查看: 3955|回复: 1
求助!!!有大佬做过开发板跑Qt然后用VNC远程同步显示控制
38
331
331
2022-4-12
42 小时
发表于 2023-11-2 17:15:37 | 显示全部楼层 |阅读模式
10金钱
有大佬做过开发板跑Qt,然后电脑用VNC同步显示控制吗?????目前用正点原子的出厂文件系统 ,启动qt应用指令如下
./qt_app -platform vnc:size=1024x600,port=5900
开发板屏幕不显示Qt界面,但是用vnc viewer可以查看也可以操作
用x11vnc,提示XOpenDisplay(":0.0") failed.,
网上有人说需要startx一下,提示
hostname: Host name lookup failure
xauth:  file /home/root/.serverauth.1551 does not exist
38
331
331
2022-4-12
42 小时
 楼主| 发表于 2023-11-2 18:41:24 | 显示全部楼层
使用xcb也不行
root@ATK-IMX6U:~# /usr/local/data/module_HMI -platform xcb
qt.qpa.xcb: could not connect to display :0.0
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb, minimal, offscreen, vnc, xcb.
Aborted
root@ATK-IMX6U:~#
GMT+8, 2026-10-31 01:37
