.in
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:142:warning: override: reassigning to symbol BR2_PACKAGE_RKWIFIBT
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:179:warning: override: reassigning to symbol BR2_PACKAGE_UPDATE
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:185:warning: override: reassigning to symbol BR2_PACKAGE_RKSCRIPT
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:208:warning: override: reassigning to symbol BR2_TARGET_GENERIC_HOSTNAME
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:209:warning: override: reassigning to symbol BR2_TARGET_GENERIC_ISSUE
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:210:warning: override: reassigning to symbol BR2_TARGET_GENERIC_ROOT_PASSWD
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:235:warning: override: reassigning to symbol BR2_PACKAGE_ALSA_UTILS
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:236:warning: override: reassigning to symbol BR2_PACKAGE_ALSA_UTILS_ALSACONF
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:237:warning: override: reassigning to symbol BR2_PACKAGE_ALSA_UTILS_AMIXER
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:238:warning: override: reassigning to symbol BR2_PACKAGE_ALSA_UTILS_APLAY
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:239:warning: override: reassigning to symbol BR2_PACKAGE_ALSA_PLUGINS
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:240:warning: override: reassigning to symbol BR2_PACKAGE_LIBMAD
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:243:warning: override: reassigning to symbol BR2_PACKAGE_ALSA_CONFIG
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:251:warning: override: reassigning to symbol BR2_PACKAGE_LIBV4L
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:252:warning: override: reassigning to symbol BR2_PACKAGE_LIBV4L_UTILS
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:253:warning: override: reassigning to symbol BR2_PACKAGE_CAMERA_ENGINE
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:315:warning: override: reassigning to symbol BR2_PACKAGE_MPP
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:316:warning: override: reassigning to symbol BR2_PACKAGE_MPP_ALLOCATOR_DRM
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:318:warning: override: reassigning to symbol BR2_PACKAGE_LINUX_RGA
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:343:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_GOOD_PLUGIN_RTP
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:344:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_GOOD_PLUGIN_RTPMANAGER
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:345:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_GOOD_PLUGIN_RTSP
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:351:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_VIDEORATE
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:352:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_VORBIS
/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.rockchipconfig:353:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_OGG
# configuration written to /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/.config
make: Leaving directory '/home/horn/03_RV1126/SDK/buildroot'
2023-03-06T15:46:34 >>> fdk-aac 0.1.5 Extracting
Done in 3s  (error code: 2)
log saved on /home/horn/03_RV1126/SDK/br.log
2023-03-06T15:40:16 The filesystem on /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/images/rootfs.ext2 is now 21139 (4k) blocks long.
2023-03-06T15:40:16
2023-03-06T15:40:16 >>>   Generating root filesystem image rootfs.squashfs
2023-03-06T15:40:16 rm -rf /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs
2023-03-06T15:40:16 mkdir -p /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs
2023-03-06T15:40:16 echo '#!/bin/sh' > /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:16 echo "set -e" >> /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:16 echo "chown -h -R 0:0 /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target" >> /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:16 printf '           - - input -1 * - - - Input device groupnn' >> /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/users_table.txt
2023-03-06T15:40:16 PATH="/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/bin:/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/horn/03_RV1126/SDK/buildroot/support/scripts/mkusers /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/users_table.txt /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target >> /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:16 cat system/device_table.txt > /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/device_table.txt
2023-03-06T15:40:16 printf '           /bin/busybox                     f 4755 0  0 - - - - -n /dev/console c 622 0 0 5 1 - - -nn' >> /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/device_table.txt
2023-03-06T15:40:16 echo "/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/bin/makedevs -d /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/device_table.txt /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target" >> /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:16 printf '           /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/bin/mksquashfs /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/images/rootfs.squashfs -noappend -processors 5 -comp gzipn' >> /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:16 chmod a+x /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:16 rm -f /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
2023-03-06T15:40:16 PATH="/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/bin:/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/bin/fakeroot -- /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:16 rootdir=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target
2023-03-06T15:40:16 table='/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/device_table.txt'
2023-03-06T15:40:16 Parallel mksquashfs: Using 5 processors
2023-03-06T15:40:16 Creating 4.0 filesystem on /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/images/rootfs.squashfs, block size 131072.
[============================================================================================================================/] 327/327 100%
2023-03-06T15:40:16
2023-03-06T15:40:16 Exportable Squashfs 4.0 filesystem, gzip compressed, data block size 131072
2023-03-06T15:40:16 compressed data, compressed metadata, compressed fragments, compressed xattrs
2023-03-06T15:40:16 duplicates are removed
2023-03-06T15:40:16 Filesystem size 6303.19 Kbytes (6.16 Mbytes)
2023-03-06T15:40:16 40.82% of uncompressed filesystem size (15440.42 Kbytes)
2023-03-06T15:40:16 Inode table size 6041 bytes (5.90 Kbytes)
2023-03-06T15:40:16 24.39% of uncompressed inode table size (24764 bytes)
2023-03-06T15:40:16 Directory table size 6943 bytes (6.78 Kbytes)
2023-03-06T15:40:16 55.06% of uncompressed directory table size (12610 bytes)
2023-03-06T15:40:16 Number of duplicate files found 13
2023-03-06T15:40:16 Number of inodes 690
2023-03-06T15:40:16 Number of files 242
2023-03-06T15:40:16 Number of fragments 28
2023-03-06T15:40:16 Number of symbolic links  361
2023-03-06T15:40:16 Number of device nodes 1
2023-03-06T15:40:16 Number of fifo nodes 0
2023-03-06T15:40:16 Number of socket nodes 0
2023-03-06T15:40:16 Number of directories 86
2023-03-06T15:40:16 Number of ids (unique uids + gids) 2
2023-03-06T15:40:16 Number of uids 2
2023-03-06T15:40:16 root (0)
2023-03-06T15:40:16 www-data (33)
2023-03-06T15:40:16 Number of gids 2
2023-03-06T15:40:16 /usr/bin/install -m 0644 support/misc/target-dir-warning.txt /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
2023-03-06T15:40:16 >>>   Generating root filesystem image rootfs.tar
2023-03-06T15:40:17 printf '           /bin/busybox                     f 4755 0  0 - - - - -n /dev/console c 622 0 0 5 1 - - -nn' >> /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/device_table.txt
2023-03-06T15:40:17 echo "/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/bin/makedevs -d /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/device_table.txt /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target" >> /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:17 printf '           (cd /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target; find -print0 | LC_ALL=C sort -z | tar  -cf /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/images/rootfs.tar --null --no-recursion -T - --numeric-owner)n' >> /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:17 chmod a+x /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:17 rm -f /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
2023-03-06T15:40:17 PATH="/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/bin:/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/host/bin/fakeroot -- /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/fakeroot.fs
2023-03-06T15:40:17 rootdir=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target
2023-03-06T15:40:17 table='/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/build/buildroot-fs/device_table.txt'
2023-03-06T15:40:17 /usr/bin/install -m 0644 support/misc/target-dir-warning.txt /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126_recovery/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
2023-03-06T15:43:19 umask 0022 && make -C /home/horn/03_RV1126/SDK/buildroot O=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126
2023-03-06T15:43:22 /usr/bin/make -j1 O=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126 HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" silentoldconfig
2023-03-06T15:43:22 GEN     /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/Makefile
2023-03-06T15:43:22 >>> fdk-aac 0.1.5 Extracting
2023-03-06T15:43:22 gzip -d -c /home/horn/03_RV1126/SDK/buildroot/dl/fdk-aac-0.1.5.tar.gz | /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar --strip-components=1 -C /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build/fdk-aac-0.1.5   -xf -
2023-03-06T15:43:22
2023-03-06T15:43:22 gzip: /home/horn/03_RV1126/SDK/buildroot/dl/fdk-aac-0.1.5.tar.gz: not in gzip format
2023-03-06T15:43:22 /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar: This does not look like a tar archive
2023-03-06T15:43:22 /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar: Exiting with failure status due to previous errors
2023-03-06T15:43:22 make[1]: *** [package/pkg-generic.mk:163: /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build/fdk-aac-0.1.5/.stamp_extracted] Error 2
2023-03-06T15:43:22 make: *** [/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/Makefile:16: _all] Error 2
2023-03-06T15:44:19 umask 0022 && make -C /home/horn/03_RV1126/SDK/buildroot O=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126
2023-03-06T15:44:22 /usr/bin/make -j1 O=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126 HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" silentoldconfig
2023-03-06T15:44:22 GEN     /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/Makefile
2023-03-06T15:44:22 >>> fdk-aac 0.1.5 Extracting
2023-03-06T15:44:22 gzip -d -c /home/horn/03_RV1126/SDK/buildroot/dl/fdk-aac-0.1.5.tar.gz | /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar --strip-components=1 -C /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build/fdk-aac-0.1.5   -xf -
2023-03-06T15:44:22
2023-03-06T15:44:22 gzip: /home/horn/03_RV1126/SDK/buildroot/dl/fdk-aac-0.1.5.tar.gz: not in gzip format
2023-03-06T15:44:22 /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar: This does not look like a tar archive
2023-03-06T15:44:22 /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar: Exiting with failure status due to previous errors
2023-03-06T15:44:22 make[1]: *** [package/pkg-generic.mk:163: /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build/fdk-aac-0.1.5/.stamp_extracted] Error 2
2023-03-06T15:44:22 make: *** [/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/Makefile:16: _all] Error 2
2023-03-06T15:46:31 umask 0022 && make -C /home/horn/03_RV1126/SDK/buildroot O=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126
2023-03-06T15:46:34 /usr/bin/make -j1 O=/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126 HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" silentoldconfig
2023-03-06T15:46:34 GEN     /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/Makefile
2023-03-06T15:46:34 gzip -d -c /home/horn/03_RV1126/SDK/buildroot/dl/fdk-aac-0.1.5.tar.gz | /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar --strip-components=1 -C /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build/fdk-aac-0.1.5   -xf -
2023-03-06T15:46:34
2023-03-06T15:46:34 gzip: /home/horn/03_RV1126/SDK/buildroot/dl/fdk-aac-0.1.5.tar.gz: not in gzip format
2023-03-06T15:46:34 /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar: This does not look like a tar archive
2023-03-06T15:46:34 /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/host/bin/tar: Exiting with failure status due to previous errors
2023-03-06T15:46:34 make[1]: *** [package/pkg-generic.mk:163: /home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/build/fdk-aac-0.1.5/.stamp_extracted] Error 2
2023-03-06T15:46:34 make: *** [/home/horn/03_RV1126/SDK/buildroot/output/alientek_rv1126/Makefile:16: _all] Error 2
Command exited with non-zero status 1
you take 0:03.53 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 563:
    /usr/bin/time -f "you take %E to build builroot" $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
问题解决了,在视频里面有强调必须要先使用 ./build.sh 全编译一遍,PDF中看不到文字强调。
113
113
2019-11-27
22 小时
 楼主| 发表于 2023-3-6 15:50:26 | 显示全部楼层
GMT+8, 2026-10-30 09:22
