查看: 2727|回复: 2
ATK-DLRV1126开发板 mpi_enc_test 编码yuv视频文件出错
2023-10-14
发表于 2024-4-3 15:14:35 | 显示全部楼层 |阅读模式
[root@ATK-DLRV1126:/]# mpi_enc_test -w 720 -h 576 -t 7 -i /dev/video50 -o ./720576yuv420xx2.yuv -n 100 -f 0x4
mpp[829]: mpi_enc_utils: cmd parse result:
mpp[829]: mpi_enc_utils: input  file name: /dev/video50
mpp[829]: mpi_enc_utils: output file name: ./720576yuv420xx2.yuv
mpp[829]: mpi_enc_utils: width      : 720
mpp[829]: mpi_enc_utils: height     : 576
mpp[829]: mpi_enc_utils: format     : 4
mpp[829]: mpi_enc_utils: type       : 7
mpp[829]: mpi_enc_test: mpi_enc_test start
mpp[829]: mpi_enc_test: open camera device
mpp[829]: camera_source: get width 640 height 480
mpp[829]: camera_source: get dma buf(0)-fd: 5
mpp[829]: mpp_rt: NOT found ion allocator
mpp[829]: mpp_rt: found drm allocator
mpp[829]: camera_source: get dma buf(1)-fd: 8
mpp[829]: camera_source: get dma buf(2)-fd: 9
mpp[829]: camera_source: get dma buf(3)-fd: 10
mpp[829]: mpi_enc_test: new framecap ok
mpp[829]: mpp_info: mpp version: unknown mpp version for missing VCS info
mpp[829]: mpi_enc_test: 0x348a0 mpi_enc_test encoder test start w 720 h 576 type 7
mpp[829]: mpp_enc: MPP_ENC_SET_RC_CFG bps 1555200 [97200 : 1652400] fps [30:30] gop 60
mpp[829]: h264e_api_v2: MPP_ENC_SET_PREP_CFG w:h [720:576] stride [720:576]
mpp[829]: mpp_enc: send header for set cfg change input/format
mpp[829]: mpp_enc: mode vbr bps [97200:1555200:1652400] fps fix [30/1] -> fix [30/1] gop i [60] v [0]
mpp[829]: mpi_enc_test: 0x348a0 encoded frame 0    size 56738   qp 26
mpp[829]: mpi_enc_test: 0x348a0 encoded frame 1    size 31003   qp 31
[  117.310036] rk_iommu ffbb0f00.iommu: Page fault at 0x002f5400 of type read
[  117.310106] rk_iommu ffbb0f00.iommu: iova = 0x002f5400: dte_index: 0x0 pte_index: 0x2f5 page_offset: 0x400
[  117.310144] rk_iommu ffbb0f00.iommu: mmu_dte_addr: 0x27911000 dte@0x27911000: 0x2672a001 valid: 1 pte@0x2672abd4: 0x000000 valid: 0 page@0x00000000 flags: 0x0
[  117.310175] mpp_rkvenc ffbb0000.rkvenc: fault addr 0x002f5400 status 4b
[  117.310196] mpp_task_dump_mem_region:1546: --- dump mem region ---
详见附件.
rv1126_mpp_enc_test_dev_video50_debug_problem0002.zip
3.08 KB, 下载次数: 0
2023-10-14
 楼主| 发表于 2024-4-3 16:04:37 | 显示全部楼层
麻烦知道的请指教下.
2023-10-14
 楼主| 发表于 2024-4-8 14:46:50 | 显示全部楼层
参数配置问题
GMT+8, 2026-10-30 21:12
