查看: 7351|回复: 2
RK3568LCD屏鼠标操作报错,键盘操作正常,请问是怎么回事?
80
319
319
2020-10-19
66 小时
发表于 2024-6-14 10:05:59 | 显示全部楼层 |阅读模式
  1. 我的RK3568上是基于Deiban替换的Ubuntu-base,外接键盘是可以正常输入的,但是外接鼠标的话就没有反应,每次点击时串口日志都会打印这个错误,请问是什么原因?怎么解决呢?
80
319
319
2020-10-19
66 小时
 楼主| 发表于 2024-6-14 10:06:23 | 显示全部楼层
[51754.803105] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.811038] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.819037] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.826981] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.835072] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.843018] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.850980] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.859052] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.866929] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.875119] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.883070] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.891186] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51754.995197] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51755.048020] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51755.049242] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51755.050685] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51755.058913] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51755.066873] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0 [51755.075126] [drm:vop2_plane_atomic_check] *ERROR* Unsupported linear format at Cluster0-win0
80
319
319
2020-10-19
66 小时
 楼主| 发表于 2024-6-18 17:19:26 | 显示全部楼层
已解决
GMT+8, 2026-10-30 21:15
