查看: 3081|回复: 0
RV1126怎么配置内核和设备树驱动OV7670摄像头?
2019-8-9
发表于 2024-5-23 16:41:03 | 显示全部楼层 |阅读模式
内核配置如图:
设备树配置:
硬件接线如图:
报错:
  1. Populating /dev using udev: [    2.771902] udevd[127]: starting version 3.2.7
  2. [    2.779594] udevd[127]: specified group 'kvm' unknown
  3. [    2.797867] udevd[128]: starting eudev-3.2.7
  4. [    2.940210] rkcif_dvp: get_remote_sensor: remote pad is null
  5. [    2.940341] rkcif_dvp: rkcif_update_sensor_info: stream[2] get remote sensor_sd failed!
  6. [    2.940379] stream_cif_dvp_id2: update sensor info failed -19
  7. [    2.941380] stream_cif_dvp_id0: update sensor info failed -515
  8. [    2.947517] rkcif_dvp: get_remote_sensor: remote pad is null
  9. [    2.947562] rkcif_dvp: rkcif_update_sensor_info: stream[3] get remote sensor_sd failed!
  10. [    2.947572] stream_cif_dvp_id3: update sensor info failed -19
  11. [    2.953500] rockchip-mipi-dphy-rx: No link between dphy and sensor
  12. [    2.955624] rkcif_dvp: get_remote_sensor: remote pad is null
  13. [    2.955725] rkcif_dvp: rkcif_update_sensor_info: stream[1] get remote sensor_sd failed!
  14. [    2.955962] stream_cif_dvp_id1: update sensor info failed -19
  15. [    2.958707] rockchip-mipi-dphy-rx: No link between dphy and sensor
  16. [    2.962840] rockchip-mipi-dphy-rx: No link between dphy and sensor
  17. [    2.967003] rockchip-mipi-dphy-rx: No link between dphy and sensor
  18. [    3.007163] rockchip-mipi-dphy-rx: No link between dphy and sensor
GMT+8, 2026-10-30 21:15
