查看: 1536|回复: 0
移植stlib库报错,请大佬帮忙解决下,万分感谢
2024-2-22
发表于 2024-6-3 16:28:38 | 显示全部楼层 |阅读模式
报错如下
tom@tom:~/linux/IMX6ULL/tool/tslib-1.21$ ./autogen.sh
libtoolize: putting auxiliary files in '.'.
libtoolize: copying file './ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'm4/internal'.
libtoolize: copying file 'm4/internal/libtool.m4'
libtoolize: copying file 'm4/internal/ltoptions.m4'
libtoolize: copying file 'm4/internal/ltsugar.m4'
libtoolize: copying file 'm4/internal/ltversion.m4'
libtoolize: copying file 'm4/internal/lt~obsolete.m4'
configure.ac:60: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:60: You should run autoupdate.
./lib/autoconf/general.m4:204: AC_HELP_STRING is expanded from...
m4/internal/visibility.m4:63: TS_CC_HIDDEN_VISIBILITY is expanded from...
configure.ac:60: the top level
configure.ac:66: warning: The macro `AC_LIBTOOL_DLOPEN' is obsolete.
configure.ac:66: You should run autoupdate.
m4/internal/ltoptions.m4:113: AC_LIBTOOL_DLOPEN is expanded from...
configure.ac:66: the top level
configure.ac:66: warning: AC_LIBTOOL_DLOPEN: Remove this warning and the call to _LT_SET_OPTION when you
configure.ac:66: put the 'dlopen' option into LT_INIT's first parameter.
./lib/autoconf/general.m4:2434: AC_DIAGNOSE is expanded from...
configure.ac:67: warning: The macro `AC_PROG_LIBTOOL' is obsolete.
configure.ac:67: You should run autoupdate.
m4/internal/libtool.m4:99: AC_PROG_LIBTOOL is expanded from...
configure.ac:67: the top level
configure.ac:74: warning: The macro `AC_HEADER_STDC' is obsolete.
configure.ac:74: You should run autoupdate.
./lib/autoconf/headers.m4:704: AC_HEADER_STDC is expanded from...
configure.ac:74: the top level
configure.ac:84: warning: The macro `AC_HEADER_TIME' is obsolete.
configure.ac:84: You should run autoupdate.
./lib/autoconf/headers.m4:743: AC_HEADER_TIME is expanded from...
configure.ac:84: the top level
configure.ac:90: warning: The macro `AC_TYPE_SIGNAL' is obsolete.
configure.ac:90: You should run autoupdate.
./lib/autoconf/types.m4:776: AC_TYPE_SIGNAL is expanded from...
configure.ac:90: the top level
configure.ac:98: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:98: You should run autoupdate.
m4/internal/tslib_modules.m4:5: TSLIB_CHECK_MODULE is expanded from...
configure.ac:98: the top level
configure.ac:99: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:99: You should run autoupdate.
configure.ac:99: the top level
configure.ac:100: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:100: You should run autoupdate.
configure.ac:100: the top level
configure.ac:101: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:101: You should run autoupdate.
configure.ac:101: the top level
configure.ac:102: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:102: You should run autoupdate.
configure.ac:102: the top level
configure.ac:103: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:103: You should run autoupdate.
configure.ac:103: the top level
configure.ac:104: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:104: You should run autoupdate.
configure.ac:104: the top level
configure.ac:105: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:105: You should run autoupdate.
configure.ac:105: the top level
configure.ac:106: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:106: You should run autoupdate.
configure.ac:106: the top level
configure.ac:107: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:107: You should run autoupdate.
configure.ac:107: the top level
configure.ac:108: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:108: You should run autoupdate.
configure.ac:108: the top level
configure.ac:113: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:113: You should run autoupdate.
configure.ac:113: the top level
configure.ac:116: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:116: You should run autoupdate.
configure.ac:116: the top level
configure.ac:117: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:117: You should run autoupdate.
configure.ac:117: the top level
configure.ac:120: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:120: You should run autoupdate.
configure.ac:120: the top level
configure.ac:121: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:121: You should run autoupdate.
configure.ac:121: the top level
configure.ac:122: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:122: You should run autoupdate.
configure.ac:122: the top level
configure.ac:123: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:123: You should run autoupdate.
configure.ac:123: the top level
configure.ac:124: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:124: You should run autoupdate.
configure.ac:124: the top level
configure.ac:125: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:125: You should run autoupdate.
configure.ac:125: the top level
configure.ac:126: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:126: You should run autoupdate.
configure.ac:126: the top level
configure.ac:127: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:127: You should run autoupdate.
configure.ac:127: the top level
configure.ac:128: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:128: You should run autoupdate.
configure.ac:128: the top level
configure.ac:129: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:129: You should run autoupdate.
configure.ac:129: the top level
configure.ac:130: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:130: You should run autoupdate.
configure.ac:130: the top level
configure.ac:131: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:131: You should run autoupdate.
configure.ac:131: the top level
configure.ac:132: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:132: You should run autoupdate.
configure.ac:132: the top level
configure.ac:133: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:133: You should run autoupdate.
configure.ac:133: the top level
configure.ac:58: installing './compile'
configure.ac:7: installing './missing'
plugins/Makefile.am: installing './depcomp'
GMT+8, 2026-10-31 02:55
