查看: 3565|回复: 1
uboot无法识别网络原厂自带的也不行
78
78
2016-4-4
发表于 2024-3-8 09:31:25 | 显示全部楼层 |阅读模式
10金钱
phy芯片是sr8201f版本的
U-Boot 2016.03-g0ae7e33 (Aug 14 2022 - 19:42:45 +0800) 出厂自带的同时我还测试出场自带程序的wifi,能搜索,但是连接永远是密码错误,就算是正确的密码也是这样。
=> bdinfo
arch_number = 0x00000000
boot_params = 0x80000100
DRAM bank   = 0x00000000
-> start    = 0x80000000
-> size     = 0x20000000
eth0name    = FEC1
ethaddr     = b8:ae:1d:01:00:00
current eth = FEC1
ip_addr     = 192.168.0.117
baudrate    = 115200 bps
TLB addr    = 0x9FFF0000
relocaddr   = 0x9FF56000
reloc off   = 0x18756000
irq_sp      = 0x9EF53EA0
sp start    = 0x9EF53E90
输入DHCP后出现下面错误 。
*** ERROR: `ethaddr' not set
手动设置后还是不行就绿灯闪烁,黄灯长灭。
自己编译了03文件中提供的出场源码
U-Boot 2016.03 (Mar 07 2024 - 11:04:39 +0800)
CPU:   Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 35C
Reset cause: POR
Board: I.MX6U ALPHA|MINI
I2C:   ready
DRAM:  512 MiB
NAND:  0 MiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc0 is current device
Net:   Board Net Initialization Failed
No ethernet found.
Normal Boot
=> bdinfo
current eth = unknown
ip_addr     = <NULL>
relocaddr   = 0x9FF48000
reloc off   = 0x18748000
irq_sp      = 0x9EF45EA0
sp start    = 0x9EF45E90
当前网卡直接不知了,不知道是不是 网卡部分没有移植。使用的版本是uboot-imx-2016.03-2.1.0-gee88051-v1.6.tar.bz2
发表于 2024-3-12 20:08:34 | 显示全部楼层
GMT+8, 2026-10-31 01:02
