查看: 8305|回复: 0
关于STM32H7X主控芯片,SPI+DMA中断发送接受的学习问题
2023-4-27
发表于 2023-4-27 19:36:35 | 显示全部楼层 |阅读模式
1.SPI通过硬件片选的方式自动收发数据,不加DMA是没有问题的,加DMA收发数据失败;
2.DMA配置为0,1,2,3通道,分别是内存->SPI1;SPI1->内存;SPI2->内存;内存->SPI2;
3.一调用发送函数,每次进DMA1_Steream2中断中,写了两天没信心了。。
配置及收发函数如下,跪求大佬指导;
  1. <blockquote>#define SPI1_DMA_TX_STREAM      DMA1_Stream0
//SPI_DMA  发送/接收;
void SPI_TransmitReceive(uint8_t Axis,  uint8_t *pTxData, uint8_t *pRxData,uint16_t Size)
        if((pTxData ==NULL) || (pRxData ==NULL) || (Size ==0UL))return ;
        volatile SPI_TypeDef* pSpi = Axises[Axis];
        uint8_t TxCnt = Size;uint8_t RxCnt = Size;
        uint32_t i=0;
        //禁止DMA1传输
        DMA1_Stream0->CR &=  ~DMA_SxCR_EN; DMA1_Stream1->CR &=  ~DMA_SxCR_EN; DMA1_Stream2->CR &=  ~DMA_SxCR_EN; DMA1_Stream3->CR &=  ~DMA_SxCR_EN;
        SPI1_DMA_TX_STREAM->NDTR = 0x00000000;
        SPI1_DMA_TX_STREAM->NDTR = BUFFER  ;
        SPI2_DMA_TX_STREAM->NDTR = 0x00000000;
        SPI2_DMA_TX_STREAM->NDTR = BUFFER  ;
        SPI2_DMA_RX_STREAM->NDTR = 0x00000000;                                  //传输长度
        SPI2_DMA_RX_STREAM->NDTR = BUFFER  ;
        //SPI1 ->Stream0      存储器地址                                  外设地址
        DMA1_Stream0->M0AR = *(__IO uint32_t*)pTxData;        DMA1_Stream0->PAR = pSpi->TXDR;
        //SPI1 ->Stream1           外设地址                                        存储器地址
        DMA1_Stream1->PAR = *(uint32_t*)pSpi->RXDR;                DMA1_Stream1->M0AR = *(__IO uint32_t*)pRxData;
    //SPI2 ->Stream2      存储器地址                                  外设地址
        DMA1_Stream2->M0AR = *(__IO uint32_t*)pTxData;        DMA1_Stream2->PAR = pSpi->TXDR;
        //SPI2 ->Stream3      外设地址                                        存储器地址
        DMA1_Stream3->PAR = *(uint32_t*)pSpi->RXDR;                DMA1_Stream3->M0AR = *(__IO uint32_t*)pRxData;
        DMA1_Stream0->CR |=  DMA_SxCR_TCIE; DMA1_Stream1->CR |=  DMA_SxCR_TCIE;DMA1_Stream2->CR |=  DMA_SxCR_TCIE;DMA1_Stream3->CR |=  DMA_SxCR_TCIE;
//        pSpi->CR2  = 5;     //TSIZE
        /* Enable EOT, DXP, UDR, OVR, FRE, MODF and TSERF interrupts */
//        pSpi->IER |= SPI_IER_EOTIE | SPI_IER_DXPIE | SPI_IER_UDRIE | SPI_IER_OVRIE | SPI_IER_TIFREIE |SPI_IER_MODFIE |SPI_IER_TSERFIE;
        pSpi->RXDR;
        //主机发送打开
        pSpi->CR1 |= SPI_CR1_CSTART;
        //使能DMA1传输  //开始传输
        while((pSpi->SR & SPI_SR_TXP) == 0);
        DMA1_Stream0->CR |=  DMA_SxCR_EN;
        DMA1_Stream1->CR |=  DMA_SxCR_EN;
        DMA1_Stream2->CR |=  DMA_SxCR_EN;
        DMA1_Stream3->CR |=  DMA_SxCR_EN;
        while((DMA1->LISR & DMA_LISR_TCIF0 )==0 || (DMA1->LISR & DMA_LISR_TCIF1 )==0 || (DMA1->LISR & DMA_LISR_TCIF2 )==0
                || (DMA1->LISR & DMA_LISR_TCIF3 )==0 ){};
        //DMA1_Stream0->NDTR -= 1;  DMA1_Stream1->NDTR |= 1;DMA1_Stream2->NDTR -= 1;DMA1_Stream3->NDTR -= 1;  //传输长度
//        while((TxCnt >0)||(RxCnt > 0))
//                if((pSpi->SR & SPI_SR_TXP) && (TxCnt > 0))
//                        *((__IO uint8_t *)pSpi->TXDR) = *((const uint8_t *)pTxData);
//                         TxCnt--;
//                if((pSpi->SR & SPI_SR_RXP) && (RxCnt > 0))
//                        *(( uint8_t *)pRxData) = *((__IO uint8_t *)pSpi->RXDR);
//                        RxCnt--;
//                if(i > 29999)break;
//                i++;
    pSpi->IFCR = (SPI_IFCR_EOTC | SPI_IFCR_TXTFC) ;
uint32_t XX_DMA_WR(uint8_t Axis, uint8_t Addr, uint32_t Value)
         uint8_t TDate[5] = {0}; uint8_t RDate[5] = {0};
         TDate[0] = Addr | 0x80;
         TDate[1] = Value >> 24 ;
         TDate[2] = (Value >> 16) & 0xFF ;
         TDate[3] = (Value >> 8) & 0xFF;
         TDate[4] = Value & 0xFF ;
         SPI_TransmitReceive(Axis, TDate, RDate,5);
         Value |= RDate[1] << 24;
         Value |= RDate[2] << 16;
         Value |= RDate[3] << 8;
         Value |= RDate[4];
        return Value;
GMT+8, 2026-11-30 16:33
