查看: 2692|回复: 4
求助:使用原子提供虚拟机系统镜像文件SDK包依然编译失败
203
203
2014-3-15
55 小时
发表于 2023-4-9 19:39:56 | 显示全部楼层 |阅读模式
30金钱
2023-04-09T19:33:58 >>> bzip2 1.0.6 Downloading
2023-04-09T19:33:58 --2023-04-09 19:33:58--  http://www.bzip.org/1.0.6/bzip2-1.0.6.tar.gz
2023-04-09T19:33:59 Resolving www.bzip.org (www.bzip.org)... 87.98.154.146
2023-04-09T19:33:59 Connecting to www.bzip.org (www.bzip.org)|87.98.154.146|:80... connected.
2023-04-09T19:33:59 HTTP request sent, awaiting response... 301 Moved Permanently
2023-04-09T19:33:59 Location: http://www.bzip.org [following]
2023-04-09T19:33:59 --2023-04-09 19:33:59--  http://www.bzip.org/
2023-04-09T19:33:59 Reusing existing connection to www.bzip.org:80.
2023-04-09T19:34:00 HTTP request sent, awaiting response... 200 OK
2023-04-09T19:34:00 Length: unspecified [text/html]
2023-04-09T19:34:00 Saving to: '/home/alientek/sdk/buildroot/output/alientek_rv1126/build/.bzip2-1.0.6.tar.gz.yqjYbf/output'
2023-04-09T19:34:00
/home/alientek/sdk/buildroot/output/alientek_rv112     [  <=>        ]  15.79K  51.5KB/s    in 0.3s
2023-04-09T19:34:00
2023-04-09T19:34:00 2023-04-09 19:34:00 (51.5 KB/s) - '/home/alientek/sdk/buildroot/output/alientek_rv1126/build/.bzip2-1.0.6.tar.gz.yqjYbf/output' saved [16171]
2023-04-09T19:34:00
2023-04-09T19:34:00 >>> bzip2 1.0.6 Extracting
2023-04-09T19:34:00 gzip -d -c /home/alientek/sdk/buildroot/dl/bzip2-1.0.6.tar.gz | /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/tar --strip-components=1 -C /home/alientek/sdk/buildroot/output/alientek_rv1126/build/bzip2-1.0.6   -xf -
2023-04-09T19:34:00
2023-04-09T19:34:00 gzip: /home/alientek/sdk/buildroot/dl/bzip2-1.0.6.tar.gz: not in gzip format
2023-04-09T19:34:00 /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/tar: This does not look like a tar archive
2023-04-09T19:34:00 /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/tar: Exiting with failure status due to previous errors
2023-04-09T19:34:00 make[1]: *** [package/pkg-generic.mk:163: /home/alientek/sdk/buildroot/output/alientek_rv1126/build/bzip2-1.0.6/.stamp_extracted] Error 2
2023-04-09T19:34:00 make: *** [/home/alientek/sdk/buildroot/output/alientek_rv1126/Makefile:16: _all] Error 2
Command exited with non-zero status 1
you take 1:43.25 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 563:
    /usr/bin/time -f "you take %E to build builroot" $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
dl压缩包没解压对,或者没解压导致的
888
2397
2397
2019-9-25
398 小时
发表于 2023-4-9 19:39:57 | 显示全部楼层
二营长v 发表于 2023-4-19 22:58
老兄是什么原因编译失败的?怎么解决的呢?
dl压缩包没解压对,或者没解压导致的
203
203
2014-3-15
55 小时
 楼主| 发表于 2023-4-9 23:50:23 | 显示全部楼层
已解决
203
203
2014-3-15
55 小时
 楼主| 发表于 2023-4-9 23:51:03 | 显示全部楼层
2023-4-19
发表于 2023-4-19 22:58:38 | 显示全部楼层
GMT+8, 2026-10-30 21:15
