查看: 4198|回复: 1
LCD驱动:测试程序modetest点亮失败
78
78
2021-11-11
发表于 2023-7-29 15:21:42 | 显示全部楼层 |阅读模式
打印如下
[root@RenJingYao]:~$ modetest
trying to open device 'i915'...failed
trying to open device 'amdgpu'...failed
trying to open device 'radeon'...failed
trying to open device 'nouveau'...failed
trying to open device 'vmwgfx'...failed
trying to open device 'omapdrm'...failed
trying to open device 'exynos'...failed
trying to open device 'tilcdc'...failed
trying to open device 'msm'...failed
trying to open device 'sti'...failed
trying to open device 'tegra'...failed
trying to open device 'imx-drm'...failed
trying to open device 'rockchip'...failed
trying to open device 'atmel-hlcdc'...failed
trying to open device 'fsl-dcu-drm'...failed
trying to open device 'vc4'...failed
trying to open device 'virtio_gpu'...failed
trying to open device 'mediatek'...failed
trying to open device 'meson'...failed
trying to open device 'pl111'...failed
trying to open device 'stm'...done
Encoders:
id      crtc    type    possible crtcs  possible clones
31      35      DPI     0x00000001      0x00000000
Connectors:
id      encoder status          name            size (mm)       modes   encoders
32      31      connected       DPI-1           0x0             1       31
  modes:
        index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot
  #0 800x480 64.62 800 888 936 976 480 512 515 528 33300 flags: ; type: preferred, driver
  props:
        1 EDID:
                flags: immutable blob
                blobs:
                value:
        2 DPMS:
                flags: enum
                enums: On=0 Standby=1 Suspend=2 Off=3
                value: 0
        5 link-status:
                flags: enum
                enums: Good=0 Bad=1
                value: 0
        6 non-desktop:
                flags: immutable range
                values: 0 1
                value: 0
        4 TILE:
                blobs:
                value:
CRTCs:
id      fb      pos     size
35      38      (0,0)   (800x480)
  props:
        24 VRR_ENABLED:
                flags: range
                values: 0 1
                value: 0
        28 GAMMA_LUT:
                flags: blob
                blobs:
                value:
        29 GAMMA_LUT_SIZE:
                values: 0 4294967295
                value: 256
Planes:
id      crtc    fb      CRTC x,y        x,y     gamma size      possible crtcs
33      35      38      0,0             0,0     0               0x00000001
  formats: AR24 XR24 RG24 RG16 AR15 XR15 AR12 XR12 C8
  props:
        8 type:
                flags: immutable enum
                enums: Overlay=0 Primary=1 Cursor=2
                value: 1
        30 IN_FORMATS:
                blobs:
                value:
                        01000000000000000900000018000000
                        01000000400000004152323458523234
                        52473234524731364152313558523135
                        41523132585231324338202000000000
                        ff010000000000000000000000000000
                        0000000000000000
                in_formats blob decoded:
                         AR24:  LINEAR
                         XR24:  LINEAR
                         RG24:  LINEAR
                         RG16:  LINEAR
                         AR15:  LINEAR
                         XR15:  LINEAR
                         AR12:  LINEAR
                         XR12:  LINEAR
                         C8:  LINEAR
36      0       0       0,0             0,0     0               0x00000001
  formats: AR24 RG24 RG16 AR15 AR12 C8
  props:
        8 type:
                value: 0
        30 IN_FORMATS:
                blobs:
                value:
                        01000000000000000600000018000000
                        01000000300000004152323452473234
                        52473136415231354152313243382020
                        3f000000000000000000000000000000
                        0000000000000000
                         AR24:  LINEAR
                         RG24:  LINEAR
                         RG16:  LINEAR
                         AR15:  LINEAR
                         AR12:  LINEAR
                         C8:  LINEAR
Frame buffers:
id      size    pitch
78
78
2021-11-11
 楼主| 发表于 2023-7-29 15:22:32 | 显示全部楼层
按照教程输入命令,modetest无法点亮LCD屏幕
GMT+8, 2026-11-3 10:51
