查看: 5239|回复: 7
[XILINX] petalinux2023编译出来的ZYNQ7020嵌入式linux无法通过sd卡boot
2024-2-21
发表于 2024-2-21 17:09:35 | 显示全部楼层 |阅读模式
2024-2-21
 楼主| 发表于 2024-2-22 19:48:04 | 显示全部楼层
有无懂哥有思路。
2217
6434
6434
2018-10-21
1908 小时
发表于 2024-2-23 09:08:45 | 显示全部楼层
20.2版本有试过有问题吗?主要是你这个版本也没人用过
2024-1-9
发表于 2024-3-18 16:29:41 | 显示全部楼层
我也用的petalinux 2023.2,但是ubuntu用的18.04版本,你的改一下设备树,
我的如下,可以编译通过并正常启动运行:
/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
system-user.dtsi内容如下:
/include/"system-conf.dtsi"
#include "include/dt-bindings/input/input.h"
#include "include/dt-bindings/gpio/gpio.h"
#include "include/dt-bindings/phy/phy.h"
model = "Alientek Navigator Zynq Development Board";
        compatible = "xlnx,zynq-zc702", "xlnx,zynq-7000";
    leds {
                compatible = "gpio-leds";
                gpio-led1 {
                        label = "led2";
                        gpios = <&gpio0 0 GPIO_ACTIVE_HIGH>;
                        default-state = "on";
                gpio-led2 {
                        label = "led1";
                        gpios = <&gpio0 54 GPIO_ACTIVE_HIGH>;
                        linux,default-trigger = "heartbeat";
                gpio-led3 {
                        label = "pl_led0";
                        gpios = <&axi_gpio_0 0 0 GPIO_ACTIVE_HIGH>;
                gpio-led4 {
                        label = "pl_led1";
                        gpios = <&axi_gpio_0 1 0 GPIO_ACTIVE_HIGH>;
                        linux,default-trigger = "timer";
                gpio-led5 {
                        label = "ps_led0";
                        gpios = <&gpio0 7 GPIO_ACTIVE_HIGH>;
                gpio-led6 {
                        label = "ps_led1";
                        gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>;
keys {
                compatible = "gpio-keys";
                autorepeat;
                gpio-key1 {
                        label = "pl_key0";
                        gpios = <&gpio0 55 GPIO_ACTIVE_LOW>;
                        linux,code = <KEY_LEFT>;
                        gpio-key,wakeup;
                        autorepeat;
                gpio-key2 {
                        label = "pl_key1";
                        gpios = <&gpio0 56 GPIO_ACTIVE_LOW>;
                        linux,code = <KEY_RIGHT>;
                        gpio-key,wakeup;
                        autorepeat;
                gpio-key3 {
                        label = "ps_key1";
                        gpios = <&gpio0 12 GPIO_ACTIVE_LOW>;
                        linux,code = <KEY_UP>;
                        gpio-key,wakeup;
                        autorepeat;
                gpio-key4 {
                        label = "ps_key2";
                        gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
                        linux,code = <KEY_DOWN>;
                        gpio-key,wakeup;
                        autorepeat;
                touch-key {
                        label = "touch_key";
                        gpios = <&gpio0 57 GPIO_ACTIVE_HIGH>;
                        linux,code = <KEY_ENTER>;
                        gpio-key,wakeup;
                        autorepeat;
教程提供的很多东西,petalinux版本升级以后就不能用了,也挺着急的
2024-1-9
发表于 2024-3-18 16:32:56 | 显示全部楼层
我的如下,可以编译通过并正常 ...
而且petalinux 2023.2版本默认启动的时候,从串口是进不去root的,你的改下配置才行。
petalinux-config -c rootfs->Image Features->serial-autologin-root.
2024-1-9
发表于 2024-3-18 16:35:41 | 显示全部楼层
我的如下,可以编译通过并正常 ...
现在教程提供的设备树基本都编译不过的,即使编译过了运行也有问题,还请官方尽早给出修改吧。另外感觉《【正点原子】领航者ZYNQ之嵌入式Linux开发指南_V3.2》这个教程写的不咋好,感觉很多东西没讲清楚。
58
58
2024-6-17
发表于 2024-6-22 17:54:04 | 显示全部楼层
【闲鱼】https://m.tb.cn/h.g5tXPPK?tk=woLsWzUYgnt MF7997 「我在闲鱼发布了【greenhill v7.1.6  RH850编译器 支持U】」
点击链接直接打开
greenhill v7.1.6  RH850编译器 支持U2A系列,F1系列,E1/E2系列,G系列 2022版本。crack版本,永久license。Rh850 U2A系列 MCAL DaVinci工具 + 测试代码(U2A16) 测试工程中已经集成MCAL GPT,PWM,ICU,ADC,SPI,CAN等模块,实际测试验证板卡正常.注:工具和测试代码需要额外购买
优势:1.不用硬件加密狗不绑定电脑。2.不限制电脑安装。3.送ghs工程和教学视频一个。4.RH850有整套工具链
微信图片_20240617160121.jpg 微信图片_20240617160107.jpg 微信图片_20240617160054.jpg 微信图片_20240617160045.jpg 微信图片_20240617160033.jpg
119
119
2025-9-21
27 小时
发表于 2025-10-16 10:24:05 | 显示全部楼层
这个问题解决了吗,怎么解决的呢,
GMT+8, 2026-10-30 23:39
