查看: 1234|回复: 0
DLRK3568 make bootimage -j8 编辑报错
74
74
2019-10-28
24 小时
发表于 2024-2-20 16:20:23 | 显示全部楼层 |阅读模式
alientek@alientek-virtual-machine:~/rk3568_android_sdk$ make bootimage -j8
16:01:28 ************************************************************
16:01:28 You are building on a machine with 7.72GB of RAM
16:01:28
16:01:28 The minimum required amount of free memory is around 16GB,
16:01:28 and even with that, some configurations may not work.
16:01:28
16:01:28 If you run into segfaults or other errors, try reducing your
16:01:28 -j value.
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=11
TARGET_PRODUCT=aosp_arm
TARGET_BUILD_VARIANT=eng
TARGET_BUILD_TYPE=release
TARGET_ARCH=arm
TARGET_ARCH_VARIANT=armv7-a-neon
TARGET_CPU_VARIANT=generic
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-5.15.0-76-generic-x86_64-Ubuntu-20.04.2-LTS
HOST_CROSS_OS=windows
HOST_CROSS_ARCH=x86
HOST_CROSS_2ND_ARCH=x86_64
HOST_BUILD_TYPE=release
BUILD_ID=RD2A.211001.002
OUT_DIR=out
PRODUCT_SOONG_NAMESPACES=device/generic/goldfish device/generic/goldfish-opengl hardware/google/camera har
dware/google/camera/devices/EmulatedCamera device/generic/goldfish device/generic/goldfish-opengl
[100% 45510/45510] out/soong/.bootstrap/bin/soong_build out/soong/build.ninja
FAILED: out/soong/build.ninja
out/soong/.bootstrap/bin/soong_build -t -l out/.module_paths/Android.bp.list -b out/soong -n out -d out/so
ong/build.ninja.d -globFile out/soong/.bootstrap/build-globs.ninja -o out/soong/build.ninja Android.bp
libRkTeeWeaver want to conditional Compile
libcameradevice want to conditional Compile
libgralloc_priv want to conditional Compile
libmpimmz conditional Compile
librga want to conditional Compile
librockit want to conditional Compile
Rockchip conditional compile
Optee Version: v1
[hardware/rockchip/libgralloc] 30
libcameradevice curr board is rk356x
error: device/generic/opengl-transport/host/libs/virglrenderer/Android.bp:156:1: "libvirglrenderer_cuttlef
ish" depends on undefined module "cuttlefish_host_only"
16:04:59 soong bootstrap failed with: exit status 1
#### failed to build some targets (03:31 (mm:ss)) ####
GMT+8, 2026-10-30 21:51
