查看: 4004|回复: 7
RV1126编译sdk报错,求助SOS
2023-6-24
发表于 2023-6-24 03:18:00 | 显示全部楼层 |阅读模式
第一次编译RV1126 sdk遇到这个报错,应该怎么解决呢
2023-06-24T03:04:53 /usr/bin/sed -i -e 's,@STAGING_SUBDIR@,arm-buildroot-linux-gnueabihf/sysroot,g' /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/pkg-config
2023-06-24T03:04:53 /usr/bin/sed -i -e 's,@STATIC@,,' /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/pkg-config
2023-06-24T03:04:53 >>> bzip2 1.0.6 Downloading
2023-06-24T03:04:53 --2023-06-24 03:04:53--  http://www.bzip.org/1.0.6/bzip2-1.0.6.tar.gz
2023-06-24T03:04:53 Resolving www.bzip.org (www.bzip.org)... 87.98.154.146
2023-06-24T03:04:54 Connecting to www.bzip.org (www.bzip.org)|87.98.154.146|:80... connected.
2023-06-24T03:04:54 HTTP request sent, awaiting response... 301 Moved Permanently
2023-06-24T03:04:54 Location: http://www.bzip.org [following]
2023-06-24T03:04:54 --2023-06-24 03:04:54--  http://www.bzip.org/
2023-06-24T03:04:54 Reusing existing connection to www.bzip.org:80.
2023-06-24T03:04:54 HTTP request sent, awaiting response... 200 OK
2023-06-24T03:04:54 Length: unspecified [text/html]
2023-06-24T03:04:54 Saving to: '/home/alientek/sdk/buildroot/output/alientek_rv1126/build/.bzip2-1.0.6.tar.gz.gzj7LU/output'
2023-06-24T03:04:54
/home/alientek/sdk/buildroot/output/alientek_     [ <=>        ]  15.79K  96.8KB/s    in 0.2s
2023-06-24T03:04:54
2023-06-24T03:04:54 2023-06-24 03:04:54 (96.8 KB/s) - '/home/alientek/sdk/buildroot/output/alientek_rv1126/build/.bzip2-1.0.6.tar.gz.gzj7LU/output' saved [16171]
2023-06-24T03:04:54
2023-06-24T03:04:54 >>> bzip2 1.0.6 Extracting
2023-06-24T03:04:54 gzip -d -c /home/alientek/sdk/buildroot/dl/bzip2-1.0.6.tar.gz | /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/tar --strip-components=1 -C /home/alientek/sdk/buildroot/output/alientek_rv1126/build/bzip2-1.0.6   -xf -
2023-06-24T03:04:54
2023-06-24T03:04:54 gzip: /home/alientek/sdk/buildroot/dl/bzip2-1.0.6.tar.gz: not in gzip format
2023-06-24T03:04:54 /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/tar: This does not look like a tar archive
2023-06-24T03:04:54 /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/tar: Exiting with failure status due to previous errors
2023-06-24T03:04:54 make[1]: *** [package/pkg-generic.mk:163: /home/alientek/sdk/buildroot/output/alientek_rv1126/build/bzip2-1.0.6/.stamp_extracted] Error 2
2023-06-24T03:04:54 make: *** [/home/alientek/sdk/buildroot/output/alientek_rv1126/Makefile:16: _all] Error 2
2023-06-24T03:10:41 umask 0022 && make -C /home/alientek/sdk/buildroot O=/home/alientek/sdk/buildroot/output/alientek_rv1126
2023-06-24T03:10:49 /usr/bin/make -j1 O=/home/alientek/sdk/buildroot/output/alientek_rv1126 HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" silentoldconfig
2023-06-24T03:10:49 GEN     /home/alientek/sdk/buildroot/output/alientek_rv1126/Makefile
2023-06-24T03:10:49 >>> bzip2 1.0.6 Extracting
2023-06-24T03:10:49 gzip -d -c /home/alientek/sdk/buildroot/dl/bzip2-1.0.6.tar.gz | /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/tar --strip-components=1 -C /home/alientek/sdk/buildroot/output/alientek_rv1126/build/bzip2-1.0.6   -xf -
2023-06-24T03:10:49
2023-06-24T03:10:49 gzip: /home/alientek/sdk/buildroot/dl/bzip2-1.0.6.tar.gz: not in gzip format
2023-06-24T03:10:49 /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/tar: This does not look like a tar archive
2023-06-24T03:10:49 /home/alientek/sdk/buildroot/output/alientek_rv1126/host/bin/tar: Exiting with failure status due to previous errors
2023-06-24T03:10:49 make[1]: *** [package/pkg-generic.mk:163: /home/alientek/sdk/buildroot/output/alientek_rv1126/build/bzip2-1.0.6/.stamp_extracted] Error 2
2023-06-24T03:10:49 make: *** [/home/alientek/sdk/buildroot/output/alientek_rv1126/Makefile:16: _all] Error 2
Command exited with non-zero status 1
you take 0:09.22 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 563:
    /usr/bin/time -f "you take %E to build builroot" $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
888
2397
2397
2019-9-25
398 小时
发表于 2023-6-29 09:38:59 | 显示全部楼层
按照教程或者视频的操作步骤解压所提供的dl压缩包了吗
2023-7-17
发表于 2023-7-17 16:44:05 | 显示全部楼层
解决了吗?
72
355
355
2020-7-30
50 小时
发表于 2023-8-10 03:26:36 来自手机 | 显示全部楼层
This does not look like a tar archive。网络问题,换一个网速快的地方试试。
888
2397
2397
2019-9-25
398 小时
发表于 2023-8-12 09:29:48 | 显示全部楼层
可以看一下这个链接,总结出来一些注意事项了:
https://www.openedv.com/thread-344583-1-1.html
2023-9-23
发表于 2023-9-24 00:30:49 来自手机 | 显示全部楼层
我也是报这个错
2023-10-8
发表于 2023-10-8 13:39:51 | 显示全部楼层
我也遇到这样的问题。和ubuntu版本有关。用ubuntu 22.04,  ubuntu 20.04都会报错。用ubuntu 18.04就完全不报错了。
2023-11-15
发表于 2023-11-15 17:19:38 | 显示全部楼层
使用ubuntu 20.04编译成功,CPU是12100F,虚拟机分配4核心,实际配置文档分配2核,虚拟机分配16G内存,编译时间可能3个多小时(挂后台没细看)
1: SDK的编译依赖包要安装需要优先成功安装 (我最早手工输入 有内容漏掉,后面导致依赖包出问题)
sudo apt-get install device-tree-compiler git-core u-boot-tools mtools parted libudev-dev
sudo apt-get install libusb-1.0-0-dev autoconf autotools-dev libsigsegv2 m4 intltool libdrm-dev
sudo apt-get install curl sed make binutils build-essential gcc g++ bash patch gzip gawk bzip2
sudo apt-get install perl tar cpio python unzip rsync file bc wget libncurses5 libglib2.0-dev
sudo apt-get install libgtk2.0-dev libglade2-dev cvs git mercurial openssh-client subversion
sudo apt-get install asciidoc w3m dblatex graphviz libc6:i386 libssl-dev expect fakeroot cmake
sudo apt-get install flex bison liblz4-tool libtool keychain net-tools adb lib32gcc-7-dev g++-7
sudo apt-get install libstdc++-7-dev libncurses5-dev libncursesw5-dev openssh-server
2. SDK解压后,再“buildroot”目录下建立dl目录,并将【正点原子】RV1126 AI开发板资料(A盘)-基础资料\01、程序源码\01、程序源码\02、buildroot下载源码包下的 dl.tar文件解压至dl目录下
3.   ./build.sh lunch 选择板级信息,再编译SDK.
上述信息供参考
GMT+8, 2026-10-30 21:15
