查看: 5615|回复: 2
[XILINX] petalinux2018.3在uboot中动态加载bit文件出现的问题
82
82
2019-11-18
15 小时
发表于 2023-9-1 18:15:53 | 显示全部楼层 |阅读模式
第一步修改platform-top.h文件如下:
#include <configs/platform-auto.h>
#define CONFIG_FPGA_ZYNQPL
#define CONFIG_SYS_BOOTM_LEN 0xF000000
#define DFU_ALT_INFO_RAM \
        "dfu_ram_info=" \
    "setenv dfu_alt_info " \
        "bitstream_bit=system.bit\0"        \
        "bitstream=system.bit\0"        \
        "loadbit_addr=0x100000\0"        \
        "mmc_loadbit=echo Loading bitstream from SD/MMC/eMMC to RAM.. && " \
                "mmcinfo && " \
                "load mmc 0 ${loadbit_addr} ${bitstream} && " \
                "fpga loadb 0 ${loadbit_addr} ${filesize}\0" \
    "image.ub ram $netstart 0x1e00000\0" \
    "dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" \
    "thor_ram=run dfu_ram_info && thordown 0 ram 0\0"
#define DFU_ALT_INFO_MMC \
    "dfu_mmc_info=" \
    "set dfu_alt_info " \
    "${kernel_image} fat 0 1\\\\;" \
    "dfu_mmc=run dfu_mmc_info && dfu 0 mmc 0\0" \
    "thor_mmc=run dfu_mmc_info && thordown 0 mmc 0\0"
/*Required for uartless designs */
#ifndef CONFIG_BAUDRATE
#define CONFIG_BAUDRATE 115200
#ifdef CONFIG_DEBUG_UART
#undef CONFIG_DEBUG_UART
#endif
#endif
/*Define CONFIG_ZYNQ_EEPROM here and its necessaries in u-boot menuconfig if you had EEPROM memory. */
#ifdef CONFIG_ZYNQ_EEPROM
#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN     1
#define CONFIG_SYS_I2C_EEPROM_ADDR       0x54
#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS   4
#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
#define CONFIG_SYS_EEPROM_SIZE         1024 /* Bytes */
#define CONFIG_SYS_I2C_MUX_ADDR        0x74
#define CONFIG_SYS_I2C_MUX_EEPROM_SEL     0x4
#endif
#define CONFIG_BOOTCOMMAND        "run mmc_loadbit; run default_bootcmd"&#8203;
第二步 重新编译
petalinux-build&#8203;
第三步生成BOOT.BIN
petalinux-package --boot --fsbl --u-boot --force
第四步 拷贝BOOT.BIN image.ub system.bit到sd卡&#8203;
问题是进入uboot时候用run mmc_loadbit提示:
error: "mmc_loadbit" not defined
为什么会出现未定义错误,,不是在platform-top.h中定义了吗?
                "mmcinfo && " \
请问是哪儿出现了错误?
2021-12-1
发表于 2024-8-28 19:48:22 | 显示全部楼层
在这里修改:project-spec/meta-plnx-generated/recipes-bsp/u-boot/configs/platform-auto.h         <       "mmc_loadbit=mmcinfo && fatload mmc ${sdbootdev}:1 0x10000000 system.bit && fpga loadb 0 0x10000000 ${filesize} \0" \         <       "default_bootcmd=run uenvboot;run mmc_loadbit; run cp_kernel2ram && bootm ${netstart}\0" \         ---         >       "default_bootcmd=run uenvboot; run cp_kernel2ram && bootm ${netstart}\0" \
2021-12-1
发表于 2024-8-29 09:13:30 | 显示全部楼层
拷贝platform-auto.h文件中的CONFIG_EXTRA_ENV_SETTINGS块到platform-top.h文件,在CONFIG_EXTRA_ENV_SETTINGS 添加你的mmc_loadbit
GMT+8, 2026-10-31 14:18
