查看: 2418|回复: 1
RV1126编译SDK报错怎么修改?
2023-7-17
发表于 2023-7-17 16:48:57 | 显示全部楼层 |阅读模式
2023-07-17T16:24:29 arm-linux-gnueabihf-g++: fatal error: Killed signal terminated program cc1plus
2023-07-17T16:24:29 compilation terminated.
2023-07-17T16:24:29 Makefile:26509: recipe for target '.obj/src/mbgl/renderer/layers/render_fill_extrusion_layer.o' failed
2023-07-17T16:24:29 make[6]: *** [.obj/src/mbgl/renderer/layers/render_fill_extrusion_layer.o] Error 1
2023-07-17T16:24:29 make[6]: *** Waiting for unfinished jobs....
2023-07-17T16:24:53 Makefile:202: recipe for target 'sub-------3rdparty-mapbox-gl-native-make_first' failed
2023-07-17T16:24:53 make[5]: *** [sub-------3rdparty-mapbox-gl-native-make_first] Error 2
2023-07-17T16:24:53 Makefile:72: recipe for target 'sub-geoservices-make_first' failed
2023-07-17T16:24:53 make[4]: *** [sub-geoservices-make_first] Error 2
2023-07-17T16:24:53 Makefile:233: recipe for target 'sub-plugins-make_first' failed
2023-07-17T16:24:53 make[3]: *** [sub-plugins-make_first] Error 2
2023-07-17T16:24:53 Makefile:48: recipe for target 'sub-src-make_first' failed
2023-07-17T16:24:53 make[2]: *** [sub-src-make_first] Error 2
2023-07-17T16:24:53 package/pkg-generic.mk:228: recipe for target '/home/mimi/RV1126/sdk/buildroot/output/alientek_rv1126/build/qt5location-5.12.2/.stamp_built' failed
2023-07-17T16:24:53 make[1]: *** [/home/mimi/RV1126/sdk/buildroot/output/alientek_rv1126/build/qt5location-5.12.2/.stamp_built] Error 2
2023-07-17T16:24:57 /home/mimi/RV1126/sdk/buildroot/output/alientek_rv1126/Makefile:16: recipe for target '_all' failed
2023-07-17T16:24:57 make: *** [_all] Error 2
Command exited with non-zero status 1
you take 2:31:52 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 563:
    /usr/bin/time -f "you take %E to build builroot" $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
888
2397
2397
2019-9-25
398 小时
发表于 2023-7-18 14:48:32 | 显示全部楼层
这是编译到文件系统buildroot就报错了
你这是一键编译的?还是单独编译的?
我建议你先试试一键编译,参考这个帖子的步骤来:
https://www.openedv.com/forum.php ... &extra=page%3D1
就看我回复的那个信息,详细操作步骤
GMT+8, 2026-10-30 21:50
