查看: 3684|回复: 2
LCD驱动:modetest测试程序 无法获取 CRTC_ID 信息
78
78
2021-11-11
发表于 2023-12-19 17:38:24 | 显示全部楼层 |阅读模式
如题,打印信息如下:
  1. trying to open device 'i915'...failed
  2. trying to open device 'amdgpu'...failed
  3. trying to open device 'radeon'...failed
  4. trying to open device 'nouveau'...failed
  5. trying to open device 'vmwgfx'...failed
  6. trying to open device 'omapdrm'...failed
  7. trying to open device 'exynos'...failed
  8. trying to open device 'tilcdc'...failed
  9. trying to open device 'msm'...failed
  10. trying to open device 'sti'...failed
  11. trying to open device 'tegra'...failed
  12. trying to open device 'imx-drm'...failed
  13. trying to open device 'rockchip'...failed
  14. trying to open device 'atmel-hlcdc'...failed
  15. trying to open device 'fsl-dcu-drm'...failed
  16. trying to open device 'vc4'...failed
  17. trying to open device 'virtio_gpu'...failed
  18. trying to open device 'mediatek'...failed
  19. trying to open device 'meson'...failed
  20. trying to open device 'pl111'...failed
  21. trying to open device 'stm'...done
  22. Encoders:
  23. id      crtc    type    possible crtcs  possible clones
  24. 31      35      DPI     0x00000001      0x00000000
  25. Connectors:
  26. id      encoder status          name            size (mm)       modes   encoders
  27. 32      31      connected       DPI-1           0x0             1       31
  28.   modes:
  29.         index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot
  30.   #0 800x480 60.16 800 888 936 976 480 512 515 528 31000 flags: phsync, pvsync; type: preferred, driver
  31.   props:
  32.         1 EDID:
  33.                 flags: immutable blob
  34.                 blobs:
  35.                 value:
  36.         2 DPMS:
  37.                 flags: enum
  38.                 enums: On=0 Standby=1 Suspend=2 Off=3
  39.                 value: 0
  40.         5 link-status:
  41.                 flags: enum
  42.                 enums: Good=0 Bad=1
  43.                 value: 0
  44.         6 non-desktop:
  45.                 flags: immutable range
  46.                 values: 0 1
  47.                 value: 0
  48.         4 TILE:
  49.                 flags: immutable blob
  50.                 blobs:
  51.                 value:
  52. CRTCs:
  53. id      fb      pos     size
  54. 35      38      (0,0)   (800x480)
  55.   #0 800x480 60.16 800 888 936 976 480 512 515 528 31000 flags: phsync, pvsync; type: preferred, driver
  56.   props:
  57.         24 VRR_ENABLED:
  58.                 flags: range
  59.                 values: 0 1
  60.                 value: 0
  61.         28 GAMMA_LUT:
  62.                 flags: blob
  63.                 blobs:
  64.                 value:
  65.         29 GAMMA_LUT_SIZE:
  66.                 flags: immutable range
  67.                 values: 0 4294967295
  68.                 value: 256
  69. Planes:
  70. id      crtc    fb      CRTC x,y        x,y     gamma size      possible crtcs
  71. 33      35      38      0,0             0,0     0               0x00000001
  72.   formats: AR24 XR24 RG24 RG16 AR15 XR15 AR12 XR12 C8
  73.   props:
  74.         8 type:
  75.                 flags: immutable enum
  76.                 enums: Overlay=0 Primary=1 Cursor=2
  77.                 value: 1
  78.         30 IN_FORMATS:
  79.                 flags: immutable blob
  80.                 blobs:
  81.                 value:
  82.                         01000000000000000900000018000000
  83.                         01000000400000004152323458523234
  84.                         52473234524731364152313558523135
  85.                         41523132585231324338202000000000
  86.                         ff010000000000000000000000000000
  87.                         0000000000000000
  88.                 in_formats blob decoded:
  89.                          AR24:  LINEAR
  90.                          XR24:  LINEAR
  91.                          RG24:  LINEAR
  92.                          RG16:  LINEAR
  93.                          AR15:  LINEAR
  94.                          XR15:  LINEAR
  95.                          AR12:  LINEAR
  96.                          XR12:  LINEAR
  97.                          C8  :  LINEAR
  98. 36      0       0       0,0             0,0     0               0x00000001
  99.   formats: AR24 RG24 RG16 AR15 AR12 C8
  100.   props:
  101.         8 type:
  102.                 flags: immutable enum
  103.                 enums: Overlay=0 Primary=1 Cursor=2
  104.                 value: 0
  105.         30 IN_FORMATS:
  106.                 flags: immutable blob
  107.                 blobs:
  108.                 value:
  109.                         01000000000000000600000018000000
  110.                         01000000300000004152323452473234
  111.                         52473136415231354152313243382020
  112.                         3f000000000000000000000000000000
  113.                         0000000000000000
  114.                 in_formats blob decoded:
  115.                          AR24:  LINEAR
  116.                          RG24:  LINEAR
  117.                          RG16:  LINEAR
  118.                          AR15:  LINEAR
  119.                          AR12:  LINEAR
  120.                          C8  :  LINEAR
  121. Frame buffers:
  122. id      size    pitch
78
78
2021-11-11
 楼主| 发表于 2023-12-19 17:38:50 | 显示全部楼层
要如何检查配置
78
78
2021-11-11
 楼主| 发表于 2023-12-19 17:40:34 | 显示全部楼层
connecter的  props 里没有输出 CRTC_ID 信息
GMT+8, 2026-11-3 09:59
